10-22-2012, 08:22 AM
#1 |
Oddometer: 1,203
Getting Montana data into Mapsource
I have been using my new Montana for about a month and am still playing around with figuring out the best way to set it up.
I learned the hard way that I need to set archiving to Daily. It looks like archiving clears the Current Track log. Is this correct? I prefer to use Mapsource over BaseCamp for most routine track editing tasks. The only way I have found to get the data into Mapsource is to set the Montana to disc mode and then in Mapsource use File Open to go to the internal storage\Garmin\gpx\archive directory and load in each day's archive and then save each one as a file. I found that if I don't put the Montana in disc mode and try to pull tracks from it in Mapsource using the icon, all I get is the Current log which is empty presumably because the data has been sent to Archive. I like to have all my tracks for a ride in one file. So I then have to open each archive file. Get the track and copy it into the master. I also like to rename each track something more meaningful to me. It looks like in BaseCamp a reasonable thing to do is create a folder for the trip and then drag each archive file into the folder and rename them and then edit them and then Export the folder as a gdp file for personal archiving and for Mapsource access. Anybody have a way of doing this that mimics the simple way a 60 works in Mapsource? Also I usually create waypoints in my planning file when creating tracks for a new trip. I also tend to create a few waypoints on the fly. I haven't learned yet a good way to retrieve these and put them into my final trip file. But I haven't tried much either. |
10-22-2012, 08:40 AM
#2 |
Long Haul Adventurer
Oddometer: 3,167
You're sure making it hard on yourself continuing to use MapSource - but, quite frankly if I had to use the Windows version of BaseCamp, I'd probably stick with MapSource too.
Anyway, using BaseCamp with your Montana connected, you could use the Transfer->Receive from Device... process and import the data directly into a preferred List. This would automatically bring in all of your data - including the Waypoints. Or, if you tend to keep non-event related data on the device, you can still do the drag/drop process. Cheers,
Cheers, Dan |
10-22-2012, 02:14 PM
#3 |
Pretty Dogged
Oddometer: 442
If you really do not want to use BC (eventually you will have to so why not invest a bit of time to figure it out - if the rest of us can do it, you can too!)...................an alternative would be to connect you Montana to your computer and open the Montana drive through My Computer......navigate to the GPX folder in the Montana (inside the Garmin folder) and cut or copy the *.gpx files to your computer and open them with Mapsource.
Can be done, but IMHO learning to use BC is the ultimate solution and one which you will have to do unless you plan on selling the Montana in future. J
2007 BMW Dakar & 2009 Ducati Multistrada entering the middle of the in-land sea called Saskatchewan Canada http://s737.photobucket.com/home/OceanMtnSea |
10-22-2012, 03:35 PM
#4 | |
Oddometer: 1,203
But BaseCamp is just too tedious to deal with most of the time. It is very slow to turn on and off. It gets into modes where it locks up for what seems like minutes at a time redrawing the screen etc etc. And if the Montana is connected it takes several more minutes to load in all the stuff I have on the unit. I am a very impatient person and at 66 years old, that is not likely to change. Mapsource turns on, opens files, writes and reads data to and from the GPS unit, redraws the screen etc. far faster than BC. When I want to do some quick checking and editing, it is a no-brainer for me to choose Mapsource over BC. Your suggested solution for opening Montana files is essentially what I have found I have to do, i.e., open one gpx file at a time and then combine all the data into one gpd file. I suspect in the future I will just use Basecamp for the initial upload of data from the unit into a List and then save the list as a gpd file. |
10-22-2012, 07:16 PM
#5 |
Oddometer: 3,969
Why?
Jerry Counts |
10-23-2012, 05:42 AM
#6 |
Pretty Dogged
Oddometer: 442
It will be just like Windows98 or Windows 2000 or Windows Millenium.............MapSource is not supported anymore and will, over time, be just like Windows 98.
If you are still using Windows 98 (2000 or M) and do not ever plan to get a new computer or OS.....................then yes my comments about switching over to BC are just dumb...............just keep on snoozing and ignore me and the rest of the changing world around you.BTW I still keep MapSource on my desktop, but the numbers of times I ever use it anymore is well.......very rare.
10-23-2012, 08:10 AM
#7 | |
Road Captain
Oddometer: 9,307
Pain in the Butte Ranch Durango, Colorado - Calculated risk or forbidden fruit? |
10-23-2012, 08:14 AM
#8 |
Pretty Dogged
Oddometer: 442
Na.........I'm an old fart too and it is too late for redemption
10-24-2012, 01:31 AM
#9 | ||
Oddometer: 1,560
How large is your 'My Collection' in Basecamp? I've broken up my gps data into several projects each with it's own collection of lists. Then use the Backup & Restore function in Basecamp to switch between them. Prior to switching between projects, do a Backup of it. You can rename the 'BaseCamp.Backup' file to something more descriptive like 'ColoradoTrails.Backup'. If your riding though Peru there's no need to see any data related to your Colorado rides in BC. Quote:
daryl dlh62c screwed with this post 10-24-2012 at 02:18 AM |
10-24-2012, 02:34 PM
#10 | |
Oddometer: 1,203
For a while I was putting lots of stuff in BC. Then I started getting virtual memory errors. So I took a lot of files out. I had loaded a lot of custom maps in from scanning Benchmark pages. I removed all of them except for the ones for the "current" ride. I kind of like what I have in it now, but I am sure there is room for more cutting. But is nice to see all the tracks for a given region at once. I have all the files as gdb because I go back and forth between BC and Mapsource routinely. I have created a few backups, but I will look into maybe using this to limit what is in BC at any one time. |
10-24-2012, 03:38 PM
#11 |
Oddometer: 3,167
According to the dev team, we are going to get some "clean-up" tools in the next update that will hopefully reduce the database bloat. My database jumped from 546MB to twice that size with one software update.
Cheers,
Cheers, Dan |
10-25-2012, 01:51 AM
#12 | |
Oddometer: 1,560
If you import a new gpx file into BC and make any changes to it, a 'Backup/Restore' will not write or save those changes back to that imported file. Only performing an 'Export' will do that. daryl dlh62c screwed with this post 10-25-2012 at 01:57 AM |
