Old 01-16-2013, 09:44 PM   #16
bmwktmbill
Traveler
Oddometer: 4,005
Zimi,
I have never had trouble with my neutral switch, maybe yours is bad. I am thinking it makes a ground but I am tired now and want to sleep, not to look at the wiring diagram.
OK I looked at the diagram,,,it is called te idle switch and it goes to ground on one side so jumping the wire to it to ground should make the light work if everything else is OK.
IMHO.
Have you disconnected your kickstand switch?
For racing I would eliminate as much as possible.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 01-17-2013, 01:41 AM   #17
Laromonster
Vesperado !
Laromonster's Avatar
Oddometer: 1,255
It should idle at minimum 1600 rpm's, maybe more.
Laromo
'91 Vespa PX 200E "Lusso"
'05 KTM 640 ADV "Fatman"
'99 HD FLHRCI "Leviathan"
Laromonster is offline   Reply With Quote
Old 01-17-2013, 07:48 PM   #18
bmwktmbill
Traveler
Oddometer: 4,005
Laro,
Are you a little high?
Man that Ramones T-shirt is suggestive of attitude adjustment problems?
Maybe you need a Sami sandwitch.
Reindears, or what.
http://ngm.nationalgeographic.com/20...en-photography
But then what do Swedes know.
I heard they drink too much?
And there is the blonde factor.
bill
Bill Shockley
bmwktmbill screwed with this post 01-17-2013 at 08:07 PM
Old 01-18-2013, 12:36 AM   #19
biensur22
biensur22's Avatar
Oddometer: 183
Originally Posted by zimi View Post
to bmwktmbill, I think I was under 1400 rpm. Now I understand that maybe the auto decompression will activate if the rpm of the engine is too low. My main jet needle is in 3rd groove from the top. Yes I can start the engine normally even with the light out in neutral. I will check what happen if I jump the switch. What is your diagostic if I can still start the bike normally even if the light is out? it's not the bubble because it lights up when i pass from 1st to neutral and 2nd to neutral.
To Amme, no I mean the technical control in order to get the numberplate in Switzerland
What's this "bubble" you were talking about? I ask because my neutral light is out as well, although it doesn't kick on between gears, it just doesn't come on at all.
biensur22 is offline   Reply With Quote
Old 01-19-2013, 09:02 AM   #20
zimi OP
Oddometer: 35
Send a message via Skype™ to zimi
Sorry I think it's a spelling mistake, I wanted to say the green led on the dashboard.
The kickstandswitch is disconnected.
Bmwktmbill, I tried to disconnect the green cable coming on the neutral switch and put it to the ground. It works, the green light stays on... even if I have a gear. it seems to me that it's pretty difficult to dismount this neutral switch, because of the for of the housing. With a nut it's not possible and with a key, pretty difficult, I tried a little bit, but abandonned. Will probably leave it..
What to do to bypass the clutch switch? I think I don't need it.
zimi screwed with this post 01-19-2013 at 03:19 PM
zimi is offline   Reply With Quote
Old 01-19-2013, 10:16 PM   #21
bmwktmbill
Traveler
Oddometer: 4,005
Connect the wires together, it should start in any gear.
bill
Bill Shockley
Old 01-22-2013, 09:40 PM   #22
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,015
Send a message via Skype™ to Low594
Just found this thread!
On mine I found it gets harder to find neutral when the oil is getting old, immediately corrected with a change!
The neutral sensor is found behind the front sprocket cover and runs along with 2 oil lines and gets cooked if not routed just right! This can change how the electricity flows. It can permanently bake the strands and make the wire very brittle!
'99 KTM 640 Adventure R
East Bay Weekly Coffee
Support your local creep! CREEPS MC
Low594 is offline   Reply With Quote
Old 01-25-2013, 01:13 AM   #23
Laromonster
Vesperado !
Oddometer: 1,255
Originally Posted by bmwktmbill View Post
Laro,
Reindears, or what.
bill
Nopers, not high at all
I have my intel straight from god himself
Originally Posted by creeper View Post
Hi gang!
As the engine breaks in, the idle speed will increase. You will need to adjust it occasionally as this occurs. it takes about 2000 miles for the engine to completely break-in and the idle to stabilize... or at least mine did.
Like Velocibiker, my personal preference for idle speed is 1500 to 1650 RPM when the engine is at operating temperature. Substantially below 1500 RPM and the auto-decompression mechanism starts to "rattle".
My LC4 is a '03 MisAdventure with a re-jetted and slide-drilled BST40, a "breather" side cover of my own design and a Supertrapp IDS2 with quiet core and 10 discs.
My bike makes 300 HP at the rear wheel and does 5th gear roll-on wheelies
Creeper
Laromo
Old 01-25-2013, 09:38 PM   #24
bmwktmbill
Traveler
Oddometer: 4,005
Laro,
Oh shit, pissed on another bible.
Where the fuck is Creeper?
I'm scared he's gonna show up at my house looking for a sandwich.
If jesus was a biker he'd be riding a KTM.
I don't picture him on a chopper or a KLR.
And what does 'Laro' mean in Norwegian anyway?
http://mymemory.translated.net/t/Nepali/Norwegian/laro
bill
Bill Shockley
Old 03-29-2013, 10:35 AM   #25
zimi OP
Oddometer: 35
The Tuareg Rally is over, the bike survived the 7 days. Just minor problems. I realized that it was too heavy for this kind of rally. When you drop it and have to pick it up 10-20 times a day in sand dunes... it feel really heavy. Most competitors had 450 enduro with big tanks.
Times are GMT -7.   It's 05:42 PM.
