Old 10-04-2012, 05:50 PM   #1
'05Train OP
Mind is not for rent
'05Train's Avatar
Oddometer: 1,051
Those nifty reflective decals...
.....That go on the vertical corners of the Adventure cases. Where can one find them, or do I need to cut my own?
Thanks in advance.
2005 FXSTB/I
2014 K1600GTL
2014 KLR650 NE
'05Train is offline   Reply With Quote
Old 10-04-2012, 05:54 PM   #2
Friction275
Oddometer: 120
If youre looking for the white and red 2" strips then almost any truck stop has them. They come in strips about 14"-16" long and are about half red/half white. Look in the truck Farley section with the CB parts and other stuff. Home Depot and Lowes also have them near the mailboxes and house letters.
Friction275 is offline   Reply With Quote
Old 10-04-2012, 05:55 PM   #3
Jnich77
Jnich77's Avatar
Oddometer: 678
Harbor Freight has them. Or search ebay for SOLAS tape... they have it in a ton of colors.
Jnich77 is offline   Reply With Quote
Old 10-04-2012, 05:59 PM   #4
mikegc
mikegc's Avatar
Oddometer: 1,622
Thanks in advance.
You may want to try Humvee Graphics: http://www.humvee-graphics.com/catal...a822092a172b0a
Mike
IBA 25881
Duty- Honoring a Friend
mikegc is offline   Reply With Quote
Old 10-04-2012, 07:11 PM   #5
mcstark
KaTooM convert
mcstark's Avatar
Oddometer: 1,128
Humvee is where I got mine. A little spendy, but those suckers are bright when just a little light hits them.
Red on the back corners...
And white on the front corners...
Regards,
Mark
2004 KTM 950 Adventure
Black is the new orange
mcstark is offline   Reply With Quote
Old 10-04-2012, 07:14 PM   #6
Fibzzz
Resident Cynic
Fibzzz's Avatar
Oddometer: 137
I found mine at Lowe's, reflective tape for mailboxes. I think I spent $5 total.
Fibzzz is offline   Reply With Quote
Old 10-04-2012, 08:20 PM   #7
Snarky
Vodka Infused.
Snarky's Avatar
Oddometer: 1,342
I got a big roll of red/white reflective tape from TSC and cut it in various sizes and shapes for my needs.
ALL ADDERS ARE PUFFS!
2012 BMW R1200 GSA, 2009 Kawasaki Versys (sold), 2001 Yamaha XT225 (sold)
PC Gamer? Support Star Citizen! Save PC Gaming and bring back Space Sims!
Pledge today! Service guarantees citizenship. @ http://www.robertsspaceindustries.com Thanks.
Snarky is offline   Reply With Quote
Old 10-04-2012, 08:25 PM   #8
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,009
Originally Posted by mcstark View Post
I see you use both the side stand and center stand when parked in the garage....can't be too careful.
def is online now   Reply With Quote
Old 10-04-2012, 09:20 PM   #9
Delta61
Delta61's Avatar
Oddometer: 248
Reflective Decals
This is what i put on the corners of my stock GSA panniers
http://www.motoequip.com/HK.htm
"Keep the Greasy Side Down"
10 1200 GSA
07 X Challenge
04 1150 GS(SOLD)
Delta61 is offline   Reply With Quote
Old 10-04-2012, 09:34 PM   #10
Steel Dragon
Steel Dragon's Avatar
Oddometer: 11
See the hockey stick? Goalies are just a little different
Steel Dragon is offline   Reply With Quote
Old 10-05-2012, 04:11 AM   #11
Chat Lunatique
ACK
Chat Lunatique's Avatar
Oddometer: 1,042
Yeah, Buffalo New York. Livin' downwind from them pesky Canadians will do that to ya!
I do not intend to tiptoe through life, only to arrive safely at death
Chat Lunatique is offline   Reply With Quote
Old 10-05-2012, 06:11 AM   #12
Beemer Bob
Beemer Bob's Avatar
Oddometer: 2,618
I do that too because when you let it off the center stand you have somewhere to plant it. Not just drop it if it goes over center..
Bad decisions make great stories!
"Often wrong but NEVER in doubt"!
Beemer Bob is offline   Reply With Quote
Old 10-05-2012, 06:41 AM   #13
mikegc
mikegc's Avatar
Oddometer: 1,622
"I'm the shit that happens!" Yeah, me, too!
Mike
IBA 25881
Old 10-05-2012, 07:20 AM   #14
rboett
posser noob 205
rboett's Avatar
Oddometer: 1,749
Bought some SOLAS tape,, very bright
(side stand and center stand, Good way to crush a toe.) My $.02
That'L do Pig,, That'L do
rboett is offline   Reply With Quote
Old 10-05-2012, 07:47 AM   #15
yellow 1150GS
Oddometer: 217
try identitape
After seeing a picture of some system cases in the ON magazine a few years ago, I decided to "tape" the back of my black system cases. I went to identitape.com and got some of their 1"wide engineer grade reflective tape in white, yellow, red and blue. Using Scotch blue tape in 1"width, I taped up the cases on a 45 degree angle putting the tape right next to each other. After completely taping the case, I removed every other piece of tape and replaced it with white, in effect creating a black and white herringbone pattern. Red was put vertically where the case halves meet, and yellow was put in a herringbone pattern on the rear wheel little plastic fender. Creates quite the striking effect.
Later that evening I went for a ride to Walmart. On the way home, the car that was way behind me started flashing its lights from high to low beam repeatedly. Then the police spot light came on. He caught up with me at the next stoplight, rolled down his window and asked me if I was wondering what he was doing. He told me that he noticed my "reflective signature" was like a firetruck, but I was too small.
When I got home, I took my tactical flashlight and walked two blocks away and showed it on the back of the bike. Wow! It was so bright that you could not even see the license plate in the halo. An unanticipated daylight added feature is that people do not pull up nearly as close at stoplights as they used to, usually leaving at least a car length of space instead of pulling right up to me.Don't think they are really quite sure where the back of the motorcycle is. I like that a lot. Best part about the whole conversion is that the tape is only $7.00 a roll for 15 feet, costing me about $28.00 or so for a lot of added day and night safety.
yellow 1150GS is offline   Reply With Quote
Times are GMT -7.   It's 10:06 AM.
