12-21-2012, 03:50 PM
#1801 |
Oddometer: 188
Outstanding RR Outstanding Pictures
I can't say how much I've enjoyed reading this -----These guys and girl are real Adventure Riders and I've learned a lot from them about a whole bunch of things. I have a couple comments:
I've found a way to run the lite locks with minimum mounting problems. I run two of them at 180 degrees but don't put them in until your have the tire fully mounted on the rim ---just spoon the tire back on the bottom side of the rim in the area where the rim lock is to be placed. Let the spoon lay on the ground under the rim and the pressure will hold it in place. Then, on the top of the tire you will want to use two spoons about 8 inches apart---and spoon the tire over the rim in those eight inches. Then insert a small block of wood----something like a short piece of 2X4 between the tire and the rim as you pull that 8 inch piece of tire outward---twist the block to gain the 3.& 1/2 inch space across the wide part of the block -----then move over 8 inches and do the same thing with another block of wood. Now, with the space created between the wood blocks and with the tire pulled back on the bottom side you have plenty of space to reach in there and set your lite lock-----then simply spoon the tire back in place. Same procedure on the second lite lock if you use a second one on the other side of the tire. Obviously this works only if you have taken the tire off the machine. The advantage of two light locks if first---for balance and second you can ride the bike for a short distance to find a place to effect a repair without the tire coming off the rim. Then, I noticed that Walters mechanic was using what we here in Utah call "An Idaho torque wrench" on that clutch. I think the Idaho guys call it a Utah torque wrench--- ha ha Rod----Man I am a fan of yours now----humor----that's the key. I know that wasn't what was inside you but that's what was coming out. Your posts added so much to the RR----and I have to admit that I got wet eyes every time mention or pictures of your dog---been there---done that. Terry----the quiet one? A real man's man. Prutser and Beamster---Good companions and good ADV riders. Thanks Walter-----You are the man.-- especially -loved those pictures of the lassies---added so much to the report. - |
12-21-2012, 04:52 PM
#1802 | |
on the road o'dreams
Oddometer: 5,390
Sounds like the DR, the BMW 's are also a doodle to swap sprockets on in situ.
12-21-2012, 05:36 PM
#1803 |
Oddometer: 148
12-21-2012, 06:37 PM
#1804 |
Oddometer: 148
Walter, is there any significance in riding thru Mongolia versus taking upper route thru Severobaikalsk and up to Yakutsk (providing there are roads up there)?
12-21-2012, 11:11 PM
#1805 | |
"Moto Porn"ographer
Oddometer: 3,801
Who says we didnt?
Sibirsky Extreme 2009 BOOK and DVD available HERE Moroccan Extreme 2011 DVD available HERE www.sibirskyextreme.com |
12-21-2012, 11:45 PM
#1806 |
Oddometer: 281
12-22-2012, 03:23 AM
#1807 |
Oddometer: 166
12-22-2012, 05:53 AM
#1808 |
не стреляйте
Oddometer: 36
Thanks for hooking all of us!
Walter- I started on this site while sitting in Iraq, spending my two free hours a day reading the original Sibirsky Extreme report. All your reports are great but each brings something a little different.
This ride is incredible with the different perspectives everyone brings. It is amazing to watch the ride unfold, with every rider sharing their photographs and experiences. Thank you to everyone for bringing us on this trip!
12-22-2012, 06:57 AM
#1809 |
Oddometer: 16
Huge mistake
I've made a huge mistake. I spent all my free time catching up on this rr. Now that I'm on Xmas break I have nothing to do. Can someone point me in the direction of where to start on Walters rr's.
true inspiration guys and gal. Thanks for taking us along for the ride |
12-22-2012, 07:26 AM
#1810 | |
не стреляйте
Oddometer: 36
I would start with "Sibirsky Extreme" and follow along by date. Make sure you tell people you won't be around for the next couple of months- you are catching up on reading!
12-22-2012, 07:34 AM
#1811 |
Scope Creep's Victim
Oddometer: 2,209
Fred '85 R80RT G/Sified '91 R100GS Bumblebee Airhead Zen: Ride-Maintain-Repair-Ride On. |
12-22-2012, 10:15 AM
#1812 | |
Oddometer: 7,723
![]() ![]() Not in any particular order... http://www.advrider.com/forums/showthread.php?t=569243 http://www.advrider.com/forums/showthread.php?t=602168 http://www.advrider.com/forums/showthread.php?t=533442 That should keep you busy for a few hours. Lets us know when your done with those and we can give you a few more links.
2004 XR650L 1992 Specialized Stump Jumper FS NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST |
12-22-2012, 11:27 AM
#1813 |
Oddometer: 506
Day 53 10 July Part 1
On the morning of day 53 Terry, Beamster and me had seen enough of our rooms in the hotel.
Because there was still no news from Rod we packed our stuff and left for a few more days. We asked Walter to let us know asap if there was news about the KTM, so we could be back in time to reunite the group Walter showed us some tracks he had. And told us to take the right one otherwise we would enter a border zone !!! (because we didn't have a permit and don't speak Russian that wouldn't be the best option) First we drove to Kosh-Agach where we got some fuel for the bikes and did some grocery shopping. Most of the tracks we tried, ended where the mountains started. After trying a few the weather didn't look to promising. So we decided to start looking for a campsite and setup camp before hell would brake loose. The landscape near Kosh-Akash is totally different from that near Aktash. Much more desert like.
BMW R100'91/R80'93/R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920 R100GS'91 (sold) |
12-22-2012, 11:42 AM
#1814 |
Oddometer: 506
Day 53 Part 2
We were lucky with the weather, although we felt a few drops it didn't get as bad as it looked in the distance.
![]() So we started to cook ourselves a nice hot meal. ![]() All the time these little eyes were keeping an eye on us.
12-22-2012, 12:45 PM
#1815 |
Oddometer: 23
Cutest pic of the day award.
Okay so this is the winner but what is it? I can't work out whether it's a Gerbil, Gerd, Degu or what have you. Either way I want a little family of them to take care of
