Old 05-21-2013, 08:58 AM   #1
MILLENNIUM FALCON OP
Oddometer: 245
USD Fork swap.....what should i make this bushing out of????
I am swapping to USD forks and the closest bearing I can find has a 2mm larger inside diameter than the triple tree stem. So i will need to make a bushing to press onto the stem to fit the new bearing. The bushings will be about 17mm in length, (i.d)28mm (o.d) 30mm. I'm just looking for some insight on materials for this bushing. Thank you
MILLENNIUM FALCON is offline   Reply With Quote
Old 05-21-2013, 10:44 AM   #2
MrPulldown
MrPulldown's Avatar
Oddometer: 3,051
Have you considered using your steer stem. Press it out of you stock triple and into the triple of the USD forks. THsi is the way I got mine to fit. If the length is good it should work out. I did need to shave and shim here or there. I was lucky and the bottom of the stem of the two forks where the same size. I have seen people make spacers for the bottom fo the stem.
If you are set on making a spacer for the bearing, I would use some kind of steel. What type; I don't know? Getting the interferance fit right could be tricky.
MrPulldown is online now   Reply With Quote
Old 05-21-2013, 10:50 AM   #3
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,155
Myself I'd use aluminum. Soft, but easier to machine accurately.
However, a 1mm wall bushing is thinner than I could make accurately because it would flex when pushing the lathe bit into it. The wall thickness will need to be within 0.1mm total to get a decent press fit. I'd use a smaller bearing and make a bushing with a thicker wall. 2mm minimum.
YMMV, depending on operator skill.
What size bearing do you need? There may be other options.
Luke is online now   Reply With Quote
Old 05-21-2013, 10:55 AM   #4
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,552
It's going to be pretty tough to machine and press a spacer that big with a 1mm wall diameter. Not saying it can't be done but not your average lathe job being the material has zippo for strength at that point.
How about some 1mm shim stock cut with tin snips? Form it around a steel rod and it should be easy to get that in the bearing then onto the stem.
Or as suggested above, use the existing stem. I did a modified version of both on my latest bike and made a new stem out of 6061 aluminum. The piece of aluminum was $10 and took a couple hours of fitting. The most expensive part of the operation was the M20 tap for the threads on the top where the KTM nut went and even that was only $25.
Post up some pics and measurements and maybe it'll help the creative juices flow.
We're not out here to rough it. We're here to smooth it . Things are rough enough in town.
Nessmuk
Old 05-21-2013, 06:25 PM   #5
Oddometer: 245
Thank you for all the replies and good advice. I will try to post some pictures and specs. as I did into things more. I thought about making a new stem, but I really think I can make these bushings and if all goes well it should be a piece of cake. Ill keep you updated. Thanks again. I appreciate any and all comments.
Old 05-21-2013, 09:15 PM   #6
Lesharoturbo
Nerdly Adventurer
Lesharoturbo's Avatar
Oddometer: 1,168
I am not sure aluminum would be a good idea. With it between the hardened metals of the stem and the bearing, it would be like gum and wear very easily. Also, there may be some galvanic corrosion if there were any moisture in the void around the stem. This may also increase the wear as the aluminum turns to powder.
The best idea is to find a donor stem that will mate the two together.
Individuality is best expressed individually; you are conforming in your non-conformity.
Lesharoturbo is offline   Reply With Quote
Old 05-21-2013, 10:52 PM   #7
Beezer
Oddometer: 5,651
I've done a couple like that.... the easy way is to press out the original stem & fit it to the new bottom triple. braze, flame spray, or weld the stem to fatten it up, then lathe it to the size of the hole in the new bottom. the top bearing can be the oem. the top triple gets shimmed by cutting off a piece of the donor stem & drilling it out to the size of the original stem. (the od is already right for the new top). actually, leave the piece long while in the lathe & cut it after it is on size
Beezer is offline   Reply With Quote
Old 05-21-2013, 11:24 PM   #8
Oddometer: 245
That would work. The only problem I can see is that I would have to bore out the triple clamps because both the top and the bottom clamp have 28mm holes in them (the dia. of the inner race of the bearings.) If I fatten up the shaft to 30mm or get a new stem I will have to modify the clamps to make it work. I made some test bushings tonight. I figure.....since my bearings will get here tomorrow I might as well try it and see if it works. If it gives me trouble I will be looking for a new set of clamps/Stem. The forks I have will work with lots of different clamps and they are the expensive part.
Old 05-22-2013, 01:56 PM   #9
Beezer
Oddometer: 5,651
the original stem is larger diameter than the one in the new USDs? wow... backwards from the ones I have done.
Old 05-22-2013, 02:24 PM   #10
Oddometer: 245
Yeah I found that strange as well. The origional uses a large bearing on the bottom and a tiny bearing on the top.
Old 05-22-2013, 02:35 PM   #11
aposaric
Garden mechanic ;-)
aposaric's Avatar
Oddometer: 270
I just did a complete front end swap on my '90 zx6d. I have put an USD front end from an zx7r. I have had new stem machined from high grade steel, and I bought new koyo bearings, so everything is the same as original on my new front end. The machining had cost me 40$ and new bearings another 30 $, and I think that it is the best and not to mention, the safest way to do this kind of a swap. I just wouldn't be comfortable having some 1 mm bushing standing between nice ride, and the visit to the hospital if it fails and my front wheel starts to wobble about :-)
aposaric is offline   Reply With Quote
Old 05-24-2013, 03:16 PM   #12
Oddometer: 245
pictures
Took it for a ride today.....handled great and felt much better than stock... Ill update you on the bushing wear.
So Far I have a total of $53 in the fork swap. :)
Old 05-24-2013, 05:38 PM   #13
DRjoe
DRjoe's Avatar
Oddometer: 5,063
That is a cool looking motorcycle
DRjoe is online now   Reply With Quote
Old 05-25-2013, 07:40 AM   #14
16VGTIDave
blame Reaver...
16VGTIDave's Avatar
Oddometer: 488
Lookin' good!
Sent from my iPad2
16VGTIDave is offline   Reply With Quote
Old 05-25-2013, 08:09 AM   #15
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,552
I have some Yamaha fork guards off the KYB forks you can have for postage if you want them.
Nessmuk
Times are GMT -7.   It's 10:23 PM.
