Old 10-05-2012, 11:07 PM   #16
Fictitious
Fictitious's Avatar
Oddometer: 202
You may think it was because there was something stuck on the float valve mating service, but it was actually because whatever engine oil you use is the wrong one.
Stuff, as well as things
Fictitious is offline   Reply With Quote
Old 10-06-2012, 11:16 AM   #17
Skinner
Mr.KTM
Skinner's Avatar
Oddometer: 5,741
Ok then Mr Smarty pants, which oil is best?
You might be an ADVRider if:
You recognize your friends by the sound of their mufflers.
http://www.meetup.com/Chicagoland-Du...torcycle-Club/
www.jimstarwaltteam.com
Skinner is offline   Reply With Quote
Old 10-06-2012, 11:49 AM   #18
ragtoplvr
Oddometer: 6,390
Make sure you do not have floats full of fuel. It is no at all unheard for brass to crack, seems Chinese brass may be brittle. Plastic and foam floats commonly leak..
Rod
ragtoplvr is offline   Reply With Quote
Old 10-06-2012, 12:27 PM   #19
boxermoose
Now fully goosed
boxermoose's Avatar
Oddometer: 2,852
What year EX500?
We had this issue on my kids and replacement float needles fixed it right up (hoses and petcock were all good
I have a carb rebuild lit for the first gen you can have if it is older then a '93 & I can find it
Sometimes you get the ABAT....and sometimes the ABAT gets you
boxermoose is offline   Reply With Quote
Old 10-06-2012, 04:12 PM   #20
victor441
victor441's Avatar
Oddometer: 960
also carry a fire extinguisher until you get it fixed, I had a new to me bike catch fire that way and I was very lucky to be able to put it out with my gloves before I lost it some of the overflow gas was ignited by the alternator wires. FWIW in my case the PO had installed new floats and they were a bit too wide at the pivot, no more overflows after I filed them a bit
victor441 is offline   Reply With Quote
Times are GMT -7.   It's 11:31 AM.
