Old 10-06-2012, 09:10 AM   #16
mountain eagle
terrorist
mountain eagle's Avatar
Oddometer: 2,920
Originally Posted by RiikMi View Post
You can open orginal headlight switch and file a little plastic pin off ,then you have on/off-low-high switch.
Anyone done a tutorial? I'll have to look into this...........
mountain eagle
08'Husky TE610 x 2 TE/SM
KTM 950SE
my smugmug gallery
How can it be fun if there's not at least an outside chance of dying?
mountain eagle is offline   Reply With Quote
Old 10-06-2012, 09:15 AM   #17
bigkuri
bigkuri's Avatar
Oddometer: 741
If it is any help I think that the euro switchgear with a off position is a pretty common part. I used it for heated grips, and bought a $10 second hand unit from a R1
See http://advrider.com/forums/showthread.php?t=690895
Current Bikes: 2006 Honda XR650R & 2007 KTM 950 SMR
bigkuri is offline   Reply With Quote
Old 10-06-2012, 10:13 AM   #18
Schannulleke
Oddometer: 208
I have SAS system taken off and fuel pump is located behind of airfilter box. I took fuel lines both sides of engine to T -joint and from T-joint a short fuel hose to fuel pump . Horn is also located to another place so i have only fuel light wire what i have to take off. Sorry about my bad english.
Sounds interesting, that might simplify tank removal and mounting.
- Do you have pictures of that setup.
- Is the current fuel pump location higher than original? This higher location compared to the fuel level in the tank, doesn't this give any problems regarding regarding static pressure?
Schannulleke is offline   Reply With Quote
Old 10-07-2012, 08:27 AM   #19
RiikMi
Oddometer: 65
I dont have pics...yet. My driving season ends after this month(cause of winter) ,then i take my SE a part then i can take some pics of my fuel lines.
Put your e-mail address for me by PM so i can send a few photos of my fuelpump location and headlight switch.
RiikMi is offline   Reply With Quote
Old 10-07-2012, 09:11 AM   #20
pepetrueba
PePeBaJa
pepetrueba's Avatar
Oddometer: 197
ktm euro light switch
The EU light switch is not compatible with the USA wiring.
I tried going that way on my SE and price is astronomical because the harness is around 500.+- then add the cost of the euro switch. This website helped me on same question I had a copuple of years ago
Cheapest alternative is filing off plastic on stock or open light shell and t a switch on the low beam.that way you can turn it off.
Pepe
LURKER
pepetrueba is offline   Reply With Quote
Old 10-08-2012, 02:02 AM   #21
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,849
swap out the electric fuel pump for a vacuum mikuni pump - that way you dont need to pull the pump when swapping tanks.
some info & pics here that will help with plumbing a vacuum pump etc
http://www.advrider.com/forums/showthread.php?t=530176
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls is offline   Reply With Quote
Times are GMT -7.   It's 11:55 PM.
