Old 03-08-2010, 06:19 PM   #1
bigtrailie OP
Rough idle
bigtrailie's Avatar
Oddometer: 703
Clarke oversize tank repair
I got ripped off on Flea-bay. When the fuel tank arrived I was more concerned about how it would fit on the KTM 520 exc than with the general condition of the tank itself.
Once I removed the filler cap, I noticed the grey RTV sealant around the base of the filler neck. I filled the tank with water and my fears were confirmed -- the "patch" is not watertight. After removing the sealant, I can now see a crack (void) that goes about half way around the circumference of the filler neck.
Has anyone found a fix for patching up these plastic tanks? I'm guessing that RTV sealant is not the way to go. Anyone out there with successful epoxy experience???
Need my knees in the breeze through the trees.
'04 KTM 950 ADVENTURE (black) - '05 Honda XR650R (plated) - '97 Honda XR600R (plated) - '99 Honda Valkyrie Interstate (joy rides with my wife and kids)
bigtrailie is online now   Reply With Quote
Old 03-08-2010, 06:37 PM   #2
Motomedic
Motomedic's Avatar
Oddometer: 2,510
plastic welding is probably a better solution...
Feike
I don't have to agree with you to like you or respect you. -Anthony Bourdain
Motomedic is offline   Reply With Quote
Old 03-08-2010, 09:12 PM   #3
ColoradoKen
Orange Cult Convert
ColoradoKen's Avatar
Oddometer: 114
+1 re. plastic welding
If it's fixable ... welding is absolutely the way go. That class of plastic typically doesn't "glue" easily/well (or at all ??) and the location at the filler neck doesn't help matters.
Hope you can repair it without too much expense. Don't know what to expect re. cost to plastic weld it ?
.Penton 250 Honda SL70~XL350~XR250~CR500~CBR1100XX Yamaha DT175~Seca 550 & 750~WR400~TDM850 Suzuki GS750~RM250~WeeStrom 650 Kawasaki KLR650~KLX300~KLX250S BMW R80~GS1150 KTM 525EXC~1190ADV
ColoradoKen is offline   Reply With Quote
Old 03-09-2010, 01:25 AM   #4
Beezer
Oddometer: 5,946
Yep, plastic weld. A good auto paint store might be helpful... they generally sell the equipment, or at least the various filler rods. If that doesn't work there might be another way, but it won't look pretty. RTV will not withstand constant contact with fuel, but this stuff will.
Aircraft fuel tank sealer by DeSoto... the 1/2 is the working time (1/2 hour).
PRC 1422B 1/2
Or ProSeal...
http://www.aircraftspruce.com/catalo...prosealant.php
edit... Another thought - you might contact the RV dealers, RVs have plastic water & waste tanks that are always gettin hit, they might advise on a reliable repair shop
Beezer screwed with this post 03-09-2010 at 01:31 AM
Beezer is offline   Reply With Quote
Old 03-09-2010, 05:27 AM   #5
saddlsor
my butt hurts
saddlsor's Avatar
Oddometer: 334
I have a place on my clarke tank that I used jb weld to seal. its been on there for 4 years now. I used some 50 grit sandpaper to roughen it up to help it stick. its a cheap repair and if it doesn't work you can always try something else.
saddlsor is offline   Reply With Quote
Old 03-09-2010, 06:26 AM   #6
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,567
Have you seen this thread:
Repairing cracked or punctured PLASTIC fuel tanks
Contact Ebay for a resolution. Paypal has protection and Ebay has tools to resolve the issue. Most good ebayers disclose defects.
scooteraug02 is offline   Reply With Quote
Old 03-09-2010, 06:43 AM   #7
The Dirty One
Oddometer: 124
definitely the best option here. that type plastic can be welded without filler rod if all the pieces are still there and it sounds like yours are,just cracked.
ps
you can use a heat gun and a regular soldering irion in most cases to do this.
The Dirty One is offline   Reply With Quote
Old 07-16-2012, 01:02 PM   #8
junglemototours
trailplug
Oddometer: 1,645
Do you have to take the gas out?
junglemototours is offline   Reply With Quote
Old 08-16-2012, 04:26 PM   #9
junglemototours
trailplug
Oddometer: 1,645
Old 08-17-2012, 12:40 PM   #10
Lesharoturbo
Nerdly Adventurer
Lesharoturbo's Avatar
Oddometer: 1,208
Yes. I would take the gas out. A heat gun or soldering iron work at temperatures of 400F and up. Some of the hot air welders we have at work will generate heat >1000F. If nothing else, this will cause the gas to vaporize and increase the pressure at the weld point. Drain the gas and leave the cap off while welding.
Individuality is best expressed individually; you are conforming in your non-conformity.
Lesharoturbo is offline   Reply With Quote
Old 08-17-2012, 02:08 PM   #11
lifer
Oddometer: 200
I had a leak in my skid loaders fuel tank about 10 years ago. It is plastic also. I went to an auto parts store and they had a plastic fuel tank repair kit. I used it and it has not leaked since. I will say the leaks were from the bolts rubbing on the tank so the holes were not real large but it worked like a charm. Personally I would open a dispute with ebay to get the guy to give back your money if it were me. You will probably have to pay to have the tank shipped back to him though.
lifer is offline   Reply With Quote
Old 08-17-2012, 02:20 PM   #12
mcma111
mcma111's Avatar
Oddometer: 12,920
Wake up guys. This thread is from March, 2010.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 08-17-2012, 03:15 PM   #13
baloneyskin daddy
bikaholic
Oddometer: 2,176
What year is it now?
baloneyskin daddy is offline   Reply With Quote
Old 08-17-2012, 06:57 PM   #14
Lesharoturbo
Nerdly Adventurer
Oddometer: 1,208
Yeah, but the guy with a branch in his tank is from 2012. That is more recent....
Old 08-21-2012, 10:00 AM   #15
junglemototours
trailplug
Oddometer: 1,645
It was a joke....taking the gas out, not the trail plug.
Enduroshack and Clarke both stepped up and gave me a new tank, all good. Now if I can just quit putting holes in my bikes.
Times are GMT -7.   It's 08:47 PM.
