Old 10-23-2012, 01:23 PM   #1
YOUNZ OP
Oddometer: 324
Honda won't charge
Just bought a nice 78 Honda 750 hondamatic, cheap, because no alternator output. Runs OK on the battery.
I pulled the Alt. cover and everything looks OK, nothing black or dark brown, wires OK.
I did continuity test of the wires to ground, zero, except the red and blue wire was about 4.0. The yellow to yellow were all about 0.4 even.
Checked continuity of the V reg wires, unplugged, zero on the red and yellows, the two greens were 1.1 to ground.
This alternator does not have brushes, it does have the copper wire coil that is stationary in the center, as is the stator. Nothing checks grounded.
Anybody got any ideas? Thanks
YOUNZ is offline   Reply With Quote
Old 10-23-2012, 01:54 PM   #2
mcma111
mcma111's Avatar
Oddometer: 12,391
Is the battery any good? I don't think a bad battery will accept a charge.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 10-23-2012, 03:36 PM   #3
Grinnin
Forever N00b
Oddometer: 2,837
The 750 SOHC stator has field coils (electro-magnets) instead of permanent magnets. The rotor is magnetized by the field coils and sweeps its magnetic field past the stator windings where far more electricity is generated than what was used to energize the field coils.
The alternator itself has a reputation as being bullet-proof. The voltage regulator and rectifier are more frequent causes of trouble.
The red and green wires go to the rectifier, not to the voltage regulator. Each diode should show near-zero resistance in one direction and near-infinite resistance in the other direction. I recall that the diodes are in stacks, but I really forget what it looks like in there so I'll stop.
The voltage regulator is that squarish "can" near the rectifier. It has only white, green, and black wires (or a green, white, and black sticker by the three spade terminals on the side/bottom of the regulator. The voltage regulator makes the alternator's field coils stronger or weaker depending on the voltage sensed at the regulator. You can take the cover off the regulator and see the coil in there (another electro-magnet). Once that coil gets a certain voltage, it attracts the arm and its contact which puts that wire-wound resistor into the circuit.
mcma111 is correct that the alternator isn't able to overcome a dead battery.
EDIT: I'll go measure the resistance between different terminals of a working regulator and edit this again later this evening.
"The belief that there is only one truth, and that oneself is in possession of it, is the root of all evil in the world."-- Max Born, Nobel Physicist
Grinnin screwed with this post 10-23-2012 at 03:51 PM
Grinnin is offline   Reply With Quote
Old 10-23-2012, 03:51 PM   #4
YOUNZ OP
Oddometer: 324
The battery does seem to be in good shape but the meter reads 11 to 12 volts given some RPM. I trust the hydrometer if I can test each cell. There isn't a corrosion problem as far as I can see, so far. The bike was stored in doors.
I will look next to the regulator and let you know how it goes.
Old 10-23-2012, 04:07 PM   #5
Grinnin
Forever N00b
Oddometer: 2,837
On one working example of a 750 voltage regulator, black and white show about 0.4 ohms. The green spade to either of those is about 35 ohms. Probably lots of variation between examples. Even though you don't have a general corrosion problem, look at the contacts inside the regulator; they are critical to charging.
But I quit too soon (above) on the rectifier. Any yellow wire should be able to pass current to red, but not to green. How this shows up on your meter depends on the polarity of your meter.
Old 10-23-2012, 04:22 PM   #6
YOUNZ OP
Oddometer: 324
Thanks Grinnin, the voltage reg. was mounted in a way I couldn't see the can. I opened it and it looks very clean and OK. There are two small black items that may be fuses on that board near the V reg. I'll check those in the morning. I also see the diode stack. I can see the individual diodes. Thanks again, I'll get back to it in the AM.
