Old 10-12-2012, 12:11 PM   #1
electroken OP
Oddometer: 219
My New POS CB450K5
I've messed with many bikes over the years, but never a DOHC Honda 450. This thing set me back $200. It came with the KLR luggage in the foreground to sweeten the deal.
When I got to the bottom of the KLR luggage I found a Honda centrifugal oil filter broken into pieces. What do you know... the one that should be under the clutch cover is missing. This project is gonna be fun!
Front end goodness:
electroken is offline   Reply With Quote
Old 10-12-2012, 02:51 PM   #2
DaveStockwell
Rock Fodder
Oddometer: 205
CB450's are great! My first bike was a CL450 Scrambler which I rode across the US at age 16. (my butt still hurts) You can do all sorts of things with them. Like this!
Or go old school adventure riding on it.
"Yes. It looks insubordinate, but it isn't really." - T.E. Lawrence
DaveStockwell is offline   Reply With Quote
Old 10-14-2012, 09:57 AM   #3
electroken OP
Oddometer: 219
I'm leaning toward some kind of Mad Max meets Zombie Apocalypse rat bike. It's just too far gone to end up pretty or resembling an original K5. It will get my own home-grown Hall Effect ignition and all LED & HID lighting.
Old 10-14-2012, 04:12 PM   #4
electroken OP
Oddometer: 219
It looks like the oil filter and clutch basket came into contact and they both lost. The only way this happens is if some dummy leaves the oil filter nut loose. At least they didn't run it long like this, because the exhaust camshaft looks passable. The clutch cover gasket was homemade from the cardboard packaging of a toy.
Carnage shot with broken clutch basket and oil filter:
Old 10-20-2012, 11:27 AM   #5
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Hell, I'd a paid $200 bucks just for the seat! I had a '71 and loved it to death. Enjoy...
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 10-23-2012, 07:54 AM   #6
electroken OP
Oddometer: 219
Nobody would want this seat. The gray vinyl is turning back into petroleum and so did the duct tape holding it on.
So far the only internal parts needing replacement have been the centrifugal oil filter, clutch basket, and shifter shaft. What I can see of the valve train looks OK and the gearbox moves through all 5 gears about as I'd expect. I haven't measured the compression, but it feels right.
At this point I need to hear the engine run before I do much else. I think the only thing keeping the PO from running it without the oil filter (and therefore any oil pressure) was the completely solidified carburetors. Within a week I'll know what I really have.
Old 10-26-2012, 12:11 PM   #7
electroken OP
Oddometer: 219
I was an hour away from hearing this engine run. The right carb was assembled, then I started on the left. Hmmm... the float sloshes. What the... what are all these cracks?
Looks like I have to wait for another float. The contents of the box under the float should cheer me up a bit.
Old 10-27-2012, 03:08 AM   #8
SOS
Ignorance is a gift
SOS's Avatar
Oddometer: 722
You gotta love bringing something like that back to life
I had a '72 CL450 given to me last winter and just got it on the road. Nice bikes. Good luck with this one.
BTW I had to replace both floats as well. Not too bad though.
www.motorcyclesolutionsllc.com
SOS is offline   Reply With Quote
Old 10-28-2012, 10:08 AM   #9
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,466
Cool project.
The PO liked "RED" didn't he?
I'm always on the lookout for an old cheap DOHC 450.
There's one out there somewhere with my name on it, I'm sure!
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
Old 11-09-2012, 01:22 PM   #10
electroken OP
Oddometer: 219
The original fork tubes and caliper have been ravaged by the previous owners and time, so while I'm scrounging for parts I think I can improve things a bit. Luckily, 35mm fork tubes were used on all of the CB450, 500, 550, 650, and 750 siblings of the '70s and early '80s. I found a nice 1980 CB650 fork for $20 and a 1982 CB650 twin-piston caliper for another $20. Here they are on the bike with the original wheel and rotor.
I need to force myself to make this thing run this weekend before I spend another cent on it.
Old 11-09-2012, 01:59 PM   #11
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,982
I'd love to have another. I had a '72 CL450. I'd take that one back bad alternator and all. These bikes run really great.
---Albert Einstein
Old 11-09-2012, 02:09 PM   #12
Fast Idle
Since the Sixties
Fast Idle's Avatar
Oddometer: 319
Love those old Honda 450's! I had 2 of them growing up. They run awesome. Wish I had one again. I've been looking and ended up with a Suzuki GS450 to satisfy my craving. I'm building right now and I stole it for $100!
Riding as much as my old frame will allow!
Fast Idle is offline   Reply With Quote
Old 11-11-2012, 01:51 PM   #13
electroken OP
Oddometer: 219
I wired up a the coils to a battery, fueled it through my plastic service tank, and the damned thing started on the 3rd kick. I only ran it for 15 seconds or so, but it ran on both cylinders and sounded pretty much like any normal DOHC 450. Now the transformation can continue.
Old 11-11-2012, 08:02 PM   #14
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,708
I may have a few leftovers from my build if you are not doing a pristine restoration.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Times are GMT -7.   It's 07:34 AM.
