Old 10-13-2012, 11:42 AM   #1
DirtyOldMan OP
Oddometer: 1,915
Load testing a starter
I'm working on a 06 Husqvarna TE 510.
It will start fine when cold but as soon as it's warmed up, the next press on the starter button blows the 15 amp fuse. I've been through all the wiring and connections carefully, replaced a worn ground cable, taken the starter apart and replaced the brush carrier. One brush (on the -side) was worn down about halfway.
The starter has always (owned the bike 4 yrs,) sounded like it was doing all it could to turn the motor over and would even sometimes not turn over at all. All I had to usually do was push the bike slightly in gear to get everything in a different position and then the starter would turn it over just fine. It kickstarts easy as well.
When it blows the fuse, it does it immediately upon pressing the button. In other words it does not labor to start and then blow.
Not many moving parts inside the starter, the windings did not look burned, the armature did have a grey mark on it from the brushes but it was not worn.
Starter spins freely when on a bench connected to 12v. I'm curious about how to measure what it's drawing when it's under load.
I have a basic multimeter
The bike has a new battery,
The starter has been probably used more than the better rider would use one. It's not uncommon for me to stall/restart frequently.
Any insight would be appreciated.
A source for the Mitsuba starters would be valued as well.
Thank You
Sandy Jackson
04 250 RFS
13 650 Terra
96 R1100R
DirtyOldMan is offline   Reply With Quote
Old 10-13-2012, 12:43 PM   #2
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,716
Does it have a solenoid/starter relay? It should but may not be attached to the starter. That's what is usually fused, not the starter motor per se. So I'd look at that and the switch. Putting a screwdriver across the two big posts on most solenoids will bypass the switch function and should engage the starter, again all depends on what you have there, much harder to do with a relay setup. Watch out with the screwdriver....sparks may fly.
But having to move the bike to rotate the starter and then get contact, that's usually a bad commutator. The part where the brushes touch, should be divided in rectangles, one of them may have failed and when the brush sits there....no contact, starter won't turn. You can check for that with the multimeter, one lead on the commutator body then hit all the contacts in turn, all should have continuity.
Have tools, will travel!
Old 10-13-2012, 12:45 PM   #3
speedracertdi
speedracertdi's Avatar
Oddometer: 985
Does your bike have an automatic compression release? That could fail and overwork the starter.
Other thing I would look at would be the starter solenoid it it's not part of the starter. Could have bad or dirty contacts.
Roads? Where we're going we don't need roads.
-Doc Brown
speedracertdi is offline   Reply With Quote
Old 10-13-2012, 06:15 PM   #4
DirtyOldMan OP
Oddometer: 1,915
The solenoid is at the back of the battery and I can jump across the contacts and energize the starter even with the fuse blown or out.
I'm starting to think the problem is the solenoid rather than the starter itself.
But, a question, now I understand that it is the solenoid that is fused not the starter, could a bad starter cause this fuse to blow.
I cleaned/tightened the external connections but was unclear how to get it open to have a look at the actual contacts. I'll explore that in the AM.
I looked into the auto compression release, don't think it has one. The manual compression release cable is the only one present.
Thanks for your help, m/c electrics confuse me.
Sandy Jackson
04 250 RFS
13 650 Terra
96 R1100R
Old 10-13-2012, 06:56 PM   #5
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,716
Universal type solenoids....they are pretty cheap if you want to save money over MC specific parts. I have a couple here that came out of garden tractors, I am sure I could fit that on a bike. I think the one on the garden tractor is out of an outboard engine....or was it an old Chrysler.
Just to say that for post sizes, they are pretty well all the same, there is like 28 pages of them on Fleabay.
I think your starter is OK. Now that I remember, the fuse was also blowing out of my old Honda way back then, kept kickstarting for a couple years til I replaced that solenoid.
Old 10-13-2012, 08:03 PM   #6
ragtoplvr
Oddometer: 6,414
to answer one specific question. Solenoids that are mounted away from the starter, a bad starter can not make the solenoid blow the fuse.
In the case where the solenoid is mounted on the starter, and has the function of engaging the drive, like used on HARLEYS, BMW, GUZZY, and probably some others, then it can. These solenoids have 2 windings, one is low current, and holds in the solenoid while cranking. The other winding is much higher current , and it used to engage things. once correctly engaged, this winding is disconnected. If the starter does not engage correctly, the high current can blow fuses.
In your case, I think you need a new solenoid.
Rod
ragtoplvr is online now   Reply With Quote
Old 10-13-2012, 09:08 PM   #7
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,317
It sounds like you have a bad armature winding that is shorted to ground.
