Old 10-11-2012, 09:33 PM   #1
SloMo228 OP
World Class Cheapass
Oddometer: 1,729
CX650 "Custom" ADV bike build
Well, I joined this forum to get some ideas for planning a long road trip next year and made the mistake of reading a bunch of trip reports from people riding dual-sports and getting off the paved roads, and it looks like a blast. And while it would be nice to go get a new GS, I'm a broke-ass grad student.
Hence this thread. I've always had a soft spot for Honda's CX twins, since a '79 CX500 was the first bike I ever owned. So when I saw a CX650 Custom listed locally for a few hundred bucks, I jumped on it. It's in kind of rough shape but the mileage is really low, only a little over 10K on it. The bad news aside from the surface rust and scrapes is the god-awful 80s chopper styling. Gotta do something about that.
Anyway, my goal with this build is to create something with roughly equivalent specs to the V-Strom 650, which seems to be a popular dual-sport ride around here. The CX650 produces just about the same power and weighs about the same as the V-Strom (actually the CX will likely weigh in about 30lbs less than the Strom after I'm done stripping it down). The CX actually has about 14" of available travel in the rear, but I'm going to limit that to about 8" or so to avoid damage to the driveshaft. Up front, I'll be swapping in forks from an XL600R, which will give me about 9" of front suspension travel.
Wheels will be 17" rear and 18" front, which gives me decent options for dualsport tires. I have a 19" front I can use as well but it would be mismatched and would probably bug me too much visually.
Aesthetically, I'm going for an old-school scrambler/WWII type look, since that will be easier to pull off than trying to mimic modern DS bikes. Hopefully, this will all come together fairly quickly, I've done my homework on this one and everything is more or less bolt-on for this build. I'm sure the MIG will come out once or twice, but for the most part this should be pretty straightforward.
Pics to come later!
--------------------------- Steve----------------------------------------
'93 GL1500 frankenbike basketcase in progress
'96 DR350SE
SloMo228 is offline   Reply With Quote
Old 10-11-2012, 09:49 PM   #2
JagLite
JagLite's Avatar
Oddometer: 1,192
Thumb CX fun
Sounds like a fun project to me.
go get 'em tiger!
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 10-12-2012, 02:30 AM   #3
gkam
gkam's Avatar
Oddometer: 68
I' m restoring a CX 500.
gkam is offline   Reply With Quote
Old 10-12-2012, 07:21 AM   #4
SloMo228 OP
Oddometer: 1,729
Here's what it looked like to begin with (not my bike, but close enough):
I forgot to take pics of the initial condition of the bike. Just imagine the above except the seat is torn and the whole bike is filthy.
Since I plan to use this bike as a commuter, everything has to be in good condition, so I start tearing it down:
And then a little more:
And that's where I left it after the first day of work, I've got today off too so it's back out to the garage for some more progress. I love working on this bike, everything is so simple. I mean, most of the bikes I've owned have been vintage bikes which are all simple by modern standards, but this one seems designed for ease of maintenance. For example, dropping the engine was all of unplugging about 6 wires, dropping the exhaust, pulling 5 engine bolts, and lowering it out of the frame. Took maybe 45 minutes to have the engine out starting from a fully-assembled bike. Didn't even have to drain the coolant, the radiator came out with the engine. And the wiring harness is so simple it's a joke.
'96 DR350SE
Old 10-12-2012, 08:44 AM   #5
bkowal
Oddometer: 246
I have a '83 CX650E, the Euro sport model, not sold in the US. Same basic bike, engine is identical. Bike has 120,000kms and still runs like new.
While you have the engine out, replace the stator. It will fail, fix it now. Also, replace the plug caps/wires. There is a resistor in there that corrodes over time giving you a weak spark. You can sometimes take them apart and clean them, but better to replace the 25 year old ones.
Same power as a VStrom 650? Not quite. But they do have a pleasant surge of power above 6000rpm
Lighter? Good Luck, the CX's are heavy beasts.
bkowal is offline   Reply With Quote
Old 10-12-2012, 11:19 AM   #6
SloMo228 OP
Oddometer: 1,729
The two bikes are closer in weight and power than you might think. I'm not sure if these specs are 100% accurate, but here's a comparison:
2012 V-Strom 650: 65 peak HP, 485 lbs wet.
1983 CX650: 65 peak HP, 480 lbs wet.
I'm not saying that the CX is the equal of the Strom (the Strom will DEFINITELY out-brake the CX, and the frame is stiffer, and the electrics are better, and a bunch of other things), but it does seem to be in the same league, at least on paper.
I got those specs from these sites:
http://www.bikez.com/motorcycles/suz...0_abs_2012.php
http://www.bikez.com/motorcycles/hon...650_c_1983.php
'96 DR350SE
Old 10-12-2012, 12:00 PM   #7
scarysharkface
30-125
scarysharkface's Avatar
Oddometer: 13,089
CX is a great bike.
