Old 10-05-2012, 12:20 PM   #1
zimi OP
Oddometer: 34
Send a message via Skype™ to zimi
preparing a KTM Adv 640 for a Rally
Hi Guys,
I opened this thread to ask question about the preparation of my 2004 KTM Adventure 640 R for Tuareg Rally in march 2013.
I just bought this bike the 24'000km on the clock and I don't know anything about the history of the bike.
I found out 2 problems:
-the neutral switch is sometimes difficult to find with then engine one, and the light doesn't stay on when i am in neutral. I can see it flash when I go from neutral to first or second gear and same on the other way round. What could it be?
-When I start the engine, with the choke on, if I try t o give some gas, the rpm goes down! If I wait a few minutes then the motor runs normally.
I am thinking about lowering the bike with one of the lowering kit. What experience do you have with it? I would feel more confortable on difficult sections if I can have my boths feets completely on the ground.
And for the air filter, does some of you have experience with Unifilter? It's an Australian brand sold by Touratech. PRetty expensive, but for desert racing, I suppose I shoulnd not spare on this if it's better than the original.
zimi is offline   Reply With Quote
Old 10-05-2012, 12:32 PM   #2
jon6.0
jon6.0's Avatar
Oddometer: 461
Lot's of info here: http://advrider.com/forums/showthread.php?t=86958
2013 KTM 990 Baja
jon6.0 is offline   Reply With Quote
Old 10-05-2012, 12:35 PM   #3
svenb
svenb's Avatar
Oddometer: 119
My tip if I go to Tuareg with my 2003 adv. Remove every thing that have with neutral switches, sidestand, clutch switches. So you can start without founding neutral or hold the clutch,
svenb is offline   Reply With Quote
Old 10-09-2012, 02:56 AM   #4
michael1968
michael1968's Avatar
Oddometer: 349
Uni filters are actually pretty cheap if you don't buy them from Touratech! Have a look around on the web.
Check out this thread;
http://advrider.com/forums/showthread.php?t=353839
michael1968 is offline   Reply With Quote
Old 10-09-2012, 03:20 AM   #5
grimmboy
Chris Grimm
grimmboy's Avatar
Oddometer: 828
Here's are a few suggestions:
disconnect the neutral switch
send your forks and shock off to a suspension specialist get them serviced and re-sprung and valved.
either get the 625 scx choke set-up or be prepared to put the choke end back in the carb after every fall because it pulls out and the bike won't idle.
remove all the engine hardware clean, loc-tight and re-torque to spec.
if you have the factory nylon tank, take it off, set it aside and order the KTM replacement plastic tank. It will take a better hit and tend not to crack like nlyon.
get spare levers, shift included you can hide them behind the fairing.
run bib mousse and michelin desert tires
safety wire the brake bolts, counter shaft bolt and there are several other areas that seem to come loose.
if I can think of anything else i'll throw it up.
my 2001 640 adventure completed the 2008 heroes legend
enjoy the day, grimmy
grimmboy is offline   Reply With Quote
Old 10-14-2012, 08:15 AM   #6
zimi OP
Oddometer: 34
Hi grimmboy, thanks for the suggestions.
however, I cant afford giving my suspension to tune, neither to buy a new nylon tank.
What kind of screws do you glue with loctite? Like screws on the frame? Not the engine screws?
Old 10-14-2012, 11:54 PM   #7
bmwktmbill
Traveler
Oddometer: 4,070
Pay attention to the shifter lever bolt, muffler bolts, any rack or pannier bolts.
Most of the rest stays tight for me.
Pull every electrical connection and grease it with dialectric.
Grease the steering head bearings and swing arm bolt.
Bleed the brakes with DOT 4 fluid, check all brake pads and the chain and sprockets, especially the countershaft sprocket.
Tighten the spokes and zip tie them.
Rebuild the carb rubber parts in the float system, check the fuel needle for wear.
Clean the air filter and grease it into place.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 12-16-2012, 01:37 AM   #8
zimi OP
Oddometer: 34
Hi bmwktmbill, thanks for the advices, so fare i did:
change the bearings and seals of both wheels
change oil of the fork and change one needle
change the sproket seal
grease the head bearings
check all the swingarm bearings
I wil send the rear shock absorber for a service
dismounted the carb for cleaning, need a new needle
I will keep updated on the rest
Old 12-16-2012, 11:54 PM   #9
bmwktmbill
Traveler
Oddometer: 4,070
The stock filter is just fine but seal it in place with grease.
Do you have a Scotts steering stabilizer?
b
Bill Shockley
Old 12-21-2012, 02:42 PM   #10
zimi OP
Oddometer: 34
no I don't, but I will probably not need it, I am not a rally pilot, just an amateur
Old 12-21-2012, 09:29 PM   #11
bmwktmbill
Traveler
Oddometer: 4,070
The pros use them for a reason...it's cheating.
bill
Bill Shockley
Old 01-15-2013, 03:16 PM   #12
zimi OP
Oddometer: 34
Hi guys, I remounted the carburator after cleaning and changing some seals + 152.5 main jet and 47.5 idle jet.
When I start the bike with the choke, it runs fine, but If I close the choke before the engine is warm (3min). the engine stall. And it makes a strange noisee when it stall, like the autodecompressor come is action from time to time.
I feel the same when the engine is warm, without choke, if I turn the idle screw to lower the rpm, when the engine starts to runs slower, it start again to make those noise, like the autodecompressort enters in action....
Anyone can help?
And about the neutral switch. I need to have it working for the technical check of the bike. For now, the light turn on when i go from 1st to neutral or from 2nd to neutral, but don't stat on, when I am on neutral.
What should i check?
and finally on this picture, there are all these cable tied together, is this normal?
http://www.servimg.com/image_preview...=21&u=15307704
Old 01-15-2013, 08:11 PM   #13
bmwktmbill
Traveler
Oddometer: 4,070
Zimi,
What RPM are you setting the idle at? I think 1400 RPM is correct.
What position is your main jet needle in?
Did you put it together correctly as shown in the manuals?
As for the neutral switch it is possible that it is failing. If you jump(connect together) the wires that go to the switch I believe the light should go on and stay on.
Will the engine start when the transmission is in neutra and the light is out?
bill
Bill Shockley
Old 01-15-2013, 10:03 PM   #14
Åmme
Oddometer: 122
Done the Tuareg 3 times and no demand for a neutral switch during technical switch.
Åmme is offline   Reply With Quote
Old 01-16-2013, 03:43 PM   #15
zimi OP
Oddometer: 34
to bmwktmbill, I think I was under 1400 rpm. Now I understand that maybe the auto decompression will activate if the rpm of the engine is too low. My main jet needle is in 3rd groove from the top. Yes I can start the engine normally even with the light out in neutral. I will check what happen if I jump the switch. What is your diagostic if I can still start the bike normally even if the light is out? it's not the bubble because it lights up when i pass from 1st to neutral and 2nd to neutral.
To Amme, no I mean the technical control in order to get the numberplate in Switzerland
Times are GMT -7.   It's 05:59 PM.
