Old 10-12-2012, 12:33 PM   #1
Qwik OP
Adrenaline Addict
Oddometer: 6,947
New motor fires up, on one cylinder
trying to figure out why. put in different coil and plug to no effect. Front cylinder exhaust gets hot rear does not..any ideas?
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 10-12-2012, 01:46 PM   #2
NKL
Oddometer: 202
Fuel in carb?
NKL is offline   Reply With Quote
Old 10-12-2012, 02:45 PM   #3
TcRulz
Oddometer: 289
You could take the air cleaner cover off and pour a cap full of fuel in the rear carb throat and see if it fires on that or might be safer to pull the rear coil stick and stick another known good spark plug in it (making sure its earthed) and see if it sparks. Has to be fuel, spark or compression all working at the right time. Good luck.
TcRulz is offline   Reply With Quote
Old 10-12-2012, 03:20 PM   #4
NKL
Oddometer: 202
Just read the title again, what do you mean "new motor" and I assume nothing else has changed, carbs, electrics, ignition.
Old 10-12-2012, 09:12 PM   #5
Qwik OP
Adrenaline Addict
Oddometer: 6,947
Replacement motor. Original electrics that worked fine with the old motor. Old carbs as well. Gonna try dumpin fuel down the carb and see if that works
Old 10-12-2012, 10:12 PM   #6
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,606
Did you check the valve clearances and/or verify that the cams are installed correctly? If the seller is considered trustworthy, then this shouldn't be a issue if they were selling a known good running engine. But generally a good idea to verify and establish a baseline of known settings.
Also, depending on how long the bike was apart for the engine transplant, the fuel may have fouled the jets or stuck the float. If there is no fuel in the float bowl, then the needle is stuck in the seat.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 10-12-2012, 10:36 PM   #7
bykpimp
Live and let ride
bykpimp's Avatar
Oddometer: 1,410
Verify you have spark in both cylinders, if so move along to fuel, compression, oxygen.............
" I can't fix your motorcycle over the phone or internet" Spanky
bykpimp is offline   Reply With Quote
Old 10-13-2012, 11:16 AM   #8
NKL
Oddometer: 202
Took the words out of my mouth.
Old 10-14-2012, 11:52 PM   #9
Qwik OP
Adrenaline Addict
Oddometer: 6,947
Had a few minutes to mess with it today. Poured a little gas down the throat of the rear carb. Cranked it a bit and it coughed and fired on both cylinders. Gonna pull the carbs off and clean em up. Obviously some debris in the system that has it plugged up. It didnt sit long enough to gum up before I drained the Carbs.
Old 10-15-2012, 02:38 AM   #10
Dustodust
Dustodust's Avatar
Oddometer: 1,075
it helps to run it with just the left tank on until you get it dialed , you can see what the carbs are doing and have access to them
from a cloud of dust we race, then into the dust we return, across the finish line
04 KTM 950 S
04 KTM 525 EXC street plated
Old 10-15-2012, 01:37 PM   #11
Qwik OP
Adrenaline Addict
Oddometer: 6,947
Yup. Only have the left Safari tank on. New carb clamp came in today as well. ( old one stripped but its on the front carb with a different screw/nut making it work.
Old 10-15-2012, 04:28 PM   #12
Narsisco Lopez
Addlepated
Narsisco Lopez's Avatar
Oddometer: 2,207
Carb? What's a carb????
Oh! You mean those old-fashioned things my great-grandfather's Edsel used to have to shoot gas into the pistons!
FYYFF!
http://www.youtube.com/watch?v=NtpUv4VBDhA
Bikes: 2013 BMW K1600GT
A Few Past Bikes
: 2003 Suzuki DRZ400E | 2012 BMW K13S | 2009 KTM 990 Adventure
Narsisco Lopez is offline   Reply With Quote
Old 10-15-2012, 06:41 PM   #13
Qwik OP
Adrenaline Addict
Oddometer: 6,947
Doesn't shoot gas it drizzles it
Old 10-15-2012, 09:24 PM   #14
Qwik OP
Adrenaline Addict
Oddometer: 6,947
Tossed some sea foam in the tank to see if it will clean the jets/carb up a bit. It's poppin a bit and doesn't want to run off choke.
Old 10-16-2012, 03:19 AM   #15
TA-Zappa
TA-Zappa's Avatar
Oddometer: 171
Exactly, the ones that doesn't give you whiplashes from normal use...
/Zappa
'05 950 Adv S - 73000km
'14 Beta RR 350 - 15h
'14 Beta RR 350 - 2h (Stolen)
'09 250 EXC-F SixDays - 184h (Stolen)
'98 XL600V Transalp - 86000km - SOLD
TA-Zappa is offline   Reply With Quote
Times are GMT -7.   It's 01:21 AM.
