Old 10-09-2012, 07:30 PM   #1
Midlife OP
HalFassed
Midlife's Avatar
Oddometer: 69
One more easy one for the 12v Gurus
Had a fun farkling day over the weekend.....new rigid lights, heated grips and fuze blocks....nice setup.
Here's my simpleton question: I wired the lights through the 3 pole switch that came with the harness to the fuze blocs box. I put it on the flat above the gauges on my 990a. Nice because it has an LED that indicates "on". Downside is its not on the bars for easy access (too big). Picked up a nice waterproof small switch...two pole push button . Can I somehow wire it as a remote switch....using the other for a master?
Thanks Much!
Steve
STILL fun after all these years! Thanks GOD!
2008 KTM 990 Adventure, and a bunch of dream bikes in my head.
Midlife is offline   Reply With Quote
Old 10-09-2012, 07:59 PM   #2
EOD3MC
What will break next
EOD3MC's Avatar
Oddometer: 4,719
If your 2-pole push button is simply a make/brake switch, wiring it in series with the power lead should work I would think, but you would need to pay attention to the amperage ratings.
EOD3MC is offline   Reply With Quote
Old 10-10-2012, 08:49 AM   #3
Midlife OP
HalFassed
Midlife's Avatar
Oddometer: 69
Thanks - good solution!
Thanks for the confirmation - I will use the switch (trail tech - rated for 10 amps) to interrupt the 12V supply (or maybe ground for an "immediate" cut off) just before the fuzeblocks. Tested it on the 12v side - works great - now I have an "indicator" on the original LED switch - as well as a master power switch, and this little pushbutton near my left thumb for a remote switch)
For anyone else who may need small waterproof switch - the trailtech unit installs with a 3/8 inch hole - very small enclosed box - cool unit....7 bucks. (and for the D.O.G's....Andrew at ACME Rider Supply carries them)
http://www.trailtech.net/040-LS-B.html
Times are GMT -7.   It's 05:59 PM.
