Old 10-09-2012, 05:53 PM   #1
kmasa OP
kmasa's Avatar
Oddometer: 3
Wink Mistake?
I was told by my local shop that I can use 75W90 for both my transmission & final drive fluid change...so I did both today. The fluid drained from both the tranny / final drive appeared to have the same color & very similar visicosity as the 75W90. Or, should I go ahead and re-do the final drive?
kmasa is offline   Reply With Quote
Old 10-09-2012, 06:17 PM   #2
smoky
smoky's Avatar
Oddometer: 313
What kinda bike?
I use the same stuff in both places in my R1200RT.
smoky is offline   Reply With Quote
Old 10-10-2012, 03:33 PM   #3
kmasa OP
kmasa's Avatar
Oddometer: 3
2005 R1200GS - almsot 10k miles - I found some write-ups about it but, NOTHING conclusive. I assume either one works fine as long as different oil viscosity doesn't have an adverse affect.
Old 10-10-2012, 08:54 PM   #4
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,626
There is a lengthy in depth discussion on this in the BMW forum.An advanced search should turn it up.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 10-11-2012, 06:36 AM   #5
kantuckid
Oddometer: 3,082
Also advisable to avoid syn in FD on the BMW to avoid leaks-well documented as mentioned earlier above.
kantuckid is offline   Reply With Quote
Old 10-11-2012, 08:15 PM   #6
AviatorTroy
AviatorTroy's Avatar
Oddometer: 1,646
Wrong.
AviatorTroy is offline   Reply With Quote
Old 10-12-2012, 01:47 AM   #7
Refplusten
Relaxed...
Refplusten's Avatar
Oddometer: 199
Please disregard that tidbit of info.
It's one thing to say:
but without the document it's just hearsay.
I'm sure BMW says that Synthetic 75W-90 for the FD is the only way to go. Although SOME guys in hotter climates occasionally use -140 but to each their own. Don't over think it. SYN 75W-90 and you are good to go for both Tranny and FD. I personally use Liqui-Moly 75W-90 full synthetic gear oil. It's a bit pricer than normal gear oil but it's got some moly in there.
VA7 GSA
Refplusten is offline   Reply With Quote
Old 10-12-2012, 02:37 AM   #8
AndyCap
Mineral Oil Anyone?
AndyCap's Avatar
Oddometer: 1,470
There are a few documents in the "Hall of Wisdom" Are they "the Gospel"? That's not for me to say.
Hall of Wisdom -> http://advwisdom.hogranch.com/Wisdom/
R12GS Final Drive Fluid Change (From Hall of Wisdom) -> http://advwisdom.hogranch.com/Wisdom...%20Change.html
Final Drive R&R Procedure (From Hall of Wisdom) -> http://advwisdom.hogranch.com/Wisdom...ive%20R&R.html
2004 R1150GSA, 2000 BMW R1150GS, 2008 KTM 950R SE, 2001 Honda XR400R, 2003 Honda XR100R
Another Proud Small Scale Faker......
New England Pie-O-Rama
ADV Pie Map
AndyCap is offline   Reply With Quote
Old 10-12-2012, 03:26 AM   #9
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,463
You can run 75w90 or 80w90 or the 140 weight in syn or dino.
Just make sure it is a good quality oil with gl5 rating.
The most important thing is to make sure not to overfill your FD.
2008 KLR 705-2004 ST1300-2001 FZ1
2001 GAS GAS 321
IBA # 23,716
http://gasguysadventures.blogspot.com/
GAS GUY is offline   Reply With Quote
Old 10-12-2012, 03:48 AM   #10
zitro79
BMW bitch
zitro79's Avatar
Oddometer: 179
Yes, make sure that it is GL-5!
zitro79 is offline   Reply With Quote
Old 10-12-2012, 04:37 AM   #11
manfromthestix
Lost in Space
manfromthestix's Avatar
Oddometer: 2,239
+1 on the above, with one comment. When I lived in Wyoming where it was much cooler, I ran lighter gear oil (same in both tranny and FD) than I do in Virginia. I've run full synthetic for years and never had any issues on three different BMWs so far. I've had two crown seal failures, but both were on bikes with 45K to 50K miles, just wear items. I changed my GS crown seal recently and did a photodoc on it in case you're interested:
http://www.advrider.com/forums/showthread.php?t=806193
The comment - I'm not sure how you overfill the FD unit. IIRC, the manual says fill to the bottom of the threads and that's just about as much as you can get in there without it drooling out. If you were somehow able to overfill it, it's vented and would likely just blow out, right?
Don't overthink this, it's the easiest service you can do on your BMW. I change my gear oils every other oil change, and do oil changes (also full synthetic) about every 5000 to 6000 miles.
Since you're new to the BMW service world, here are a couple more links to things that might be of interest. I've wrenched for decades on my bikes, but I admit to being rather intimidated by the thought of tearing into the BMWs. As it turns out, they are really rather easy to service compared to some other bikes I've had, and you can save BIG money doing it yourself, especially swapping tires:
http://www.advrider.com/forums/showthread.php?t=148614
Check your brake lines!!!
http://www.advrider.com/forums/showthread.php?t=825120
Welcome to ADVrider!
Doug
"If it doesn't blow smoke and make noise, it isn't a sport!" - radio ad for shop in Bozeman, MT
manfromthestix is online now   Reply With Quote
Old 10-12-2012, 04:40 AM   #12
kantuckid
Oddometer: 3,082
OK, I give . I'll let this go for awhile until you hear from someone that is willing to spend time digging up the "hearsay". In the meantime I'll run dino in my BMW FD to avoid seeping.
Old 10-12-2012, 04:43 AM   #13
manfromthestix
Lost in Space
Oddometer: 2,239
Oh yeah, there's one other thing about synthetic - if you get a colored one like Royal Purple or Redline it's really easy to tell if you have a leak!
I've heard of people putting two different colors in the tranny and FD unit so that if one develops a leak they'll know which it was, but that seems like a bit much to me.
Take care!
Doug
Old 10-12-2012, 04:52 AM   #14
manfromthestix
Lost in Space
Oddometer: 2,239
If it's seeping, the seal is worn and needs to be replaced. Running synthetic won't make a good seal leak. It's less than $25 and an hour of your time to replace that crown seal. It might be better to do that than worry about it seeping or having it blow out when you're 1000 miles from home.
Doug
Old 10-12-2012, 09:34 PM   #15
GSA GIRL
2010 R1200GS Adv.
GSA GIRL's Avatar
Oddometer: 103
Doug
My 2010 GSA does not have a vented final drive. It does not have a fill hole to fill to until it gets to the threads. My R1100GS did but this one is made entirely different. On This model you have to measure out I think it is 300 ml's and fill at a weird angle with a funnel after removing the rear wheel!
Alicia from The Left Coast. IBA # 45858
2010 GSA, 2008 KLR650, 1995 GS (Sold), 2005 ST1300 (DEAD)
GSA GIRL is offline   Reply With Quote
Times are GMT -7.   It's 04:41 AM.
