Old 10-08-2012, 11:57 AM   #1
indr OP
Oddometer: 501
Fuse Boxes vs Inline Fuse Holders
indr screwed with this post 02-24-2015 at 12:16 PM
indr is offline   Reply With Quote
Old 10-08-2012, 12:10 PM   #2
cat
cat's Avatar
Oddometer: 1,323
The first problem with using those auto parts stores fuse holders is you have join to them with splices or solder and heatshrink - not good. Check easternbeaver.com - he has some decent ones that don't come with wires sealed in.
cat is offline   Reply With Quote
Old 10-10-2012, 01:06 PM   #3
sledgegreen
Oddometer: 12
Somehow you have to supply power to each of those individual in line fuses. Are you going to run a separate wire for each to the battery +ve? You will end up with a mess of wires.
The same is true for lots of cheaper auxillary fuse boxes, which have a separate terminal at each side of each fuse. I prefer to use a fuse box which has a single feed connection which supplies all the fuses - it gives a much tidier result.
sledgegreen is offline   Reply With Quote
Times are GMT -7.   It's 08:51 AM.
