Old 11-23-2012, 12:02 PM   #811
Colebatch OP
"Moto Porn"ographer
Colebatch's Avatar
Oddometer: 3,806
Originally Posted by ERU View Post
Why do you carry 15 W 50 ? Did you shifh form the standard 10 W 40 to 15W50 ? If yes why ?
Your report is awesome like always.
Cause it was hot
Sibirsky Extreme 2009 BOOK and DVD available HERE
Moroccan Extreme 2011 DVD available HERE
www.sibirskyextreme.com
Colebatch is offline   Reply With Quote
Old 11-23-2012, 12:16 PM   #812
Tracks1
Arctic Rider
Tracks1's Avatar
Oddometer: 75
Originally Posted by Colebatch View Post
Cause it was hot
Since the subject of oil is at hand...How did the Oil Cooler work?
Tracks1 is offline   Reply With Quote
Old 11-23-2012, 02:26 PM   #813
TRadventure
TRadventure's Avatar
Oddometer: 56
Originally Posted by macblach View Post
"The OSCO has a special oil ... but cause Prutser and Beemster arrived with just hand luggage, they couldnt bring any ... I shopped around for some chainsaw oil but couldnt find any in Astana (its the steppe .. what would anyone need a chainsaw for there), so ended up using what I had on me .... Motul glow in the dark 300V 15w50 engine oil"
Well, I use ATF as well. Any concerns what negative effect engine oil or in fact ATF might possibly have on O-rings?
Gearbox OIL 90W
TRadventure is offline   Reply With Quote
Old 11-23-2012, 03:33 PM   #814
sion
sigh-own
sion's Avatar
Oddometer: 2,771
what sort of lube were you using?
Any kind
Of lube will do
Maybe from another
Part of you
From the north
From the south
Take a little slobber
From the side of
Your mouth
Roll it over
Grease it down
Here come that crazy
Screamin' sound..."
Frank Zappa, Keep It Greasy
I say, there's no such thing as a bad day's riding. -metaljockey
whats the value of good gear?: http://www.advrider.com/forums/showp...ostcount=49301
sion is offline   Reply With Quote
Old 11-23-2012, 05:08 PM   #815
Old Kiwi#99
Oddometer: 243
Auto transmissions are full of O ring seals and they get on just fine. Transmissions run a lot hotter than chains, too.
There have been auto trans that ran engine oil, such as the original BMC Mini Auto frinstance, (not the VW based things) and they worked ok too.
Old Kiwi#99 is offline   Reply With Quote
Old 11-23-2012, 05:09 PM   #816
Old Kiwi#99
Oddometer: 243
Originally Posted by TRadventure View Post
Gearbox OIL 90W
you ever tried getting 90w through a small tube?
Old 11-23-2012, 05:58 PM   #817
VFR
VFR's Avatar
Oddometer: 550
Actually it works fine. That's what I use.
Now back to the ride report.....
Larry
If it ain't fun, I don't do it!!!
Stuff - I need more Stuff....
VFR is offline   Reply With Quote
Old 11-23-2012, 06:18 PM   #818
gunnerbuck
I.Hopp.
Oddometer: 3,077
Also unloaded from the van were Terry and my new tyres for stage 2 of the ride. While the others spent the afternoon finalising the bike packing and getting their bikes ready for the steppes of Kazakhstan, Terry and I scooted down the road to fit our new tyres.
I was going with Michelin Desert (classic) at the back and was going to run with a less grippy but more asphalt friendly T63 front and Terry again had his Mitas E09s. The front E09 and T63 were very similar in tread pattern. Come to think of it, the Desert rear and E09 rear were also very similar.
Terry's Tyres:
My Tyres:
I was definitely giving up grip with the T63 on the front compared to the more aggressive Desert front I used in the first third of the trip. I thought it wouldnt matter on the hard pack steppe ground ... but actually I did miss the extra grip of the Desert.
It was a really hot day and by the time we returned to the hotel, it was time for evening meal and drinks with the gang of 5 ... now all ready to head off bright and early tomorrow morning.
