Old 10-07-2012, 05:45 PM   #1
indr OP
Oddometer: 501
Flasher Relay
indr screwed with this post 02-24-2015 at 12:26 PM
indr is offline   Reply With Quote
Old 10-07-2012, 06:42 PM   #2
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,754
If the blinkers are led and the flasher unit is not designed they wont flash because the led doesnt draw enough amp to trigger the flasher
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 10-07-2012, 09:28 PM   #3
buickid
Lets ride!
Oddometer: 310
If its a regular flasher relay, it needs the correct load to blink as designed, one bulb probably isn't enough. Thats why you'll see people with blinkers blinking really fast or not at all - one of the bulbs is cut.
2005 Yamaha Zuma YW50, 2009 Kawasaki Super Sherpa KL250
buickid is offline   Reply With Quote
Old 10-08-2012, 04:34 AM   #4
Grinnin
Forever N00b
Oddometer: 2,894
What he said.
A "regular" flasher has a contact that bends when it heats up. When it turns on, it needs enough current flowing through it to heat it enough to cause it to bend. After it bends and turns off the lights, it cools and springs back to turn the lights on again. If the rest of the circuit (the signals themselves) don't use enough current to cause the flasher spring to heat up, then it remains on all the time.
"The belief that there is only one truth, and that oneself is in possession of it, is the root of all evil in the world."-- Max Born, Nobel Physicist
Grinnin is offline   Reply With Quote
Times are GMT -7.   It's 05:36 PM.
