Old 10-15-2012, 01:50 PM   #1
danielcut OP
danielcut's Avatar
Oddometer: 25
'86 Interceptor 750?
I have the option to pick up an '86 Honda Interceptor 750. I'm still working on an '80 CB750 and wasn't really looking for another project but the price is pretty unbeatable. I'm basically looking for opinions on the bike. I don't know a ton about them. I've been scouring the net but there seems to be pretty limited info on them. Apparently they were fairly rare in the states in the 750 orientation. It's in fairly rough shape but I'm told it runs.
danielcut is offline   Reply With Quote
Old 10-16-2012, 07:32 AM   #2
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,927
vfrworld.com
awesome motor, nothing sounds like gear driven cams
Old 10-16-2012, 07:36 AM   #3
Doppelganger
Alive & Living
Doppelganger's Avatar
Oddometer: 144
Bought one brand new in 86....loved it. I had it for 4-5 years and put on 25,000 miles. Loved it so much, I bought another VFR in 2002. Great motor.
Get on your bad motor scooter and ride!
Doppelganger is offline   Reply With Quote
Old 10-16-2012, 01:49 PM   #4
danielcut OP
danielcut's Avatar
Oddometer: 25
I picked it up this morning. It's pretty beat up but I only paid $100 for it and it had a title so I'm satisfied. It'll be a slow work in progress but hopefully I can make something decent out of it.
Side note: Does anyone know why people feel they have to do that with a rattle can? I bought a '94 CBR600 with the same thing done to it. How hard is it to just mask something off?
Old 10-16-2012, 07:00 PM   #5
dentvet
Oddometer: 1,345
$100 well spent. Are you sure its a 750? I think the 750 had gold calipers or something. The 700 was more common, i had a couple, first a RWB 700 then a pearl white 700. Nice steady wail as they climb in the RPMs. I bought the first one wrecked and the guy selling it swore that you could balance a nickel on its edge on the engine case as you revved it to the moon. Maybe an official honda promo/propaganda? Funny the things you remember sometimes. I still have the matching Freddie Spencer Aria helmet, thinks its still any good?
dentvet is offline   Reply With Quote
Old 10-16-2012, 07:57 PM   #6
danielcut OP
danielcut's Avatar
Oddometer: 25
I'd heard the 700s were more common. Tariff busters. Not 100% sure on it being a 750, just what I was told by the guy I bought it from. I'm curious now, I'll have to check it out tomorrow and see what I can find out. Is there any real difference in the models other than engine size?
Old 10-16-2012, 08:50 PM   #7
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,745
IIRC there was an issue with valve guides leaking and the motors smoking a lot, I guess you'll find out when you start it!
James and Colleen Tucker.
Aut viam inveniam aut faciam
DMV work/insurance/registration/titles/address use/room rental/motorbike&vehicle buying/travelers help/problems solved
TUCKERS is online now   Reply With Quote
Old 10-17-2012, 01:16 PM   #8
motomike14
Thumper Crusader
motomike14's Avatar
Oddometer: 1,724
http://jalopnik.com/5952274/how-to-g...eville-for-300
"The bold adventurer succeeds the best. - Ovid
I drink the koolaid too...just not the orange kind.
motomike14 is offline   Reply With Quote
Old 10-18-2012, 11:13 AM   #9
danielcut OP
danielcut's Avatar
Oddometer: 25
Confirmed on the VIN plate that it is in fact a 750. I've put off starting work on it for now because we will be moving soon and I'd rather move the full bike than a frame and boxes of parts. That and I'm not even sure where to start...
Old 10-19-2012, 12:00 PM   #10
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,537
You can start just by looking at how hard it is to remove the carbs for a cleaning. I know had a Sabre....same design. My friend just picked up one of them Sabres.....I looked again just for old times sake. His runs but not that well. Will be sitting for a few days with carbs full of Seafoam just in case that works and we don't have to remove them.
If you are crafty and like working in tight places with bent tools, you may be able to do as we did. Remove one of the bottom carb covers and inspect,left rear was the easier one. Then assess the amount of crap that may be in there. That one wasn't too bad....no grits so we are trying the Seafoam, just in case that works. I hope we get the "Miracle in that can". Phew....will know next Tuesday.
Have tools, will travel!
Old 10-19-2012, 12:44 PM   #11
pjm204
Oddometer: 1,987
I also had a sabre, wow did those carbs suck to work on. Avoid removing them at all costs!
Current bikes:2006 DL650, 2008 WR250R
Past bikes: XT225, TTR125, '04 CRF50 '74 DT125,'70 TS250,'85 v45, '89 zx600c, '78 GS400x, '99 GS500E, '01 GS500E '05 Z750s, '77 GS400e, '82 GS1100ez, '97 GSX600, '07 VFR800, '03 KLR650, '03 FJR1300, '06 DL1000, '00 KLR650, '99 WR360, '08 DL650, '05 DR650, '08 EX650r, '96 CR500, '82 GS450T, '06 Ural
pjm204 is offline   Reply With Quote
Old 10-19-2012, 01:01 PM   #12
markjenn
Oddometer: 10,395
I've worked on a lot of V4 Hondas and if the bike is in as rough a shape as it looks, your chances of getting the carbs to work acceptably without removing them is essentially zero. They're difficult to remove and more difficult to put back on but you probably need to bite the bullet and do the deed.
The keys to getting them back on without too much cussing:
+ get the rubber boots as pliable as you possibly can by soaking in very hot water and/or use new ones
+ leave the hose clamps off all-together if you have to - even loosened, then can add stiffness to the boots that make it more difficult to seat the carbs; its tough to fish them in after the carbs are seated, but it can be done
+ don't be afraid to use considerable force
As I recall, it works best to first seat the front boots, then the back.
This is a very cool bike, but make an overall assessment of what is likely to need replacement to make it acceptable to you before you sink too much money into it. If too far gone, it is uneconomical to bring a bike like this back and it is better to punt and disassemble/sell for parts. This one looks like it would be totally uneconomical to bring back to stock but it could possibly be made into a decent runner. Early Honda V4 parts are quite valuable.
- Mark
markjenn screwed with this post 10-19-2012 at 02:01 PM
Old 10-19-2012, 01:12 PM   #13
moparren
moparren's Avatar
Oddometer: 171
I've got a VF1000R project going. Gotta add on about getting the carbs off and on is a pain. Make sure the bike is well suported when you go to beat the carbs back into position.
But that sound...
I like to pretend I'm a writer! http://davidsreynolds.weebly.com/index.html
moparren is offline   Reply With Quote
Old 10-19-2012, 01:18 PM   #14
BikePilot
BikePilot's Avatar
Oddometer: 11,253
Cool bike, way advanced for that vintage. Generally a pain to work on, generally very high quality build. Cams were known to wear, probably due to marginal oiling to the cams and maybe partially due to soft metal used to make the cam. Check the lobe heights.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 10-19-2012, 01:29 PM   #15
YOUNZ
Oddometer: 324
It required three cans of Sea Foam to clean my carbs that were not run in twenty years. But it worked.
YOUNZ is offline   Reply With Quote
Times are GMT -7.   It's 11:57 PM.