Likely the reason for the similarities between the Michelin and Mitas is that they are made in the same factory...
I'm a big fan of the EO 9 rear, especially now that I can get them in a 140/80 x 18 size...
I've got to agree with your observation of lack of aggression on the T 63/EO- 9 front tire: I also found the tread depth too shallow for my liking and the low profile of the tire give a higher risk of pinch flats and dented rims... I won't run these up front anymore ...
This thread is top shelf, keep it coming...
640 A x 2
gunnerbuck is offline   Reply With Quote
Old 11-23-2012, 11:22 PM   #819
tee bee
Oddometer: 166
How did the Oil Cooler work?[/QUOTE]
The oil cooler worked very well, giving us extra oil capacity whilst helping to keep the oil cool as well.
Stephen shefellmeire is in the process of fine tuning them for the market.
tee bee is offline   Reply With Quote
Old 11-23-2012, 11:31 PM   #820
Tracks1
Arctic Rider
Tracks1's Avatar
Oddometer: 75
Oil Cooler
The oil cooler worked very well, giving us extra oil capacity whilst helping to keep the oil cool as well.[/QUOTE]
Was it instrumented for performance understanding?
Old 11-24-2012, 01:08 AM   #821
Pate
Pate's Avatar
Oddometer: 219
For such roads we now use Mitas C02 and C05. For heavy motorcycles of anything more aggressive doesn't exist. BMW GS800 has about 10000 km with them.
Sakhalin http://www.advrider.com/forums/showt...9#post11817489
Russian north, enduro ride
http://www.advrider.com/forums/showthread.php?t=432431
Russian Off-Road Challenge 2010 http://www.advrider.com/forums/showthread.php?t=579487
BMW F800GS KTM 300EXC KTM 690 R +RRP
Pate is offline   Reply With Quote
Old 11-24-2012, 02:15 AM   #822
legasea
Ape on wheels
legasea's Avatar
Oddometer: 54
Mine went down to 6 volts after an 'incident'
So did mine.
Charged with a common electronic tender, came to a steady 13.35v meaning about 90% capacity.
Started a K12 very easily several times. Hope she might come back from a possible dead situation and be ready for a few years service.
In the growing process of migration to the new technology, might serve someone the way I adapted mine.
In this photo is missing another plus. On the front pannel was fitted a "loudspeaker box pressure connector" for GPS and other fused low amp's aplications. There's plenty of room.
Colebatch,
Your rides and reports are most appreciated. A great source of information, entertainment and dream feeding, they are.
Many thanks to you and the gang.
ADV....SE
legasea screwed with this post 11-24-2012 at 02:57 AM
legasea is offline   Reply With Quote
Old 11-24-2012, 05:21 AM   #823
ROD CURRIE
ROD CURRIE's Avatar
Oddometer: 459
Prep to go
After we got the bikes off and I had collected all the various bits -panniers etc -Sambors guys had taken off so they could get all the bikes on the trailer I remembered I didn't have much gas left in the bike after the trip from London to Bas' shop near Amsterdam, where they were trucked from.
The gas station was just a couple of hundred yards from the hotel, so I hopped on and scooted off to fuel up. Just as I was pulling up to the pumps the bike gave a cough and died. My initial thought was "some bugger's siphoned the bike when the trailers been unattended", so I let it roll to the pump and filled up. I then restarted and nipped back to the hotel without further incident. Why am I telling you something so boring? you'll see.
ROD CURRIE screwed with this post 11-24-2012 at 05:22 AM Reason: Typo
ROD CURRIE is offline   Reply With Quote
Old 11-24-2012, 05:38 AM   #824
tee bee
Oddometer: 166
They look like a very good tyre pate,i ought to try them next time.
Old 11-24-2012, 06:16 AM   #825
Putts
Gettin' there.
Putts's Avatar
Oddometer: 10,959
^^^Plot thickening.
"Origin is right here, right now," said Klay. GTomic replied, "Many myth the point."
Putts is online now   Reply With Quote
Times are GMT -7.   It's 03:43 PM.
