Old 10-23-2012, 01:21 PM   #16
baloneyskin daddy
bikaholic
Oddometer: 2,085
The rollers and side plates are still coming in contact with the sprocket and need some kind of protection from wear which chainlube provides better than teflon or wd40.
baloneyskin daddy is online now   Reply With Quote
Old 10-23-2012, 01:35 PM   #17
JLAW3000
Oddometer: 33
acid
hydrochloric acid based wheel cleaner.... its what the detail shop I use to work at used. Spray the whole rim, let it sit for about 30 seconds and spray it off.... It will get 20 year old stains off, really is amazing. Don't get it on ANY plastic and DON'T breath it in, nasty stuff.
JLAW3000 is offline   Reply With Quote
Old 10-23-2012, 01:42 PM   #18
Wlfman
Wlfman's Avatar
Oddometer: 1,288
Originally Posted by DAKEZ View Post
p.s. STOP using chain lube. There is NO valid reason to spray "Chain lube on a modern O-Ring/ X-Ring chain. NONE.
Spray a bit of Teflon lube every 400 miles or so to help with the chain to sprocket contact...
All the "won't fly off" chain lubes trap dirt and destroy the the O-rings, cutting chain life in half (or worse)
WOW I guess my current chain that is sitting at 25K miles on it (and the two prior that each got 20K+) that I use Chain Wax on after every ride would have lasted 50K??? Actually the chain is still fine, just need new sprockets..
I ride not to add days to my life, but to add life to my days.
Those who say it cannot be done should not interrupt the people who are doing it."
"Now and then it's good to pause in our pursuit of happiness and JUST BE HAPPY."
Wlfman screwed with this post 10-24-2012 at 06:25 AM
Wlfman is online now   Reply With Quote
Old 10-24-2012, 07:22 AM   #19
Adios Pantalones
AdventureDeficitDisorder
Adios Pantalones's Avatar
Location: San Diego, not Mex, but I can smell it from here.
Oddometer: 2,332
I like Krud Kutter or simple green used full strength, an automotive wheel brush works the charm. (think big bottle brush)
I like the acidic wheel cleaners too. Maguires brakedust cleaner is the bomb. pre wet the rim, scrub and rinse promptly. It will etch alum if left to dry.
Adios Pantalones is offline   Reply With Quote
Old 10-24-2012, 02:33 PM   #20
DC2wheels
Castle Anthrax troll
DC2wheels's Avatar
Oddometer: 2,484
IF the wheel has good quality paint or a good quality coating, a rag dampened with acetone works wonders and will not harm a well applied finish.
'92 K100RS
'12 DRZ400
sugarhillctd on the
http://k11og.org/forum/index.php world-wide K bike forum
DC2wheels is online now   Reply With Quote
Old 10-24-2012, 03:19 PM   #21
ttpete
Rectum Non Bustibus
Oddometer: 5,750
Coleman fuel (naphtha) works well and won't attack paint or aluminum.
15 BMW RnineT
09 Kaw Versys
Old 10-24-2012, 06:41 PM   #22
Mambo Dave OP
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,338
Naptha sounds... poisonous. I don't aim to drink it, but ... I take it I should wear rubber gloves when using it?
I'm all for a really fast way to clean the aluminum rims, but I also don't want too harsh a chemical that is going to harm the rubber of the tires, nor the tube if it seeps through the spoke holes.
Mambo Dave is offline   Reply With Quote
Old 10-24-2012, 06:48 PM   #23
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,537
Don't tell the pot growers that Coleman fuel is Naphta, they may like to use it for something. Not that they don't know yet and complain about the price.
Yes to the Naphta, you can also buy that at autobody supply shops, used as a surface prep to remove greases,waxes & sillycones. Rustoleum makes some and to my nose, sure smells like the old Naphta we used so much of back then when we could still buy it by its proper name.
Not buy it rebadged as Coleman Fuel or surface prep for what I think is too much money. But a little goes a long way and sure safe on just about any surfaces.
Have tools, will travel!
Old 10-24-2012, 07:06 PM   #24
Mambo Dave OP
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,338
Wow.
So what is the product name of the Rustoleum product? Or is it still called Naptha?
Not sure I understand which is the cheaper way to buy it.
Old 10-24-2012, 07:29 PM   #25
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,537
Originally Posted by Mambo Dave View Post
Wow.
Coleman fuel I guess. I have been using some old one nowadays, probably not good for the lamps anymore.
Rusto is called...."Wax & Tar remover" . Don't know how cheap that is at almost $10.00/32 fl.oz but went a long way. Can has now been refilled with old Colemen gas, haven't noticed a difference in smell or properties.
Any Kiwis here?....look up Prepsol.
Old 10-25-2012, 08:07 AM   #26
Pantah
Patriot Nation?
Pantah's Avatar
Oddometer: 10,123
I vote wd40 on a rag too, and will never use S100 again. It attacks aluminum parts like swing arms and such. Dulls powdercoats too.
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 10-25-2012, 08:24 PM   #27
shu
Oddometer: 996
WD 40. It's amazing how quickly it cuts through crusty old chain grunge- try it with a stiff brush on that crap on the engine case behind your front sprocket.
..........shu
shu is offline   Reply With Quote
Old 10-25-2012, 09:07 PM   #28
farmboyfz1
Oddometer: 45
Wicked
Originally Posted by dakez View Post
+1
+ 2 on WD-40
farmboyfz1 is offline   Reply With Quote
Old 10-26-2012, 07:09 AM   #29
timsgs
timsgs's Avatar
Oddometer: 53
I always use WD-40 on my aluminum rims to clean the front or rear , it's just so easy.
2007 DRZ400s, 1995 Nighthawk 750
Son, don't force that , get a bigger hammer....
timsgs is offline   Reply With Quote
Old 10-26-2012, 09:18 AM   #30
ttpete
Rectum Non Bustibus
Oddometer: 5,750
WD-40 is mostly mineral spirits, which is what does the cleaning. Mineral spirits are available as generic paint thinner in the paint aisle of any hardware store at a fraction of the cost of WD-40.
15 BMW RnineT
09 Kaw Versys
Times are GMT -7.   It's 06:53 PM.
