Old 09-17-2012, 04:50 PM   #1
tam162 OP
Two wheel Terry
Oddometer: 20
R1150GS Pannier /Top Box Compatibilitya
I'm looking to replace my system luggage with either Jessee Odyssey or Happy Trails panniers on my 2002 R1150GS. I would like to also use my factory BMW top box. This is the model with a built in passenger backrest which is a little over 18" wide in the front. Am wondering if anyone has used a similar set up and if the pannier lids clear the top box.
tam162 is offline   Reply With Quote
Old 09-17-2012, 04:57 PM   #2
(none)
poser
(none)'s Avatar
Oddometer: 2,613
of course it will work. Here is my setup.
Current:
R1150GS
GN400
LC80
JK Rubi
(none) is offline   Reply With Quote
Old 09-17-2012, 06:59 PM   #3
tam162 OP
Two wheel Terry
Oddometer: 20
My question is answered
Cool!, Thanks.
Old 09-18-2012, 06:48 AM   #4
manfromthestix
Lost in Space
manfromthestix's Avatar
Oddometer: 2,193
Micatech panniers/side cases open to the side, so you don't even have to remove all the crap you have strapped to the top of the bike, or worry about the lids hitting the topcase.
Just a thought.
Doug
"If it doesn't blow smoke and make noise, it isn't a sport!" - radio ad for shop in Bozeman, MT
manfromthestix is offline   Reply With Quote
Old 09-18-2012, 07:20 AM   #5
(none)
poser
(none)'s Avatar
Oddometer: 2,613
Originally Posted by tam162 View Post
Cool!, Thanks.
NP, i enjoy my BMW top box as well. Been toying with replacing it, but it works great.
Current:
R1150GS
GN400
LC80
JK Rubi
Old 09-18-2012, 02:51 PM   #6
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,133
My new Happy Trails (9" Tetons) don't work with the BMW TOP Box unfortunately. Can't open the lids with the box on. This is with the boxes in their stock mounting position for the factory.
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is offline   Reply With Quote
Old 10-12-2012, 09:35 PM   #7
BobLoblaw
Comfortably Numb
BobLoblaw's Avatar
Oddometer: 1,507
Those look like Odyssey 1's. I think the lid shape has changed and the latest version may not work with the systems topcase?
Scott PDX Are the 9 inch Teton lids removeable if you remove the lid hinge screws and lift them off?
Ride till you can't - Marty Hill
BobLoblaw is offline   Reply With Quote
Old 10-13-2012, 11:00 PM   #8
tam162 OP
Two wheel Terry
Oddometer: 20
Finished Product
Ok, I finished the install on my Jesse Odyssey ll luggage system today. The right side opens and clears the factory rear top box with no problem. The exhaust side pannier has to be mounted all the way forward for the lid to clear the top box. The problem here is that I ride with my wife on the back and when the box is all the way forward she does not have much leg room. Were heading out next month to Central America and she will be putting a lot of hours in the saddle. I could use some spacers on the mounts and maybe gain 1" rearward but probably will set the pannier back and remove the top box when I need access to the pannier.
Old 10-14-2012, 03:24 AM   #9
AUSSIEADV
AUSSIEADV's Avatar
Oddometer: 265
The hinge and bushings on the Happy Trails lids can be removed in short time and access can be made with virtually any top box.
AUSSIEADV is offline   Reply With Quote
Times are GMT -7.   It's 01:49 PM.
