10-06-2012, 03:27 PM
#16 | |
Oddometer: 1,692
A bit spendy... First is the same, the rest change. They're not for everyone.
Cheers, Numbers 05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800 Founding member Longtails SC |
10-06-2012, 03:54 PM
#17 |
Mutha Mutha
Oddometer: 534
I have 4K on my big bore, no issues.
I expect it will easily do 12K.
"I swear to god that I will beat you senseless with a sanka can before I die" Mr.Grumpy |
10-06-2012, 04:09 PM
#18 |
ride2discover
Oddometer: 3,180
After ur done rebuilding ur engine you'll have a blast. I know many who've done the big bore kit and they're happy with the results, i was gonna do this SUZUKI JE DRZ400 DRZ 400 BIG BORE 434CC CYLINDER KIT just for the heck of it. Keep up the good work focallength.
DR-Z400E 00 - DR650SE 02. Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY". |
10-06-2012, 04:58 PM
#19 |
patty cake champion
Oddometer: 3,403
Im just concerned about the reliability of a BB, I dont want to tear the engine down every 6k miles.
Unregistered destructive device. |
#20 |
OH.THAT'S GONNA HURT
Oddometer: 3,814
might as well do the 434 BB, as it doesn't cost anymore.
2004 BMW R1150RS 1984 BMW R80G/S (wrenching index) 2003 Suzuki DRZ 400S (TAT Prep) One More DRZ does the TAT (Ride Report) |
10-06-2012, 05:16 PM
#21 | |
Oddometer: 1,692
I am not sure how you define a "top and bottom rebuild" I've got about $1000 in the crank, main bearings, piston, cylinder, gaskets, seals etc. That is still cheap when I compare it to my Huskies (bare crank is ~$1200), BMWs or KTM. The head that I have built is worth about $1100 in parts (no core purchase) to initially build and about $200 to rebuild later, but that head is built for a stroker which tends to blow out the top end cost. You could probably get it done for a heck of a lot less with a set of Hotcams and reusing many of the parts that I have discarded.
10-06-2012, 05:23 PM
#22 | |
Oddometer: 1,692
Maybe you have spent too much time listening to the kids on TT.
10-06-2012, 05:42 PM
#23 |
patty cake champion
Oddometer: 3,403
I havent heard any negative on a BB kit, however the very nature reduces longevity. Im slightly concerned with the head bolts. I had a xr600 with a 660 BB kit (10% over bore same as a 400 to 440) and it pulled the head off.
The big suck with my bike is I need a new head, thats $600 for a blank head. Im not reusing any parts from the seized head. By rebuild I mean the kits they sell on line, theyre mostly bearings and gaskets, top end comes with a new piston...I dont think I need to go hog wild on a head, nothing fancy just stock parts aside from cams.
10-07-2012, 06:43 AM
#24 | |
Oddometer: 1,692
The head is bolted through the cylinder to the crankcase...Lifting the head due to the cylinder is improbably. One point in favour of the stock bore is that the OEM piston skirts are longer and wider than the non genuine parts including those for the standard bore and there might be a longevity advantage using an OEM piston. I don't think that there is a problem with using a 94mm bore, but if using the stock bits makes you comfortable then go for it. The S motor only needs cams, carb, compression and exhaust to go from asthmatic to a nice motor. Big bores are optional. BTW, I'd definitely want to check the crank and transmission very carefully because it seems from the cylinder that the damage may not have been limited to just the head.
Cheers, Numbers 05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800 Founding member Longtails SC 955616846 screwed with this post 10-07-2012 at 06:57 AM |
10-07-2012, 08:50 AM
#25 |
Oddometer: 3,815
I would also suggest pulling apart the oil pump and look for wear/scoring. Then replace if necessary.
![]() I rebuilt a blown up Yammie once and the oil pump had sucked some material and was surprised at the noticeable wear on the internal parts.
"Deeply flawed people make deeply flawed decisions." |
10-07-2012, 01:22 PM
#26 | |
GPoET&P
Oddometer: 3,758
I was helping a friend with a DRZ that had a chronic overheating problem. Repeated blown headgaskets, warped head, etc. It turned out that the waterpump impeller had unglued itself from the shaft and would turn on the shaft with only a little resistance. Or, not turn when the bike was running. It looked good, though. Doesn't sound like your problem, but it's easy to check when you're in there. |
10-07-2012, 04:46 PM
#27 |
patty cake champion
Oddometer: 3,403
So im slowly going over the frame as well, looking for damage. I have noticed 3-4 spots where the paint has chipped away revealing some surface rust. Need to take care of that, just need to find a similar color spray paint...
Im srarting to think a yearly engine pull is in order, theres alot of nooks and crannies that harbor dirt/mud. Plus engine mounts need greasing. Pulled the frame drain plug to check the filter, looked clean aside from a lone long hair?! Plan on splitting the case tomorrow and seeing what parts I need to start ordering. Stay tuned...
10-07-2012, 06:43 PM
#28 | |
Oddometer: 955
Tipsy
2008 Buell XB12X Ulysses 2008 KTM 450 EXC-R "There's a plane! Where there's a plane there's probably a pilot! Where there's a pilot there must be a bar! I can finally get a drink!" - Brian from Family Guy |
10-07-2012, 06:52 PM
#29 | |
patty cake champion
Oddometer: 3,403
10-09-2012, 01:13 PM
#30 |
patty cake champion
Oddometer: 3,403
so here is the score so , far. Im waiting for a puller for the fly wheel then Ill split the case. Initial inspection shows some slight play in the rod, which means shes shot. I ordered a complete hot rods lower parts kit, to rebuild the bottom end. The gears arent blue, but I wont know until I can split the case. So far no definitive causes, the cylinder does show signs of previous wear and oil could have slipped passed the rings. The cylinder is nice and flat, but the head is pretty well warped.
Ill have the case honed just in case, so that both parts fit together perfectly. Now the cylinder is salvagable, Ill prob. send it off to cylinder works or millenium and have them hone and replate it. Still not sure if I wabt to go with a BB or not. The head is just a big paper weight, however there are signs of dirt being sucked into the valves, which is not that uncommon with a dirt bike. Just means Ill have to really check my air intake when I re install it. Most likely it happened over time, however I did notice that the FCR-MX carb dosent fit quite so well, so Im going to have to do something about that. Maybe find a airboot from another bike thats a little bit longer. So lower parts kit should be here tomorrow as well as the puller, in addition Ill replace the countershaft bearings. Heres hoping the gears are good. Stay tuned, sorry no pics, nothing new to show... I may pick up a kick starter kit though, should be easy to install with the engine in pieces...
Unregistered destructive device. focallength screwed with this post 10-09-2012 at 01:49 PM |
