Thread Tools | Search this Thread | Rate Thread | Display Modes |
10-12-2012, 05:21 AM
#1 |
out riding...
Oddometer: 1,274
help with garmin zumo 660, trying to import colrut, cenrut etc...won't acknowledge
i had my zumo 550 exchanged for the 660, i rode south america last year and not a problem loading maps, i just put them on a SD card and the unit recognised them and they showed on the screen right now i am back in mexico (i have garmin mexico loaded by online download) but heading into Belize today and the rest of CA next week and needs these maps to show i have tried... putting info on card - nothing putting info in GPX file and doing a rename to see if it shows - nothing it is the same name as a file already in there gmapsupp.imp, does it need to replace that file? any help would be much appriciated |
10-14-2012, 09:30 AM
#2 | |
Long Haul Adventurer
Oddometer: 3,170
If you don't have a computer with MapInstall and BaseCamp go to a NetCafe and download the IMG file for the map product you want to use and then rename it to gmapsupp.img and save it to the µSD Card\Garmin\ folder. You could use internal storage but you will quickly run out of space so use the µSD Card. On the road with no computer, the best access to maps of the world is via OSM for Garmin. You can obtain these maps in IMG format using a NetCafe browser (as long as they allow large downloads). It just might take a little time but once you down load the IMG file just save it to your zumo\µSDCard\Garmin\ folder as gmapsupp.img. Cheers,
Cheers, Dan |
10-16-2012, 07:16 PM
#3 |
out riding...
Oddometer: 1,274
i did get it figured out, all i needed to do was save the file to my computer then delete it off the Garmin, then upload the new map to the unit, and then move it to the GPX file, for some reason it didn't work if i put directly into the gpx file, seems a long way around but it works, well kind of Cenrut maps in Belize kind of suck in some areas, but the real life views are great...
check 'em out here...http://www.advrider.com/forums/showthread.php?t=809883 |
11-01-2012, 12:19 PM
#5 |
Oddometer: 9
Have you checked the english instructions on the Cenrut site?
Here they are: http://www.cenrut.org/adw/over.htm |
11-01-2012, 12:28 PM
#6 | |
out riding...
Oddometer: 1,274
