Old 10-03-2012, 12:06 PM   #1
bighopper OP
Oddometer: 193
BaseCamp 4.0.2 Update Available - WIN
Just installed Basecamp 4.0.2, a bunch of fixes. That might help with some of your issues of late.
I Just Like To Ride
'03 BMW R1150GSA
'06 BMW K1200LT
bighopper is offline   Reply With Quote
Old 10-06-2012, 06:48 AM   #2
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,646
Thanks for mentioning this! Am updating now.
The list of fixes:
  • Added smoothing of speed and heart rate graphs.
  • Improved Track Join inside of an Adventure
  • Change to not show the "Filter Results" option in the find results if there are no results to filter.
  • Fixed layout not being remembered properly between application runs.
  • Fixed layout being different after exiting from Adventure playback.
  • Fixed an issue with the "References" tab page not being properly updated when changing selection.
  • Fixed an issue with route shaping point info being lost when erasing points from a route.
  • Fixed an issue with track color being changed when tracks are filtered.
  • Fixed an issue with not updating the summary in the route dialog when points are unselected.
  • Fixed some issues with login and re-login for MyGarmin services
  • Fixed doing an undo while drawing a route ending the route. Now only the last via point is removed.
  • Fixed an issue when importing photos with invalid time EXIF data.
  • Fixed text messages from Basestation devices being repeatedly notified
  • Fixed an issue with route join
  • Fixed an issue with the route divide tool
  • Fixed an issue with duplicating routes
  • Fixed an issue with adding waypoints into routes in an Adventure
  • Fixed an issue with line breaks being repeatedly added to GPX files
  • Fixed an issue with click & drag on the map hiding properties dialog
  • Fixed an issue with importing KML or KMZ files that had downloadable content.
  • Fixed an issue with creating a waypoint via the map context menu when a list folder is selected
  • Fixed an issue where the waypoint ordering was not updated when changing the main track in an Adventure
  • Fixed an issue when clicking on the 'X' to remove a tag from the References tab page.
  • Fixed an issue when changing map detail level before putting focus into the map views.
  • Fixed an issue where the creation date of a photo waypoint didn't match the creation date of the photo's EXIF data
  • Fixed an issue with waypoints sometimes not being shown on the map
  • Fixed an issue with some card products not being recognized. Unfortunately this requires re-indexing all card products.
  • Fixed various other customer reported issues
Times are GMT -7.   It's 03:12 PM.
