12-05-2012, 05:41 PM
#1051 | |
Oddometer: 114
PM Sent re Boots
ROD, sent you a PM
....elronQuote:
"Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways, totally worn out and screaming "WOO-HOO, what a ride!!" |
12-05-2012, 06:48 PM
#1052 | |
"Moto Porn"ographer
Oddometer: 3,797
Much cooler? I dont think so. We werent that hot riding along - when the heat is being transfered from the clothes to the air just as quick regardless of colour of clothes. Its staying still in the direct sun where the colour would be some disadvantage. I mentioned to the guys on several occasions to try not to stop in the sun. Find a patch of shade if we are going to be stationary. If you do that then there is no temperature difference from colour of clothing. If you are in a plastic riding suit of any colour in 35 degrees, you will feel hot when standing still. I remember riding in Morocco with a friend a year ago in 43 degrees (110F) me in black and him in all white. I said to him he must be cooler in the white. He looked at me and said that if I didnt think he was fu@king hot too, then I was kidding myself. Hot is hot, regardless of the colour. I looked into it a bit more when I got back from Morocco and this is my take on it ... I read about an experiment at a car dealer once where they had a bunch of same model cars on a baking hot day parked in the lot in different colours and checked the surface paint temp and internal air temp in the cars. While the surface paint temp of the black sections in the sun was up to 25C hotter than the white, the air temp difference on the other side of the painted surface was just 2 degrees different. I imagine it like that with clothing ... but with clothing you will get much smaller differences. Apparently the outer surface sections of black woven fabric (in bright sunshine) can be up to 6 degrees C hotter than white ... but separating the outer surface of the fabric from your skin are a lot more layers of fabric and an air gap. Using the same dilution as the car scenario, you are only going to get a 0.5 C difference in temp on the inside of the jacket. Less if there is any air flow. Apparently there is a difference, but its much less than on hard or metallic surfaces, and much less than people imagine. There can be a significant psychological factor. Like myself in Morocco, I was feeling damn hot and tried to blame it on the black riding gear. I was looking for an excuse. The reality was the guy in all white was just as hot. It was 43C - thats why I was hot. Bear in mind Bedouins in the Sinai often wear black robes, Tuareg in the Sahara wear dark blue. That wouldnt be possible if the differences were critical. Airflow is key. If colour made a significant difference, Finns and Swedes would historically have dominated the Sahara - their very pale skin and platinum blonde hair would give them an evolutionary advantage in reflecting the direct heat radiated from the sun, but in fact the people that dominate the hot climates and deserts of the world typically have black hair. So again you have to assume the difference can not be significant or that would not be possible. - - - Another thing of interest popped up as I was writing this reply and mentioning bedouins .... Amiram Shkolnik, C. Richard Taylor*, Virginia Finch* & Arieh Borut Department of Zoology, Tel Aviv University, Tel Aviv, Israel *Museum of Comparative Zoology, Harvard University, Cambridge, Massachusetts 02138 Survival in hot deserts has always posed a problem for man; ... It seems likely that the present inhabitants of the Sinai, the Bedouins, would have optimised their solutions for desert survival during their long tenure in this desert Yet, one may have doubts on first encountering Bedouins wearing black robes and herding black goats. We have therefore investigated whether black robes help the Bedouins to minimise solar heat loads in a hot desert. This seemed possible because experiments have shown that white hair on cattle, and white feathers on pigeons permit greater penetration of short-wave radiation to the skin than black. In fact, more heat flowed inward through white pigeon plumage than through black when both were exposed to simulated solar radiation at wind speeds greater than 3 m/s. We report here that the amount of heat gained by a Bedouin exposed to the hot desert is the same whether he wears a black or a white robe. The additional heat absorbed by the black robe was lost before it reached the skin.
Sibirsky Extreme 2009 BOOK and DVD available HERE Moroccan Extreme 2011 DVD available HERE www.sibirskyextreme.com Colebatch screwed with this post 12-07-2012 at 12:33 AM |
12-05-2012, 06:59 PM
#1053 |
Oddometer: 1,082
I may have missed it somewhere, but are you guys riding with paper maps in addition to the Montanas?
Operation: Battle Panda |
12-05-2012, 07:35 PM
#1054 | |
Arctic Rider
Oddometer: 75
BLACK IS FASTER..So ride in BLACK!
Also there a reason engines are painted Black...it has better heat rejection and thus makes the cooling system smaller and lighter too. TO GO FAST IN THE HEAT: YOU MUST WEAR BLACK AND RIDE A BLACK BIKE!
