Old 10-12-2012, 01:12 PM   #1
GmanVic OP
GmanVic's Avatar
Oddometer: 154
BMW R850R RID Install?
Hey does anyone know how hard it is to install a RID (Rider's Information Display) on a 1996 R850R that didn't have it installed at the factory? I guess it would be too easy to be true that the various sensors (gear indicator, oil temp, fuel level) would be in place and it's just missing the LCD display device?
(A friend of mine just bought a cherry R850R for his wife and I let slip that "it sure would be nice if it had the RID" - oops!)
GmanVic is offline   Reply With Quote
Old 10-13-2012, 02:30 PM   #2
hitmanh
hitmanh's Avatar
Oddometer: 202
hmm, good question. Lift the tank and see if the socket is present. There are different part numbers for the main wiring loom between the GS and the R so the socket may not be present.
BMW F800GSA
hitmanh is offline   Reply With Quote
Old 10-13-2012, 02:44 PM   #3
hitmanh
hitmanh's Avatar
Oddometer: 202
Far as I can see, only the GS and RT came with a RID. Not sure if the R is fitted with a gear position indicator or a neutral only indicator switch.
BMW F800GSA
Old 10-30-2012, 10:11 PM   #4
GmanVic OP
GmanVic's Avatar
Oddometer: 154
Thank you hitmanh!
Old 10-31-2012, 10:31 PM   #5
ramon
weezin' the juice!
ramon's Avatar
Oddometer: 1,128
It's not a cheap upgrade. I too thought, all you needed was the display. Wrong! You need the wiring too. Not too expensive, but more expensive than it should be. I'd hit eBay and hope for the best
"...if you don't like the price then move on because I don't give a shit...it's my bike and I will sell it for whatever I want." Craigslist SF posting
ramon is offline   Reply With Quote
Old 11-01-2012, 03:15 PM   #6
acejones
acejones's Avatar
Oddometer: 5,271
I wouldn't add it even if you could. The information is not as legible as analog instruments and it'll probably fail anyway. The Germans aren't real handy with electrons.
I got tired of being here, so now I'm there
acejones is offline   Reply With Quote
Times are GMT -7.   It's 03:35 AM.
