Old 10-06-2012, 06:59 AM   #16
GHT
Weeee Rider!!!
GHT's Avatar
Oddometer: 162
Thumb
That's great information, I'm just lovin this Wee more and more!
'08 Suzuki DL650 WeeStrom (Yellow/Black)
'08 Yamaha WR250R (Blue)
'03 KTM 450 EXC (Sold)
'03 Yamaha FJR 1300 (sold)
'06 Suzuki DRZ400SM/S (sold) '06 Suzuki M50 (sold) '05 Kawasaki KLR (sold)
GHT is offline   Reply With Quote
Old 10-06-2012, 02:34 PM   #17
CvFactor
Oddometer: 50
Originally Posted by DSM8 View Post
I have an 09 SV650 Crate motor sitting in the shop just waiting to go into this bike when I get around to it. When the shifting gets to the point it annoys me more than anything else will be the time I will swap them out.
The drum is an $80 part. So yeah not terrible to fix but I don't feel like putting that kinda time into it when there is a freshee sitting there waiting to be used.
Where did you get the SV650 crate motor and how much was it?
CvFactor is offline   Reply With Quote
Old 10-06-2012, 11:05 PM   #18
DSM8 OP
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,961
Got it from a place here in LA, story is the bike was brand new and got damaged somehow. Was a total write off. Blind luck on my part to get it, I just had to wait 6 months for it to finally clear the insurance crap.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 10-07-2012, 05:45 PM   #19
RickS
RickS's Avatar
Oddometer: 595
How much did the valve clearance change between adjustments? What interval did u check valves?
RickS is offline   Reply With Quote
Old 10-07-2012, 07:36 PM   #20
DSM8 OP
DSM8's Avatar
Oddometer: 3,961
I had them checked at the factory intervals.
600 first, then every req interval after that. It has not needed a valve adjustment till 45K miles and not another one since.
Old 10-08-2012, 05:15 PM   #21
sierraoffroad
sierraoffroad's Avatar
Oddometer: 1,339
wow congrats on the miles. are you still on your stock clutch? i have just under 50k miles and had to replace the cable. otherwise its great.
2013 Super Tenere
2004 Yamaha Wr250f
sierraoffroad is offline   Reply With Quote
Old 10-08-2012, 05:51 PM   #22
DSM8 OP
DSM8's Avatar
Oddometer: 3,961
Yup which is surprising.
Other than, tires, chains, oil and filters the motor is untouched.
Old 10-09-2012, 03:15 AM   #23
sierraoffroad
Oddometer: 1,339
thanks for your reply. same here on the maint. items. all i have done is tires chains, etc.
2013 Super Tenere
2004 Yamaha Wr250f
Old 10-09-2012, 02:23 PM   #24
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 6,082
Amsoil synthetic
I swear by amsoil but you sure can't convince the rest of the riding population.
Nice stats Dave.
Chris Brown - "The Browneye"
"Without Motorcycles, People Live Very Boring Lives." - Malcolm Smith
Camp Nelson 2014 RR Laguna Seca 2012 RR Sequoia 3-Day Campout Thanksgiving 2012
browneye is offline   Reply With Quote
Old 10-09-2012, 02:58 PM   #25
DSM8 OP
DSM8's Avatar
Oddometer: 3,961
Nice stats Dave.
Thats why I became a dealer. To get it at cost.
Old 10-09-2012, 03:38 PM   #26
browneye
PIN IT & BANG GEARS
browneye's Avatar
Oddometer: 6,082
X2
Like 15 years ago. I'm still broke.
But my vehicles run good.
Old 10-09-2012, 03:40 PM   #27
uzidzit
Oddometer: 12
shift drum?
How have you traced the problem there? Just asking as I have been around the sv motor a while and have not really seen trouble there, seen a bad detent though and several bad shift forks (but I was building race motors).
I would be surprised if the valves went if you kept them to the loose side of the tol. The sv-650 will break a bottom end when over revved on the track, and tends to wear out the cam chain guide in the front jug, and cam chain. I am thinking the tranny would be more likely shift forks.
My original wee (an 04) is in Newport Tn right now with about 138k on the clock and the cam chain is a little noisy as of june( this year last time I saw its current owner). The only thing done to this engine has been valve checks (15k set at max, 65k still in but tighter re-set to max, 110k re-set max loose but were still in).
Just to add to the oil thd(ugh)the 04 had only seen rotella full syn 5w-40 from wally world every 5-6k. (changed when the clutch got a little grabby)
I just did the valves on my 06 at 66,000 (second setting) and could have left them. I just set them max loose again, hint for you guys suzy shims(and aftermkt) are in.05mm increments(7.48mm O.D. shims) trade your shims with an old honda shop, honda shims are avail in .025mm increments. so you can hit your numbers closer(lap them if you really want to hit it spot on).
Valve guides seem to not wear much in these motors in my exp. if the buckets fit properly in the head
Just ramblings don't post much but this caught my eye
uzidzit is offline   Reply With Quote
Old 10-09-2012, 03:59 PM   #28
DSM8 OP
DSM8's Avatar
Oddometer: 3,961
I assumed it was the shift drum based on a past experience, but without getting into the motor or trans there is no real way to determine the cause. It just randomly false neutrals between gears (all of them) which by my understanding was more towards the shift drum than forks since as I have been told the forks are specific to certain gears, and this is happening across the board.
Regardless if/when it gets bad I will just yank the motor then might dig into it and take measurements just for grins.
Old 10-11-2012, 03:54 PM   #29
uzidzit
Oddometer: 12
Hey did ya get new boots?
I started missing the random shift, when I went from my old sidi roads to a shorter toe box, pair of boots. that missed shift followed me at random on all my bikes till the new boots broke me in.
Old 10-11-2012, 04:10 PM   #30
DSM8 OP
DSM8's Avatar
Oddometer: 3,961
Yes I got new boots but this problem persisted for about 20K miles prior to the new boots.
Wish it was that simple..
Times are GMT -7.   It's 04:22 PM.
