Old 10-05-2012, 07:17 PM   #1
Yokomo OP
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,326
1985 Honda XL350R carburetors
I've got some questions about the carbs. Does 1 of them work at all times and the 2nd one kicks in from the mid to top end? Which one works throughout the whole range? The 1 on the left per chance?
Is there a way to tell if the 2nd one is kicking in?
Is there an easy way to richen the idle so it will start easier? I did something easy on my XR250L and it made it kick to life real nice (I just don't remember what I did).
I run Klotz in my weed wacker and chainsaw for the smell
Yokomo is offline   Reply With Quote
Old 10-06-2012, 02:59 AM   #2
Homerb
Oddometer: 462
Thats right, the left carby operates all the time and the right carby kicks in at higher throttle openings.
You can tell by the sound of the exhaust when the second carby opens.
Not sure how to easily richen up the mixture.
Homerb is offline   Reply With Quote
Old 10-06-2012, 03:55 AM   #3
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,994
When you get past half throttle, just like the man before me said, you can hear the engine open up and feel it. atleast so on my XL600
The air mixture screw should be on the bottom of the main (left) carb according to my manual. You shouldn't have to turn it more than 1 and a half times. The 83' XL600 has one on the side.
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust + over sized header
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is offline   Reply With Quote
Old 10-06-2012, 05:40 AM   #4
Yokomo OP
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,326
Thank you.
Does the 2nd open in response to throttle pull or rpm? ie. Is there anything to physically see moving on the 2nd or does it open in response to rpm/then the vacuum lifts?
Yes there's the air/fuel screw on the left of the left carb. It has a tab on it that limits its movement. On my 250 I dremeled off the tab so I could turn it more and richen it up. I think I may have raised the needle using a washer as well. I remember it made it fire right up 1st kick.
Has anyone tried that?
How hard is it to remove the carbs? Do they come out as a unit or seperate?
Old 10-06-2012, 05:50 AM   #5
brucifer
brucifer's Avatar
Oddometer: 2,530
Originally Posted by Yokomo View Post
Thank you.
The second carb opens with linkage--so it's mechanical not vacuum.
I used a washer on my XL600 needle and, yes, it made a difference.
The carbs are kind of a PITA to remove. They come out as a unit.
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-2002 Husky TE570-2001 Husaberg FE650E-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F
brucifer is offline   Reply With Quote
Old 10-06-2012, 05:52 AM   #6
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,994
Thank you.
The second one is operated all mechanically.
You can cut the tab, I recommend it. On my XL600R, Which according to the book is the same as the 350, they come out together. You can seperate them if you need to, but you can do most the work on them together.
Video from Drayshop on youtube.com for XL600r carb maintenance. Worth the 9 mins watching!
https://www.youtube.com/watch?v=lOCD...9&feature=plcp
Old 10-06-2012, 05:55 AM   #7
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,994
Damn beat me to it by two minutes
Old 10-06-2012, 06:28 AM   #8
Yokomo OP
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,326
Nice video. But I see some differences. The fuel mix screw that is already dremeled in the vid, I don't have. Mine has a horizontal screw on the left side of the carb (which is not on the 600 carb). So I'm wondering if mine has an air screw instead of a fuel screw?
Now that I see the vid I recall my 250 had a weird way to get the needle out. I bet the 600 and 350 are the same. Something about a spring and removing a screw inside the carb? I'm thinking there's a vid on this as well? Anyone know?
Thanks for the quick responses!
Old 10-06-2012, 05:37 PM   #9
Yokomo OP
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,326
Anyone?
Old 10-08-2012, 05:29 AM   #10
Yokomo OP
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,326
Anyone?
All thread are better with pichers.
Old 10-08-2012, 05:50 AM   #11
brucifer
brucifer's Avatar
Oddometer: 2,530
Here's an exploded diagram of your carbs. Number 15 is what you're concerned with.
http://www.bikebandit.com/houseofmot...9697#sch405906
Regarding your mixture screw, in my experience if it is towards the back of the carb it's an air screw, towards the front it's fuel.
Old 10-08-2012, 05:56 AM   #12
motomike14
Thumper Crusader
motomike14's Avatar
Oddometer: 1,762
Behind float bowl (towards the rear) = air screw.
In front of float bowl (towards cylinder) = fuel screw.
You should have an air screw.
"The bold adventurer succeeds the best. - Ovid
I drink the koolaid too...just not the orange kind.
motomike14 is offline   Reply With Quote
Old 10-08-2012, 05:36 PM   #13
Yokomo OP
Gorilla Adventurer
Yokomo's Avatar
Oddometer: 2,326
Are you sure it's not #7? That looks more like the airscrew. (I could be wrong)
Old 10-08-2012, 06:21 PM   #14
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 9,321
That's the nicest 350 I've seen; a classic for sure.
High Country Herb is offline   Reply With Quote
Old 10-08-2012, 06:36 PM   #15
motomike14
Thumper Crusader
motomike14's Avatar
Oddometer: 1,762
Anyway you can take a photo of the left side carb? I tried to look online, but couldn't tell.
Times are GMT -7.   It's 10:27 PM.