If you need to physically move the starter when it is on a dead spot before it will crank, that rules out the solenoid.
To verify you need to disassemble the starter and check for continuity between the commutators, and also between the commutators and armature ground, but I suspect that if it is to the point where it is blowing fuses like this you will probably see which commutator is discolored and also has darkened paint on the windings.
GreaseMonkey is offline   Reply With Quote
Old 10-13-2012, 09:25 PM   #8
_cy_
Oddometer: 6,332
Thank You
starters are never fused because of huge current draws up to 200amps.
what are fused is starter relays. normally your starter button can only handle small current loads, usually less than what starter solenoid requires to function.
if your fuse is blowing .. I'd be looking at what is blowing fuses by tracking down your starter relay. provided your husky has one... sorry not familiar with Husky. but all starters work this way. unless starter button can handle a large current. then no relay is needed.
to test your starter ... after fuse blows... touch a wire from positive side of battery to solenoid wire that energizes starter. main cable from battery to top post of solenoid will always be hot.
when solenoid is energized, top wire will make a connect with bottom spinning starter armature. solenoid will also engage starter tooth to flywheel ring gear.
if you have an DC amp meter ... initial draw will be about 125-150amps, then reduce down to about 75amps or so. depending on how cold.
your battery when fully charged should read about 12.8v resting. when engine is running depending on battery charge level... voltage should be from 13.8-14.2 aprox.
_cy_ is online now   Reply With Quote
Old 10-13-2012, 09:44 PM   #9
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,122
The Husqvarna uses a starter motor that is always engaged and an over running type clutch when the engine is running. What people are calling the solenoid is just a big relay.
It appears he read your mind and took your advice before you posted it.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 10-13-2012, 10:16 PM   #10
_cy_
Oddometer: 6,332
that's a new one on me... but that doesn't sound right... I'd believe the starter drive gears are engaged all the time. but not the start motor.
in which case starter relay would work identical as described above. only instead of solenoid pulling starter tooth into ring gear ... solenoid would engage drive clutch and armature.
here's the factory service manuals for download ... can't make hide nor tail out of it... beside chinese manuals, worst written manuals I've ever seen http://husqvarnaoutlet.com/repair_manuals
Old 10-13-2012, 11:00 PM   #11
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 34,122
Okay, the starter disengages when the engine starts and the gear over runs the shaft. Here's what it looks like on a flying brick. It's similar for just about every bike that doesn't use a bendix. I'm using BMW because I know the parts catalog and Real OEM has good graphics. Here's another example, a G450X which is also used in a Husqvarna.
DirtyOldMan, test the continuity between every segment of the armature and the shaft. There should be no continuity. Use the ohms setting on the multimeter.
Anorak screwed with this post 10-13-2012 at 11:05 PM
Old 10-14-2012, 07:38 AM   #12
anotherguy
anotherguy's Avatar
Oddometer: 6,631
Anyone remember one of these?
you don't see luggage racks on a hearse..........act accordingly
Old 10-14-2012, 07:51 AM   #13
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,713
I have one of those but mine is really old. No meter instead it has a light bulb. I know it's used to test starter windings. I think it's used to test the rotor mainly, maybe the rotor only. But I don't know how to use it. I tried to figure this out on the internet but didn't get very far. Since then I've not really needed to test any rotors. It just sits on a bench in my room. One of the old things I can't bring myself to throw away. It has history.
---Albert Einstein
disston is online now   Reply With Quote
Old 10-14-2012, 08:33 AM   #14
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,716
You bet when I was young...an even older one with a bulb instead of a meter.Most of our old equipment was from the 30's when grandpa set up shop. Bulb lights when testing for continuity instead of the needle going up.
Install armature on top of the "magnets", turn it on then using an old (or new) hacksaw blade laid along the windings, rotate the armature. If the hacksaw blade "magnetizes" anywhere on the outer part of the armature, it is bad.
After that....black wire on the armature and touch each commutator in turn with the red, bulb will light if so equipped or meter will show continuity at each one . If one doesn't, that's bad. But you can easily do the last with a regular Ohmeter.
Always had a kick with that growler....there buddy hold this just above there when I turn it on.
Old 10-14-2012, 08:46 AM   #15
_cy_
Oddometer: 6,332
does your growler look like this?
from ebay for $39 ... have always wanted one after watching someone rebuild starter from a Triumph Spitfire when I was a kid.
pretty coool process .. silver soldering new brushes, testing armature on growler, turning down armature copper pickup on a lathe, pressing new bushing, etc.
Times are GMT -7.   It's 07:21 PM.
