Old 10-03-2012, 02:19 PM   #1
mrbreeze OP
mrbreeze's Avatar
Oddometer: 9,057
liquid cooled boxer!
it's a reality!
http://www.cycleworld.com/2012/10/02/intermot-2012/
2013 Suzuki DL650 Adventure
Travels with Maw Maw
mrbreeze is offline   Reply With Quote
Old 10-03-2012, 02:39 PM   #2
unlucky1
unlucky1's Avatar
Oddometer: 276
Interesting intake/exhaust port relocation. Icing on the intake probably isn't as big a big deal on these guys as it was on prop driven aircraft, eh?
2008 XB12X
What do you call a group of Buells? A failure.
unlucky1 is offline   Reply With Quote
Old 10-03-2012, 05:59 PM   #3
ttpete
Rectum Non Bustibus
Oddometer: 6,145
You don't get icing on injected engines because the fuel is injected into the port below the throttle body, and there's no venturi in the way.
2015 BMW R9T, 2010 Ducati 1098 Streetfighter S
2009 Kaw 650 Versys, 1967 Triumph 650 TT Special
Old 10-04-2012, 09:05 AM   #4
squish
Out of the office.
Oddometer: 6,407
I just love that BMW fell into the trap the metric water cooled cruisers have.
Fake fins. Nice touch.
The relocated intake will be nice to those who need more leg and shin room.
On vacation for a spell
squish is offline   Reply With Quote
Old 10-04-2012, 09:31 AM   #5
Railbender
Oddometer: 1,048
Somewhere in the countless threads on this bike I read that only the heads are water cooled, the cylinders are air cooled so the fins are functional.
The shortest distance between two points is boring.
Railbender is offline   Reply With Quote
Old 10-04-2012, 09:53 AM   #6
squish
Out of the office.
Oddometer: 6,407
Yea functional in that there is some heat exchange but the real meat of cooling happens around where the real meat of the heat is produced, the head. if you look at the photos it shows fin up to the valve covers.
Old 10-04-2012, 10:59 AM   #7
Emperor Norton
Kilroy was here
Emperor Norton's Avatar
Oddometer: 1,245
205 ad infinitum, belongs in GSpot etc..
Pics of whatever/where ever http://joee.smugmug.com
I used to be indecisive, now I'm not so sure.
Emperor Norton is offline   Reply With Quote
Old 10-05-2012, 09:01 AM   #8
Detroit Steve
Homely Adventurer
Detroit Steve's Avatar
Oddometer: 514
Thumb Road Warrior Content
The styling department is going to work awful hard on making a good looking Roadster out of that motor with the throttle bodies on top of the barrels and two radiators to hide.
My Stuff for sale: http://bmwsteve.smugmug.com/Other/For-Sale/i-SRK3jDN
Detroit Steve is offline   Reply With Quote
Old 10-05-2012, 02:53 PM   #9
Offblnz
Offblnz's Avatar
Oddometer: 2,469
It's not called "fake fins", it's called "Heritage"!
Offblnz is offline   Reply With Quote
Old 10-05-2012, 03:11 PM   #10
GB
Mod Squad
GB's Avatar
Oddometer: 57,100
The fins are still used for cooling.. the liquid cooling, according to BMW, provides only 35% of the cooling.. So it still is air / oil cooled as well.
Old 10-11-2012, 10:05 PM   #11
Carter Pewterschmidt
Carter Pewterschmidt's Avatar
Oddometer: 1,105
The real headline of this motor should be the integrated gearbox and the wet clutch. The best thing BMW could to to a motor is make less places to leak from lol.
Carter Pewterschmidt is offline   Reply With Quote
Old 10-11-2012, 11:32 PM   #12
Tosh Togo
Oddometer: 1,594
Au contraire...
Think about it... it's not the fuel that freezes in the intake tract; it's moisture that's already present in the air. If the humidity is high enough, and the OAT is low enough, the added evaporation from pressure drop can sometimes drop the air below freezing as it heads toward the intake valve(s).
Where the fuel is added to the airflow has zero effect on "carb" icing, and the throttle plate creates a lot of vacuum downstream unless it's WFO. .
Tosh Togo is offline   Reply With Quote
Old 10-12-2012, 05:53 AM   #13
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,408
You mean like the oil coolers on an R1100/1150/1200R?
I don't think that will be an issue.
Jim
Old 10-12-2012, 08:39 AM   #14
DiabloADV
Semi-Occasional
Oddometer: 2,336
Fins (and the rest of the engine case) provide over half the cooling on this motor. Water only cools the top of the combustion chamber, around the heads and valves. Keeps the water system small and light.
So anyway...the fins quite functional and necessary.
1974 R90/6 motor w/1050 kit; twin plugged; installed in...1970 R60/5 frame; RM125 front end; KZ1000 Police Tank.
DiabloADV is offline   Reply With Quote
Old 10-12-2012, 08:44 AM   #15
DiabloADV
Semi-Occasional
Oddometer: 2,336
+1
THAT is the really big news here...finally joining the "unit construction" modern age. No more car clutch in a motorcycle. One oil fill, slipper clutch, quieter, smoother, lighter...best boxer motor refinement since the oil cooler. Eases the engine cooling requirement, too. Smaller water system is a nice byproduct...
And...now they are set up to drop a CVT (or electro-mechanical) in there and offer paddle shifting/automatic. For their target audience, that will be a big seller.
Times are GMT -7.   It's 11:24 PM.
