Old 10-07-2012, 09:04 AM   #1
indr OP
Oddometer: 501
Wire gauge from battery
indr screwed with this post 02-22-2015 at 11:43 PM
indr is offline   Reply With Quote
Old 10-07-2012, 10:13 AM   #2
the_gr8t_waldo
Oddometer: 2,107
depends on what it's going to feed
the_gr8t_waldo is offline   Reply With Quote
Old 10-07-2012, 10:24 AM   #3
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,611
Don't know the specific size for your battery/starter size. Not all that standard, my old GS sure has much bigger cables than smaller Japanese bikes.
12V you can always go bigger, won't hurt a thing. Did that on my other BMW, premade cables are cheap at Wal-Mart,or I should say much cheaper than buying cable by the foot somewhere and you can get the right size eye connectors at Battery Direct, then just a matter of soldering them on the cables.
Sears may even still have their small jumper cables in the cheap tools bin, they were about $10.00 and 7(?) feet long, again much cheaper than buying cable by the foot somewhere and you get red and black.
Have tools, will travel!
Old 10-07-2012, 11:05 AM   #4
herrhelmet
A Serious Man
herrhelmet's Avatar
Oddometer: 2,364
Originally Posted by indr View Post
Trying to redo the whole wiring on bike. Standard 12volt motorcycle battery. What should the gauge of the wire connected to the leads of the battery be?
Should be 6 AWG
"Your bike is too heavy" www.motolithium.com TWITTER
herrhelmet is offline   Reply With Quote
Old 10-08-2012, 04:30 PM   #5
bwringer
Gimpy, Yet Alacritous
bwringer's Avatar
Oddometer: 2,187
On old Suzukis, the stock battery cable size seems to be somewhere between 6 and 8 AWG.
When necessary, I make new cables with 6 AWG wire. When I bought the crimper, wire, and lugs, the gent at the electrical supply shoppe commented that he sells to a lot of custom builders who use the same.
1983 Suzuki GS850G, Cosmic Blue
2002 Suzuki Vstrom DL1000, Midnight Blue
2005 Kawasaki KLR685 - Turd II.2, The ReReTurdening
"Do not crinkle your food wrappers loudly. Be considerate to others, or I will bite your torso and give you a disease."
bwringer is offline   Reply With Quote
Old 10-10-2012, 10:00 PM   #6
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,295
All of my Suzukis have used 8g from the battery to the starter relay to the starter,and also for the negative to engine case ground.The rest of the wiring is 14g-16g.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 10-10-2012, 11:25 PM   #7
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,540
I used 4 gauge on my Airhead when I recently did a complete rewire. It's what http://www.euromotoelectrics.com/EME-Battery-s/79.htm uses in their battery cable kits (I didn't use one of their kits, though). It's a pain to work with, but my starter is happier than ever.
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is offline   Reply With Quote
Old 10-11-2012, 05:35 AM   #8
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,295
Increasing wire size would probably help over the long haul seeing how larger wire can flow more electrons.It just makes for a little more bulk in the harness.Plus it's stiffer also and helps keep vibration from breaking connections.
Old 10-11-2012, 06:21 AM   #9
ScEd
Dances with Deer
ScEd's Avatar
Oddometer: 284
8-Gauge welding leed cable works well. Will pass as much current as 6ga standard wire and is very flexible. Some welding supply houses will sell this by the foot.
Always aim where you want it to go and never at people (DakarNick)
ScEd is offline   Reply With Quote
Old 10-13-2012, 04:05 PM   #10
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,521
Thats what I was going to recommend. Tractor Supply sells it in bulk by the foot. McMasterCarr.com?
scooteraug02 is offline   Reply With Quote
Old 10-13-2012, 04:06 PM   #11
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,692
McMaster will also sell the lugs and crimping tool
Twilight Error is offline   Reply With Quote
Old 10-13-2012, 06:18 PM   #12
Mad_Jack
Oddometer: 26
Stiffer may be better for you but flexible is the way I want to go (I use braided strap for ground when I can find an appropriate gauge). Flexible absorbs the vibration but stiff works battery bolts loose, loosens connections and causes shorts. 'Course, my Wide Glide eats batteries for breakfast.
As for what gauge to use, I want 4 gauge or heavier from battery to starter and for the ground strap. Even then the ground strap can get uncomfortably warm if it takes more than about 4 revolutions to start (and it takes 3 for the electronic ignition to fire).
You can probably get by with less; Harley starters want lots of amperage.
I'm an ex-citizen of nowhere...and sometimes I get mighty homesick.
Mad_Jack is offline   Reply With Quote
Old 10-16-2012, 06:52 AM   #13
cat
cat's Avatar
Oddometer: 1,323
Get good flexible cable, like good welding cable, it's much more flexible than that old-fashioned braided stuff. good lord, that stuff is from cars of 40-50 years ago.
cat is offline   Reply With Quote
Old 10-16-2012, 07:11 AM   #14
Stphnw8
Oddometer: 3
Cables are thicker on European bikes/ vehicles and most have a larger cca battery ( cold cranking amps) this is because it's colder over there and it takes more amps to turn an engine over when cold.
Stphnw8 is offline   Reply With Quote
Old 10-16-2012, 12:23 PM   #15
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 12,166
Er, you HAVE spent a winter North of St. Louis, yes?
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Times are GMT -7.   It's 01:39 AM.