The road to Hell is paved...
Save $5 on a Smugmug subscription when you use my coupon:
yBr7OofIPuOP6
Another '98 DR350 for sale http://advrider.com/forums/showthread.php?t=1036981
scarysharkface is offline   Reply With Quote
Old 10-12-2012, 12:22 PM   #8
limeymike
Who Me?
Oddometer: 626
keep it coming, always enjoy these types of builds and I especially like the CX motorcycle.
SloMo, remember you said: " for the most part this should be pretty straightforward." I hope you are right and you won't have to eat those words. Good luck, thousands are watching....
limeymike is offline   Reply With Quote
Old 10-12-2012, 12:26 PM   #9
bkowal
Oddometer: 246
Aussies dynoed it in at 35.4kW (47 HP). My butt dyno agrees.
http://australiancx.asn.au/files/CX6...heels-8306.pdf
These guys tested the new Vstrom 650, dynoed at 66HP
http://www.ridermagazine.com/road-te...-road-test.htm
Old 10-12-2012, 06:54 PM   #10
SloMo228 OP
Oddometer: 1,729
Ah. I had assumed that those were both crank HP numbers. Oh, well.
'96 DR350SE
Old 10-12-2012, 07:07 PM   #11
SloMo228 OP
Oddometer: 1,729
More progress today. Went to work with the wire wheel and de-rusted the frame, it was actually a lot better than it looked at first:
Then primed:
I painted too, but I used a light gray paint that is almost exactly the same color as the primer, so I didn't take another picture. I have a few free hours this weekend, so hopefully more progress will be made. The new parts are starting to trickle in via UPS, which is good since I don't have much more to do as far as re-finishing - gotta start reassembly after that and I need parts to do so.
Basically the only thing I'm not sure on as far as parts matching up is my wheels and brakes. I'm 95% sure the 17" wheel I ordered will fit, but won't know for certain 'til it gets here and I do a test fit - if it doesn't I'm in trouble because the stock wheel is a ridiculous 15". I know the front wheel I want will physically fit the XL600R axle, but I'm kind of taking a shot in the dark as far as getting the brake caliper in the proper position, it might require a custom-made bracket. Not a huge deal.
The biggest unknown is finding a decent-sized tank that fits close enough to work. I have a few to try, hopefully one is at least close enough to "massage" into the proper shape with a hammer.
'96 DR350SE
Old 10-12-2012, 08:10 PM   #12
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 3,764
Here's ya some inspiration....
http://www.twtex.com/forums/showthread.php?t=46633
____________________________________
Get fit. Stay safe. Enjoy life. Learn something to help someone in need.
AustinJake is offline   Reply With Quote
Old 10-16-2012, 09:54 AM   #13
SloMo228 OP
Oddometer: 1,729
No pics of progress, since it was either too cold or too humid to do any more painting over the weekend, there's really nothing to look at yet. Still waiting on parts to come in (mainly the rear wheel and the XL600 forks) before I can make any more real progress.
I replaced the steering bearings with new tapered roller bearings, drained, removed, and flushed the radiator, wirebrushed the rust off a bunch of fasteners (everything's going back on with antiseize on it, this bike's going to be ridden in winter), cleaned up the wiring harness connections, and gave the engine a quick scrubdown - the factory paint is actually still in pretty good condition, so I'm just going to leave it for now. Not really worth repainting it right before winter.
I'm trying to decide between the Shinko 244s and 705s for tires. I live in an urban area so most of my riding will be on the street since this will be a commuter. Any dirt riding will be on weekends or days off. So I'm leaning toward the 705s as they're more street-oriented. But, I also plan to ride this as often as possible, short of ice storms or blizzards, so I need grip in the snow. Seems like the 244s might be a bit better for that. I'm also considering buying some of the Aerostich studs and I feel like they would work better in the 244s as well. Any input or other suggestions would be appreciated.
'96 DR350SE
Old 10-18-2012, 08:39 AM   #14
SloMo228 OP
Oddometer: 1,729
More progress
My tank arrived today, along with a couple other boring parts like a carb kit and battery. I mocked it up to see how it will fit, and it looks like it will be close enough to work!
Hoping that the forks will show up soon, then I can start putting this thing back into some semblance of a motorcycle. I still have to figure out a seat arrangement, I was thinking about using one of those sprung saddles, or just a flat bench seat. I definitely think I'm going to have to modify the frame a bit to get rid of the "chopper dip," probably just cut out the top of the rear triangle and weld in straight tubing to make things flat there.
'96 DR350SE
Old 10-18-2012, 09:25 AM   #15
JagLite
JagLite's Avatar
Oddometer: 1,192
Thumb Good fit!
That tank looks like it was made for the bike!
Excellent choice and in great condition too.
Winner!
Attitude ~
James
Times are GMT -7.   It's 12:47 AM.
