11-12-2012, 02:14 AM
#511 |
sigh-own
Oddometer: 2,771
I find that to be a positive. First thing I did with my Zumo 660 was to mute the turn by turn instructions.
I say, there's no such thing as a bad day's riding. -metaljockey whats the value of good gear?: http://www.advrider.com/forums/showp...ostcount=49301 |
11-12-2012, 02:40 AM
#512 |
"Moto Porn"ographer
Oddometer: 3,808
Yes, on google earth there is a button labelled "add path". Using that tool you draw a line by adding points.
When finished, highlight the header for it on the left side lists of stuff, and save it somewhere as a KMZ file. Using WinGDB3 (http://www.sackman.info/) or www.gpsvisualizer.com i convert the KMZ file to a GPX track file and open in Mapsource - then its ready to load onto a Montana. You can do the same thing (drawing your track) with a bit of free Russian software called SASplanet (http://sasgis.ru/download/ - extract it into a directory and run the exe file). SASplanet allows you to choose different satellite image sources from google, yahoo, bing, and several russian sources ... whereas google earth just allows you access to google satellite images. Also SASplanet stores all downloaded imagery in a hard-drive cache, and you can even set it to download areas or even countries at various resolutions, so you can use them offline, when you are out lost in the middle of nowhere. Its a nifty bit of software and now allows installs in English (before it was Russian only and a real handful) If you prefer working in basecamp, then like for the Montanas, you must work with tracks and not routes. If you work with routes in basecamp, your entire effort will be wasted, as basecamp thinks its smarter than you are ignores all the hundreds of points you have drawn as your intended route from A to B ... it takes only points A and B and calculates its own way there. I still have a huge preference for garminising via Mapsource.
Sibirsky Extreme 2009 BOOK and DVD available HERE Moroccan Extreme 2011 DVD available HERE www.sibirskyextreme.com Colebatch screwed with this post 01-21-2013 at 10:18 AM |
11-12-2012, 05:43 AM
#513 |
Oddometer: 301
great info!... exactly what i've been looking for.....
11-12-2012, 05:52 AM
#514 | |
"Moto Porn"ographer
Oddometer: 3,808
As the vidcaps show, there are a load of track splits or intersections on this track. You have to check at each and every one that you are going the right way. If you can do that without slowing down, from just a quick glance at the unit, its a huge convenience. I wish they made these things with 5 inch screens, like many of the car units, but for now 4 inch is as big as bike capable screens get - and thats the Montana. A comparison on the link below highlights the screen size and screen resolution difference (almost 4 times re pixel resolution). Surprisingly, the weight is almost the same. 9.2 oz for the 62s vs 10.2 oz for the Montana. https://buy.garmin.com/shop/compare....eProduct=63801
Sibirsky Extreme 2009 BOOK and DVD available HERE Moroccan Extreme 2011 DVD available HERE www.sibirskyextreme.com |
11-12-2012, 07:19 AM
#515 |
Oddometer: 39
wow that´s a nice journey indeed, just read threw the posts.
11-12-2012, 07:38 AM
#516 |
"Moto Porn"ographer
Oddometer: 3,808
Day 22 - Part 2
The ride began well. Weather was great, track condition was promising. The only thing we missed was Olga from Pervomayskiy.
For the next few days we were covering some of the tracks I did in the Russian Off Road Challenge in 2010 ... so where possible, I was going to take new pics from 2012 to compare the track. If there was one thing I remembered from 2010, there were some superb smooth fast sections on todays track. We should have a real ball. (see 2010 pics of this section here http://www.advrider.com/forums/showp...&postcount=183) ![]() ![]() ![]() ![]() ![]()
Sibirsky Extreme 2009 BOOK and DVD available HERE Moroccan Extreme 2011 DVD available HERE www.sibirskyextreme.com Colebatch screwed with this post 11-12-2012 at 12:42 PM |
11-12-2012, 07:51 AM
#517 |
"Moto Porn"ographer
Oddometer: 3,808
This was also the fast section when in 2010, little Andrey (PG) went head over heels in a somersault at over 80 km/h (50 mph)
See here: http://www.advrider.com/forums/showp...&postcount=342
11-12-2012, 08:10 AM
#518 | |
Nearing the end
Oddometer: 517
How did his soft side bags hold up? |
11-12-2012, 08:15 AM
#519 | |
Oddometer: 219
He is man of iron, 2 months ago it destroyed the motorcycle finally. Itself it is absolutely healthy.
Sakhalin http://www.advrider.com/forums/showt...9#post11817489 Russian north, enduro ride http://www.advrider.com/forums/showthread.php?t=432431 Russian Off-Road Challenge 2010 http://www.advrider.com/forums/showthread.php?t=579487 BMW F800GS KTM 300EXC KTM 690 R +RRP |
11-12-2012, 08:21 AM
#520 | |
Oddometer: 149
Have you ever use TYRE? It is more like google maps vveres Mapsource is less user-friendly, correct me if I'm vvrong. |
11-12-2012, 08:28 AM
#521 | |
Oddometer: 219
only in SASp, you should use and GOOGLE EARTH also. As GOOGLE doesn't allow SAS to load a picture of high resolution. But 2 programs together lead to very good result
11-12-2012, 09:48 AM
#522 |
"Moto Porn"ographer
Oddometer: 3,808
Day 22 - 2010 Revisited - A
Here was a pic from 2010 ...
![]() And here's Terry in 2012
11-12-2012, 09:50 AM
#523 |
Three Wheel Maniac
Oddometer: 401
So nobody created a shortcut in the meantime
But it looks a lot drier the last time
Three Wheel Fever forever Xtankteam™ Proud sponsor of the Sibirsky Extreme Project |
11-12-2012, 09:58 AM
#524 |
"Moto Porn"ographer
Oddometer: 3,808
Day 22 - 2010 Revisited - B
2010 - Myself:
![]() 2012 - Terry:
11-12-2012, 10:40 AM
#525 |
Oddometer: 166
Sorry for the late post, but just to back up what walter said.... Olga really was rather... umm, stunning.
