Go Back   ADVrider > Riding > The Perfect Line and Other Riding Myths
Old 10-23-2012, 07:55 AM   #1
Mambo Dave OP
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,864
What to use to clean black chain lube off of aluminum rims easily?
Obviously I don't want to use an abrasive on aluminum rims to clean them, but I was somewhat shocked that pure strength, then diluted strength to soak, Simple Green didn't really clean much chain lube off of the rear wheel of my DR650.
I'm no neat freak with the bikes since I ride them at least six days a week, but the one time I've thought "Yeah, maybe I should wash the DR..." it didn't really get clean looking with the goop on the rear wheel, sprocket, etc.
Should i go buy a little kerosene? Does WD-40 still cut through modern lubes? (I think the spray-can lube I have at home is PJ1 Black Label).
Mambo Dave is offline   Reply With Quote
Old 10-23-2012, 07:57 AM   #2
Offcamber
Offcamber's Avatar
Oddometer: 1,930
I use Simple Green straight without diluting it. Its safe on the rims and is an excellent grease cutter....
"Beer cans explode with a nice loud pop when they are hit by a Heidenau K60 at 40 miles an hour. Now my bike smells like last call..." Me
Offcamber is online now   Reply With Quote
Old 10-23-2012, 07:58 AM   #3
Wlfman
Wlfman's Avatar
Oddometer: 1,295
Simple Green
I ride not to add days to my life, but to add life to my days.
Those who say it cannot be done should not interrupt the people who are doing it."
"Now and then it's good to pause in our pursuit of happiness and JUST BE HAPPY."
Wlfman is offline   Reply With Quote
Old 10-23-2012, 08:02 AM   #4
urbanXJ
urbanXJ's Avatar
Oddometer: 3,111
WD40 on a rag
Also, the chain cleaner that you hose off with water seems to works really well.
...SPEEDING PAST THE LINE OF GOOD TASTE...
urbanXJ is offline   Reply With Quote
Old 10-23-2012, 08:08 AM   #5
CharlestonADV
I do my own stunts!
Oddometer: 564
I've found that Honda aerosol cleaner / wax works most of the time for grease and bugs. For stubborn stuff I spray WD 40 on a rag.
CharlestonADV is online now   Reply With Quote
Old 10-23-2012, 08:31 AM   #6
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,714
Just use a little diesel / kerosene. It'll cut through caked on asphalt and tar, so it will work great on chain lube as well.
It's cheap and easily obtainable. It won't damage the finish.
Old 10-23-2012, 08:33 AM   #7
DAKEZ
DAKEZ's Avatar
Oddometer: 19,747
Originally Posted by urbanxj View Post
wd40 on a rag.
+1
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 10-23-2012, 09:20 AM   #8
Mambo Dave OP
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,864
Thanks guys.
I'm either surprised the Simple Green is working for some, as I stated it was pretty useless, or that the chain lubes they use are cut by it when PJ1 Black isn't.
Old 10-23-2012, 09:26 AM   #9
DAKEZ
DAKEZ's Avatar
Oddometer: 19,747
p.s. STOP using chain lube. There is NO valid reason to spray "Chain lube on a modern O-Ring/ X-Ring chain. NONE.
Spray a bit of Teflon lube every 400 miles or so to help with the chain to sprocket contact...
All the "won't fly off" chain lubes trap dirt and destroy the the O-rings, cutting chain life in half (or worse)
Bib
Old 10-23-2012, 09:36 AM   #10
Mambo Dave OP
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,864
I'd almost agree with that, but I've seen what the Florida sun does to damage the o-rings on o-ring chains from others' bikes.
From what i understand, coating o-rings with a proper lube keeps them expanded, flexible, and protected from the sun.
Old 10-23-2012, 09:39 AM   #11
Aussijussi
Oddometer: 1,147
I was wondering about that myself, i mean if there is an o ring, the spray wont even reach the joint, which it's supposed to lube
Aussijussi is offline   Reply With Quote
Old 10-23-2012, 09:42 AM   #12
Aussijussi
Oddometer: 1,147
Referring to Dakez post
Old 10-23-2012, 09:48 AM   #13
Mambo Dave OP
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,864
I think of it as trying to keep the stock lube in the chain. If one's o-rings are dry, the lube from the inside will migrate in tiny amounts. Lubed o-rings won't draw lube from the insides.
This may be proven wrong, but in nearly every other application fluids do tend to move to cleaner or dryer areas.
Old 10-23-2012, 10:55 AM   #14
Human Ills
Useful Idiom
Human Ills's Avatar
Oddometer: 24,037
polishing compound.
I like to use ATF
Human Ills is offline   Reply With Quote
Old 10-23-2012, 11:44 AM   #15
crofrog
Oddometer: 1,455
S-100 works really well too.
crofrog is offline   Reply With Quote
Times are GMT -7.   It's 12:25 PM.