Tracks1 screwed with this post 12-05-2012 at 07:41 PM |
12-05-2012, 09:07 PM
#1055 | |
"Moto Porn"ographer
Oddometer: 3,797
But the bike is too heavy overall, and definitely too top heavy. No ground clearance. The brakes are poor and the suspension is terrible. You can fix the suspension and the ground clearance. Fixing the brakes is harder. Fixing the weight problem is pretty much impossible. Same with the Tenere 660. As far as I know, its the heaviest single cylinder bike on the market, possibly heaviest single ever made. Africa Twin and Tenere 660 are good reliable bikes that will take you anywhere - if you like riding at moderate speeds. They are just going to be much more difficult to ride as fast as we were generally going.
Sibirsky Extreme 2009 BOOK and DVD available HERE Moroccan Extreme 2011 DVD available HERE www.sibirskyextreme.com |
12-05-2012, 10:05 PM
#1056 | |
Oddometer: 22
I sow that your russian buddy in Morocco was wearing an armour under the jacket, but i didn't understand why is he wearing the jacket in the first place in that heat. Looking forward to see the rest of your adventure.
WINDRIDER |
12-05-2012, 10:13 PM
#1057 | |
ADVreader
Oddometer: 121
But I think you have best setup in your bike and is really pretty that dakar front and that rotax engine has the best fuel consumption btw. You have a RR here from yours trips to South America in the red GS650? Or were to read, and the The Tokyo to London Project is my next read Looking forward for the new updates |
12-05-2012, 10:30 PM
#1058 |
мотоциклист
I think way Walter has his bike setup rocks. I have a strong KTM basis, but the sheer reliability of the Rotax engine along with it fuel consumption makes it an ideal adventure bike. If I was doing a solo adventure I would look at duplicating this for myself.
Stories from the Seat Facebook My Photos Cannonball Charity Ride No Four Wheel Drives, No Fixers and No Fricken Whingers |
12-05-2012, 11:42 PM
#1059 |
"Moto Porn"ographer
Oddometer: 3,797
Day 41 Continued
We left the last village and headed off into the unknown.
![]() From here on there was nothing on the map. Nothing on any map. It was going to be about 250 km (160 miles) of Kazakh nothingness. We were headed towards one of the emptiest parts of Kazakhstan, abandoned and overgrown as it was the main soviet nuclear testing site prior to 1991. ![]() We were filled with anticipation. ![]()
12-05-2012, 11:48 PM
#1060 |
"Moto Porn"ographer
Oddometer: 3,797
Terry's air con
Terry cooling himself down, as only he knows how ...
12-05-2012, 11:52 PM
#1061 |
"Moto Porn"ographer
Oddometer: 3,797
Day 41 - the middle of nowhere
While it was incredibly remote, it was also incredibly beautiful in its own way .... way out here. For the first time in the trip so far, we were aware that we were really in the middle of nowhere here. No farms. No people, and the double track we were riding on was not frequently travelled at all. Pretty faint in most parts.
![]() ![]() We came upon a small lake ... ![]() And Prutser decided to have some fun ... splash around in the shallows of the lake to try find a way to cool Rod's bike, which was playing up again ......
Sibirsky Extreme 2009 BOOK and DVD available HERE Moroccan Extreme 2011 DVD available HERE www.sibirskyextreme.com Colebatch screwed with this post 12-06-2012 at 03:33 AM |
12-05-2012, 11:56 PM
#1062 |
"Moto Porn"ographer
Oddometer: 3,797
Boxer stuck
Only it didnt work out quite the way he had in mind ...
![]() So some luggage came off ... ![]() Terry (in the background) and I popped down to see what was going on: ![]() And the traditional deep extraction method began ...
Sibirsky Extreme 2009 BOOK and DVD available HERE Moroccan Extreme 2011 DVD available HERE www.sibirskyextreme.com Colebatch screwed with this post 12-07-2012 at 12:35 AM |
12-06-2012, 01:23 AM
#1063 | |
Oddometer: 460
But if you're looking for a bike that's slow, heavy, with shit susension, comedy brakes and unreliable too (why not go the whole hog?) do your brains in and try a KLR. It's the bike that does everything...badly! ![]() Prepare for a storm of protest from KLR-ers. I'll apologise now. Sorry guys...only winding you up. |
12-06-2012, 01:38 AM
#1064 |
Oddometer: 123
I reccomment the awesome IZH Planeta 5
Remember when SEX was safe and MOTORCYCLES were dangerous ... |
12-06-2012, 02:00 AM
#1065 |
Oddometer: 505
My intentions.......
My intentions with the lake were to find a place to cooldown the KTM after it stopped again in the heat of the day.
When I drove towards it to check it out I noticed my bike was sinking fast. When I turned round it was to late............. lake !!!Luckily this was the only time I needed the tow rope my self.....
BMW R100'91/R80'93/R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920 R100GS'91 (sold) |
