Old 10-08-2012, 02:41 PM   #1
indr OP
Oddometer: 501
Starter Solenoid
indr screwed with this post 02-24-2015 at 12:16 PM
indr is offline   Reply With Quote
Old 10-08-2012, 03:15 PM   #2
emti
Oddometer: 271
30 amps is not a lot for a starter if you think about a battery with at least a couple hundred cold cranking amps, it must be to protect the solenoid? That seems a lot to trigger the solenoid tho? Whats the starter to? emti
emti is offline   Reply With Quote
Old 10-08-2012, 03:44 PM   #3
bwringer
Gimpy, Yet Alacritous
bwringer's Avatar
Oddometer: 2,234
The fuse is for the rest of the bike's electrics. The bike's starter can pull a couple hundred amps, so there's no fuse for the starter motor.
There's a connection (big wire, sometimes red) directly to the solenoid from the positive terminal of the battery. No fuse.
On some bikes, like yours, the rest of the electrics are fed from this connection on the solenoid, and for the sake of compactness and convenience the fuse and the connection to the rest of the electrical system are housed in the solenoid. On other bikes, the fuse is somewhere else.
You may want to spend some quality time pondering your bike's wiring diagram.
You may also want to update your signature with the year, make and model of your bike.
1983 Suzuki GS850G, Cosmic Blue
2002 Suzuki Vstrom DL1000, Midnight Blue
2005 Kawasaki KLR685 - Turd II.2, The ReReTurdening
"Do not crinkle your food wrappers loudly. Be considerate to others, or I will bite your torso and give you a disease."
bwringer is offline   Reply With Quote
Old 10-09-2012, 05:35 AM   #4
JensEskildsen
Oddometer: 1,064
Bwringer is correct, its exactly like that on my '03 xt600e, however, I think the stock fuse is around 20a
2003 xt600e 155.000km
1986 xt350 100.000km (now sold)
JensEskildsen is offline   Reply With Quote
Old 10-09-2012, 08:20 AM   #5
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,764
The above gentlemen are correct, the 30 amp fuse is the main fuse for the bike and most likely feeds the other fuses for lights, turn signals etc.
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Times are GMT -7.   It's 04:38 AM.
