Old 10-12-2012, 01:47 PM   #1
Mike Ryder OP
Kriegerkuh
Mike Ryder's Avatar
Oddometer: 1,024
BeadPro tire tool, 205?
Just saw this, has anyone here used it?
http://www.youtube.com/watch?v=MK75j2N3QmY
Yes I am quite serious.
Mike Ryder is offline   Reply With Quote
Old 10-12-2012, 04:12 PM   #2
stilldointime
Fast and Loose
stilldointime's Avatar
Oddometer: 42
stilldointime is offline   Reply With Quote
Old 10-12-2012, 04:51 PM   #3
knobbyjoe
knobbyjoe
knobbyjoe's Avatar
Oddometer: 539
OK but where is the demo of the bead breaking process??
KTM 400 XCRW with Thumper Racing 450 kit and 450 cam 2007
KTM 450 XCRW with Christini AWD and Plated 2008 now has 520 Thumper Racing kit
KTM 990 Adventure 2008
knobbyjoe is offline   Reply With Quote
Old 10-12-2012, 05:30 PM   #4
swingset
Got the knack.
swingset's Avatar
Oddometer: 11,052
47 seconds of sleek photos of a tool and not a single second devoted to seeing how it works?
Awesome marketing there.
swingset is offline   Reply With Quote
Old 10-13-2012, 09:25 AM   #6
rockydog
just a guy
rockydog's Avatar
Oddometer: 888
or one could go to the motion pro website and look under tools- tire/wheel. but if that is too difficult, just use this link and look at the pictures
http://www.motionpro.com/motorcycle/partno/08-0519/
Two lane roads and two bit towns
Rockydog woofs the Isles, British Isles
rockydog screwed with this post 10-14-2012 at 08:30 AM
rockydog is online now   Reply With Quote
Old 10-13-2012, 01:51 PM   #7
ThunderPig
ThunderPig's Avatar
Oddometer: 33
I have the pair and I think they work great. Popped the bead in about 45 seconds. Really ingenious design.
ThunderPig is offline   Reply With Quote
Old 10-14-2012, 05:39 AM   #8
stilldointime
Fast and Loose
Oddometer: 42
Originally Posted by rockydog View Post
or one could go to the motion pro website and look under tools- tire/wheel. but if that is too difficult, just use this link and look at the pretty pictures
A few still pictures are awesome. Wonder if it's to "difficult" for them to post an actual video to demonstrate the tool. As we all know (well maybe some of us don't) breaking beads on tires isn't all that easy. So pictures are great, but they don't show the actual use of the tool. If it is such a great tool and easy to use, I find it suspicious they do not have a video breaking a bead. They advertise it as the first tool of its' kind for "Adventure Bikes". Then show me the tool in action on an adventure sized tire.
Old 10-14-2012, 07:06 AM   #9
Mike Ryder OP
Kriegerkuh
Mike Ryder's Avatar
Oddometer: 1,024
I suspect,but don't know,that a hammer may be necessary as an insertion tool.
Old 10-14-2012, 09:16 AM   #10
SierraJeep
It's toast
SierraJeep's Avatar
Oddometer: 630
I took a 3600 mile trip in July/August and had 5 flats along that adventure; all on those were on the rear tire. Although I run tubes in my wheels, my tires are tubeless tires (Heidenau K-60s) and they are a pain to break and reset the beads. So in September I took another 1500 mile trip and bought a set of these to see if it'd make the trail-side tire changes easier. While I am anxious try them I can report that there have been no more flats!
So maybe it's worth it to buy and set and then not have to use tthem?
Tod
2010 KTM 990 Adventure
2010 KTM 450 EXC
SierraJeep is offline   Reply With Quote
Old 11-01-2012, 06:33 AM   #11
rockydog
just a guy
rockydog's Avatar
Oddometer: 888
I had to change a tube on the rear of the xchallenge and used a small Dasko Pro pry bar to break the bead. Basically pushed the bar between the tire and rim and pried until there was a workable gap, a few more bites working around the rim and the tire was ready to be spooned off the rim . No hammer, just a few bites, easy job. Here is a link to the home depot page, Sears carries them also. The bar is the middle one, great tool for many tasks, 9 1/2" long, little under 1/8" thick. $7 on the sears online page.
http://www.homedepot.com/buy/dasco-p...l#.UJJ2Hu_C2So
rockydog screwed with this post 11-01-2012 at 06:54 AM
Old 11-02-2012, 02:32 PM   #12
Spinalcracker
former redriderofma
Spinalcracker's Avatar
Oddometer: 1,091
why is it for tubless tires? can you use it with tubes?
Unless we change direction, we are likely to end up where we are headed.
It's county Fair time in New England
TET MA to NC
Vermont Covered Bridges
Spinalcracker is offline   Reply With Quote
Old 11-05-2012, 06:38 AM   #13
acap650
acap650
acap650's Avatar
Oddometer: 734
Not just for tubeless, they say that because tubeless usually have a tighter bead fit on most rims, not always, but usually. I've seen some tire/rim combinations that will break with the heel of a boot and others that require an industrial bench vice. They could make it look easy if the tire/rim combo is a loose fitting one. As with all miracle tools, YMMV.
acap650 is offline   Reply With Quote
Old 11-07-2012, 03:44 AM   #14
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 7,928
after being annoyed by most bead breakers on the market someone mentioned to me they just use 3 tire irons. 2 pressing down on the tire at 12 and 2 o'clock then the third pressing the opposite direction.
Voila bead popped. I couldn't believe it. I haven't bent over to use the bead popper on any tire change since. Just put the wheel in the wheel holder, 3 tire irons in 3 locations and I'm done.
Try it, you'll be surprised how easy it is. Also, make sure it's well lubed.
HaChayalBoded is offline   Reply With Quote
Old 11-07-2012, 04:11 AM   #15
BornAgain
BornAgain's Avatar
Oddometer: 254
I'll second that really easy.
BornAgain is offline   Reply With Quote
Times are GMT -7.   It's 06:34 PM.
