Old 10-19-2012, 04:51 PM   #1
Mr Dual Sport OP
Wanderer
Mr Dual Sport's Avatar
Oddometer: 297
XR 600R Stators
Need a new stator for my 94XR600R. Had a Ricky, it failed due to the insulation coming off the wires and shorting out.
Looking at a Baja Designs rewind, but don't want my bike down.
Prime riding here in Central Oregon right now.
It's running off the stock stator now and they don't want to rewind the Ricky.
Any of you have any dealings with Caltric? Found them on ebay, have never heard of them.
Also waiting for Ricky to return a message I left today regarding the wiring insulation to see if they have had problems and corrected them if they did. No reply yet. Still haven't ruled them out, depends how they handle things.
Need at least 150w prefer 200+
You're never lost till you run out of gas...
The Apocalypse Bike-1994 XR600R-Patches
Originally Posted by HellsAlien View Post
bought a real dual sport bike, XR600R with plate.
Mr Dual Sport is online now   Reply With Quote
Old 10-19-2012, 07:22 PM   #2
elsalvadorklr
Oddometer: 3,974
hey we had the same thing happen
I thought about getting a different brand like the caltric, caltrex, etc..stators which are signifcantly cheaper...
however after talking with mike at ricky stator they offered me a great deal on my second stator from them
like you my exciter coils looked burned and possibly shorted as I was only getting 30 volts at kickover...
so I got a new one and noticed the windings are now completely sealed in epoxy were as my old one was only wrapped in tape and glued
Im hoping this extra protection helps
works great again!
cheers
elsalvadorklr is offline   Reply With Quote
Old 10-19-2012, 07:52 PM   #3
Mr Dual Sport OP
Wanderer
Oddometer: 297
Thanks for the info. I'll wait to talk to someone at Rickys before I make my decision.
Old 10-19-2012, 09:44 PM   #4
Mike the Yank
Oddometer: 87
Question
Hey Christian, what happened when you rewound yours? I'm thinking about tackling it myself if my carb tuning doesn't work.
Thanks heaps for all advice so far.
It's a lot easier to apologise than to ask permission
My Stator rebuild pics http://advrider.com/forums/showthread.php?t=835339
Mike the Yank is offline   Reply With Quote
Old 10-20-2012, 01:13 PM   #5
elsalvadorklr
Oddometer: 3,974
stator
its pretty damn easy...
If you have a stock bike and starting is hard...try jetting first...I reccomended the stock 60 pilot at 2.5 turns out and a 158 or 155main
honda went overboard and jetted too fat, especially after the bike has ran a long time and soots up and loses a bit of compression you will never run clean or crisp with that jetting
if this does not help your bike
then the stator is a cinch...remove allen bolts...and plop cover off, stator is in cover with 3 10mm hex screws...undo that and pull the grommet off the cover and you can rewind or replace your stator easily...
I rewound my stator twice and t worked, what didnt was the epoxy that I could find down here and it eventually cracked and failed however the stator still workd but it would only be a matter of time befire the wires shorted...
cheers
Old 10-30-2012, 10:30 AM   #6
XRider
Almost Lifelike
XRider's Avatar
Oddometer: 1,151
I've had very good luck with BD rewound stators, they make a 200w single output rewind now that I think is the best. I've always had good luck with RS stators also but I've only installed a few (I own a shop). I would never recomend an Electro Sport and I have never dealt with Caltric but the fact that no one has heard of them should give you pause.
XR650R Plated Supermoto
XR628R Plated and highly modified
CR500R Still rips after all these beers
RZ350L Kenny Roberts Special
"If it's hard to do, you're probably doing it wrong."
XRider is offline   Reply With Quote
Old 10-31-2012, 01:02 AM   #7
Mike the Yank
Oddometer: 87
my stator
Mike the Yank screwed with this post 11-01-2012 at 07:18 PM
Old 10-31-2012, 10:52 PM   #8
XRider
Almost Lifelike
XRider's Avatar
Oddometer: 1,151
Originally Posted by Mike the Yank View Post
No pic there mate.
Old 11-02-2012, 05:41 AM   #9
Mike the Yank
Oddometer: 87
2nd try
Uploaded at ImageFra.me
Old 11-03-2012, 02:17 AM   #10
Mike the Yank
Oddometer: 87
I just rewound my own and it works a treat,,,,today. Ordered a Ricky too just incase mine fails. Took 2 days to cut the shit off and rewind. Shoulder gets real tired after a couple hours of winding. I think it tooks about 5-6 hours winding to do it myself. time V money?
Old 11-03-2012, 02:57 AM   #11
Mike the Yank
Oddometer: 87
Old 11-03-2012, 02:59 AM   #12
Mike the Yank
Oddometer: 87
Old 11-03-2012, 03:00 AM   #13
Mike the Yank
Oddometer: 87
Old 11-03-2012, 03:01 AM   #14
Mike the Yank
Oddometer: 87
Old 11-03-2012, 03:03 AM   #15
Mike the Yank
Oddometer: 87
Times are GMT -7.   It's 05:13 PM.
