09-19-2012, 12:02 PM
#1 |
Zen Cowboy
Oddometer: 4
I just took a minor hit to my very expensive SW Motech skid plate while riding on a Forest Service Road. I ride a 650 V-Strom and installed the plate to protect my vulnerables from errant rocks etc. The very first impact and I have broken rivets!!!! What a poor design. The SW Motech reply to the damage and I quote " it protected your engine didn't it?" I said, "but now your product is a worthless piece of aluminum". "Sorry, it did as it was designed to do, it protected your motor, any impact voids your warranty" What a load. So if you are considering this Farkle consider this: it is a nice looking product, that is not designed to take any impacts, should never be taken off road, doesn't fit well with Givi crash bars, has a hokey adapter plate for the bars, and has zero manufacturer support if it fails. Be advised that SW Motech does not stand behind this product, nor does the retailer that I will not name. Any suggestions for a bash plate that actually can take a hit on keep on ticking?
09-19-2012, 12:23 PM
#2 |
Oddometer: 1,249
If you just busted a rivit you can re-rivit or bolt it back together.
Lame-YES: but it did protect your engine didn't it
94 DR 350 SE |
09-19-2012, 12:29 PM
#3 |
generally strange
Oddometer: 410
try this
If you're thinking about it your just trying to justify it to yourself. |
09-19-2012, 01:38 PM
#4 |
Doesn't Care
Oddometer: 1,516
What sort of impact? Did you try to jump a curb or something?
--Semantics are everything. |
09-19-2012, 02:48 PM
#5 |
Anatomically Correct
Oddometer: 2,493
not trying to slag anyone, but I can't imagine a riveted bash plate -- clearly, there IS such an animal, but I'm not sure I'd install it (or buy it if I knew) . . . .
Searching for the immaculate contraption |
09-19-2012, 03:11 PM
#6 |
Oddometer: 151
I have the same one on my wee. I agree, it's a total POS.
09-19-2012, 03:32 PM
#7 |
Just me.
Oddometer: 3,385
Rivets? Seriously?
It's too bad Pat Walsh doesn't make a skid plate for the DL. The PWD skid plate on my DR650 is a built like a friggin' brick outhouse. Thick aluminum, solid welds, large fasteners. Maybe start pestering PWD to have them make one for the DL.....? (not meant as spam, no affiliation)
This space for rent. |
09-19-2012, 06:09 PM
#8 |
The Flying Mythos
Oddometer: 980
The Motech plate for the Tiger 800's is also riveted, but I think the rivets are probably stronger than Triumph's lame-o mounting points. If you can't weld aluminum, most fab/welding shops will do it for you for a nominal fee.
"I tried to move my mind there and nowhere else and imagine a single detail that, if I didn't see it that weekend, I never would... The world is easily lost." James Dickey |
09-19-2012, 06:13 PM
#9 |
Oddometer: 6,431
So quit bitchin and fix it, bolt, rivet or weld it. Add character.
You know, a long time ago being crazy meant something. Nowadays everybody's crazy IBA 22425 |
09-19-2012, 07:13 PM
#10 |
Zen Cowboy
Oddometer: 4
More on the SW Motech skid plate
Thanks for the responses. To be clear, I hit a rock, the type that goes clank on the skid plate, not crunch like a big crash. I was going about 5mph on an uphill. If I rode like crazy man in the dirt, I wouldn't be on Strom. I don't have a big dent or anything on the plate, just a scuff. As to re riveting or bolting it, why bother. I would consider welding it but I really have no confidence in the product, and I never have liked the way it mounted on Givi bars. Looks like something a high school kid made up in welding shop. I will toss it in with the recycling next week and look for something that does what a skid plate is supposed to do, protect the engine and stay in one piece. As to bitchin about something that breaks so easily, I guess I'm spoiled, I ride a V-Strom, it doesn't fail when used properly.
09-19-2012, 07:42 PM
#11 |
Where fun goes to die....
Oddometer: 3,149
I have the Pat Walsh skid plate crash bar combo. Side impact tested on the freeway @ 45 mph by a hit and run driver.
Bike went down hard. Plate stood up to it and broke but it was a big hit. My new strom has the same things. Luv em cause you can also lift the bike via the skid plate with a jack. Just my .02
DSM8 - A different kind of mean SQL > SELECT finger FROM hand WHERE id=3 WWW.DSM8.whereamiriding.com |
09-19-2012, 07:43 PM
#12 |
Oddometer: 1,035
That sucks, I never knew any skid plates were riveted. I never liked any of their products and always thought they were 2nd or 3rd tier. Too bad Black Dog doesn't make Strom skid plates. I would look into that Enduroguardian plate. I hate buying expensive stuff, but if I only have to buy it once, then I'll be happy. I can see them saying it was sacrificial if you hit a big boulder, but not fire road stones.
09-19-2012, 08:55 PM
#13 |
Oddometer: 344
Can we see some pics? Theoretically speaking, a riveted construction could be just as strong (or stronger) than a welded piece.
09-19-2012, 10:30 PM
#14 |
Vagabond
Oddometer: 1,447
You acknowledge it was cheese, but installed and used it with an expectation it would perform as something better? You knew it was riveted, right?
Your engine/lower parts were spared damage. And now you're angry with the retailer. Wow. |
09-20-2012, 04:29 AM
#15 |
World Wide Inmate
Oddometer: 2,118
Like front and rear collision impact on a car, the actual collapsing of the materials is what takes up the energy. "Heavy metal" not always the answer. Like making issue with a foam filled car bumper after it just saved your life... "jeez, look at my bumper, it's wrecked now"......
![]() Fooey on the Strom for running exhaust and a oil filter right out there where it's likely to get smacked, I say. Great bike, but who thunk that stuff up..... if we are making issues with design flaws?
´¯`·.¸¸.·´¯`·.¸ ><((((((º> `·.¸¸.·´¯`·.¸¸.·´¯`·.¸ ><((((º> ´¯`·.¸¸.·´¯`·.¸¸.·´¯`·.¸ ><((((((º> Everything happens for a reason. "Still seeking the reason" |
