Old 10-06-2012, 11:16 AM   #1
ronandkat OP
Oddometer: 154
71 sl70
Im restoring an sl70, and other than an electrical problem some great folks on here helped with it has went pretty smoothly. My only issues is this, I plan finishing it n order to sell for profit, and it currently smokes a little.
When I first got it, it did not smoke, however I took the top end off to inspect anyway. While in ther I put in a new OEM honda pistin, rings and clip.. On the stock bore with a new hone job done by a locak shop here.
Currently it smokes. not horribly, and I only have about 25 minutes run time on it overall, which included a small test ride through the gears, and alot of idle time trying to get the headlight working. I have read many places that sometimes until the rings seat, it may smoke. Other places I have read said it should not smoke period.
I have rebuilt few 2-strokes in my day, and of course, hard to tell with them. This is my first 4 stroke, It purs like a kitten and starts fist kick even after sitting for 3 weeks at a time. General consensus?
ronandkat is offline   Reply With Quote
Old 10-06-2012, 12:54 PM   #2
Skowinski
Primate
Skowinski's Avatar
Oddometer: 6,065
My brother had one just like that, same year and color. Brings back memories.
Did you check the piston - bore clearance when you put the new piston in? Ring gaps set correctly?
"The atoms or elementary particles themselves are not real; they form a world of potentialities or possibilities rather than one of things or facts."
- Werner Heisenburg
Skowinski is offline   Reply With Quote
Old 10-06-2012, 08:31 PM   #3
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,699
Cute lil thing, as for the smoke.... how much oil or what did you use as a rebuild lube on the piston?
Maybe the rings are not seated yet too.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 10-07-2012, 08:06 AM   #4
AtLarge
AtLarge's Avatar
Oddometer: 125
Sharp bike!
1973 CL70-K3
1983 KZ750-K1
2008 GSX1300-BKK8 #1120
Cardo Scala rider G4 PowerSet
AtLarge is offline   Reply With Quote
Times are GMT -7.   It's 07:01 PM.
