Old 03-21-2012, 06:52 AM   #1
antonac OP
Commuter
antonac's Avatar
Oddometer: 324
Running tires at the sidewall max PSI
Am I the only one who thinks that this completely idiotic, and arguably dangerous? I run my KLR's front at 25-28psi cold with no load where they're rated for mid-30s, and I know of compatible tires with sidewall ratings well into the 40s.
Stamped on the outside of many of your tires is a recommended tire pressure range. (At least an upper limit.) For longest tire life it is my recommendation that you strive to keep them at the higher limit of those recommendations (regardless of what your motorcycle owner's manual might say to the contrary.) Further, this pressure should be determined while the tires are cold - meaning, have not been used for a couple of hours.
http://www.msgroup.org/Tip.aspx?Num=009
They're talking about running this in the winter, no less, and give no other justification than "for longest tire life". On a safety site. I think maybe someone needs to have a word with these guys?
'06 DL650
"Go soothingly on the grease mud, as there lurks the skid demon"
antonac is offline   Reply With Quote
Old 03-21-2012, 07:01 AM   #2
duck
duck's Avatar
Oddometer: 10,403
Despite the URL that site is mostly the OPINIONS of one guy. He posts many controversial things there. (i.e. bullshit)
duck is offline   Reply With Quote
Old 03-21-2012, 07:15 AM   #3
perterra
perterra's Avatar
Oddometer: 7,400
Curious as to why it's dangerous?
I run lower off road, on the highway I pretty much run the max and have for more years than I can remember.
My Father was my maker. Poverty was my maker. Distrust was my maker. I have met them all my life.
IBA 22425
perterra is offline   Reply With Quote
Old 03-21-2012, 07:16 AM   #4
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,863
He's right, whomever he is. Remember the flipping Exploders on Firestones? Nothing wrong with the tire, the low pressure on the door tag and in the owners manual is what got them.
Tires run cooler, last longer and get better fuel economy at the recommended pressure that is stamped on the tire.
Can you get away with less pressure for a better ride and more traction? Yes.
Old 03-21-2012, 07:28 AM   #5
duck
duck's Avatar
Oddometer: 10,403
If I run my front PR2s at the max sidewall pressure then the tire is too hard and the front end wanders all over the place. How is having less control safer?
Old 03-21-2012, 07:34 AM   #6
perterra
perterra's Avatar
Oddometer: 7,400
Why does too hard make it wander? Tire profile?
Never had that issue, I have run at over the max load for days on end. And can tell you from trailer tires, heat build up here can kill a tire quick and I dont mean wear out the tread, I mean letting go all at once.
IBA 22425
Old 03-21-2012, 07:45 AM   #7
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,752
Depends on the tire manufacturer's recommendations and the tire pressure rise with riding.
The 1973 tag on my bike has 25/27 psi for the tire pressures, but that was for tires from that era. My current Avons recommend 32/36 psi and the bike feels better.
One rule of thumb we used to use back when was the "10% rule". Measure the tire pressures COLD. Go out and run them at highway speeds for 10-20 miles and measure the tire pressures HOT. If the pressure increase is less than 10%, your cold pressure is too high and the tire is not heating up enough. If it's more than 10%, your cold pressure is too low and the tire is heating up too much. Adjust the COLD pressures to get a 10% rise. The reason is sidewall flexing. Or so the theory was back then.
Otherwise,
'73 R60/5 Toaster
Bill Harris screwed with this post 03-21-2012 at 10:55 AM
Old 03-21-2012, 08:42 AM   #8
thehomealien
thehomealien's Avatar
Oddometer: 179
This ^^^
Evaluate his statements carefully. What he says about tire pressure may be correct, but if so, it's only by chance. He writes some long, detailed, and seriously confused articles.
thehomealien is offline   Reply With Quote
Old 03-21-2012, 08:50 AM   #9
JamesG
Rabid Poster
JamesG's Avatar
Oddometer: 10,946
Its unwise to make blanket statements.
All tires have different properties and behaviors. And motorcycles react differently to those changes.
Bolded for irony.
JamesG is offline   Reply With Quote
Old 03-21-2012, 09:30 AM   #10
HairBear
I'm a Grandpa
HairBear's Avatar
Oddometer: 777
Am I the only one who thinks that this completely idiotic, and arguably dangerous? I run my KLR's front at 25-28psi cold with no load where they're rated for mid-30s, and I know of compatible tires with sidewall ratings well into the 40s. ?
Odd statement when the sticker on my KLR says 21psi.
"Looking at the cake is like looking at the future. Until you've tasted it what do you really know. And then of course...it's too late."
HairBear is offline   Reply With Quote
Old 03-21-2012, 09:33 AM   #11
daveinva
Oddometer: 556
Hmmm. Since IME Davis backs up his "opinions" with empirical evidence and physics, I'm wondering if you could do the same?
daveinva is offline   Reply With Quote
Old 03-21-2012, 10:23 AM   #12
DAKEZ
DAKEZ's Avatar
Oddometer: 19,719
That guy spews He is right that the tire will last longer. (if you can manage to keep them from washing out and faceplanting you to your death) But it comes at a cost of poor handling and a jolting ride.
Motorcycle tires are made (need to) to flex to provide a proper contact patch and operating temperature. This is especially important while turning.
If all you do is drone down the interstates then go ahead and run higher pressures. If you like the back roads and twisties then go with less (what is recommended for the BIKE)
This is the way to go.
Originally Posted by Bill Harris View Post
One rule of thumb we used to use back when was the "10% rule". Measure the tire pressures COLD. Go out and run them at highway speeds for 10-20 miles and measure the tire pressures HOT. If it's less than 10%, your cold pressure is too high and the tire is not heating up enough. If it's more than 10%, your cold pressure is too low and the tire is heating up too much. Adjust the COLD pressures to get a 10% rise.
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ screwed with this post 03-21-2012 at 11:34 AM
DAKEZ is offline   Reply With Quote
Old 03-21-2012, 11:05 AM   #13
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,270
Suddenly all the topics in faceplant make sense when people randomly slide out on nothing during slow turns. Running your tires at the max PSI on the sidewall is eating up half the traction you'd have otherwise...
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 03-21-2012, 11:31 AM   #14
DAKEZ
DAKEZ's Avatar
Oddometer: 19,719
Bib
Old 03-21-2012, 02:11 PM   #15
randyo
randyo's Avatar
Oddometer: 1,725
the pressure on the sidewwall is NOT the maximum pressure for the tire, it is the pressure at which the tire acheives its maximum weight load
for instance the Karoo T's on my V-strom read "Max Load 716 lbs @ 33psi" go to the Metzler website and they recommend running 38psi F and 42psi R on a V-strom well over the 33psi on the tire
once I questioned Avon why they recommended higher pressures than Suzuki did on my SV650, in their e-mail to me, they answered that it was due to their VBD carcass design AND that for every 2psi under their reccomendation, expect 10% loss in treadlife with no significant increase in traction
E-mail the tire manufacturer ask THEM what you should be running for your bike and your weight
high pressure is NOT a safety issue, airing down for off road is a placebo
RandyO
IBA # 9560
07 VeeStrom
99 SV650
82 XV920R
A man with a gun is a citizen
A man without a gun is a subject
randyo is offline   Reply With Quote
Times are GMT -7.   It's 11:40 PM.