Old 10-23-2012, 04:34 PM   #7
Beezer
Oddometer: 5,841
I can help if you post a diagram. also.... meters.... if you are checking diodes the meter needs to be on a special diode scale if it is a digital. And, most meters auto range on the ohm scale & will read "K" ohms or even "Meg" ohms so be careful about what scale it's on because numbers will come out no matter what. and last but not least... many of the manuals for older bikes have electrical readings that were made with analogy meters. the pure resistance measurements (like coil ohms) will be the same but any circuit with a diode or transistor in it will be different. it has to do with how the meters are different and the characteristics of solid state devices
Beezer is offline   Reply With Quote
Old 10-23-2012, 06:04 PM   #8
Advntr
Dilbert
Oddometer: 453
Typically with those motorcycles it's a bad rectifier, which is a Wheatstone bridge type iirc Anyone have a schematic?
He who rides alone rides with nobody...
Advntr is offline   Reply With Quote
Old 10-24-2012, 12:20 AM   #9
Beezer
Oddometer: 5,841
think I found one...
http://oldmanhonda.com/MC/WiringDiagrams/MCwiring.php
bottom of the page CB750A
if this is it then yes, as mentioned above the exciter field is fed by small carbon brushes which are prone to wear. pull the connector from the regulator and measure ohms between the white wire and ground. the rule of thumb is this type of field should have a resistance about 1/2 the system voltage (6 ohms for a 12V system)... the meter should be between 4 and 15 ohms (not K ohms). if so, then the brushes are good and the field coil is good. if less resistance, it may be shorted, if more ohms then it has bad connections, if it reads infinite the circuit is open (broken brush or wire or coil). If this all checks good but the generator does not make good voltage then jump the white wire straight on to the battery plus... this will give full field and voltage will rise with RPM.... be careful, the unregulated output can go to 40 volts or more. if the regulator has contact points, run a business card through the closed contacts to shine them up... if really bad they can be filed but they won't last long until the crust up again
to test the stator, pull the plug on the rectifier. ohm out each pair of the 3 yellow wires. they should read low, like .3 to maybe 2 ohms between each paring. high resistance is wires & connections (bad connections, corrosion). any reading of infinity is an open circuit (bad). also read each lead to ground.... that should be open (no path) if there is a path, the stator is shorted to ground.
to test for a short between windings is harder. the easy way is to connect a light bulb between each pair and run the engine. the light should light and get brighter with RPM up to system value. (or you can measure the voltage... it will be AC, not DC)
to test the rectifier, select a diode scale. pull the connector on the rectifier. put the meter NEGATIVE lead on the rectifier's output lead (that goes to battery plus, looks like a red/yellow wire)... now touch each of the 3 stator input points. they should read continuity,,, usually about 450 ohms, depending on the meter. reversing the leads should read infinite... no path.
now put the POSITIVE meter lead on the rectifier's ground output (looks like there are 2) and touch the meter negative lead to each of the 3 phase inputs... they should read a diode number. reverse the leads and it should read infinite
Beezer screwed with this post 10-24-2012 at 12:28 AM
Old 10-24-2012, 04:02 AM   #10
Grinnin
Forever N00b
Oddometer: 2,837
No brushes in the alternator. None. The field coils and the generating coils are both stationary. The rotor is energized by the magnetic field of the field coils instead of being energized electrically.
I failed to pick up on one measurement by YOUNZ. I cannot tell if you measured the white wire into the alternator (it's on a separate bullet connector, not on the gang plug). The white wire to ground should be 7 or so ohms. The white wire to green wire (another separate bullet connector at the same place) should be the same. Green to ground should be zero (it's grounded on in the alternator), but if you're getting zero on white you have a shorted field coil.
Old 10-24-2012, 08:28 AM   #11
YOUNZ OP
Oddometer: 324
Yep, zero on the white wire to ground! That's the white wire from the copper wire spool in the alternator! Son of a gun, I thought zero to ground was good. Oh well, I guess I'm in the market, if anyone has one. Would rather deal here than on flea Bay. Thanks for all your efforts, guys.
Old 10-24-2012, 10:08 AM   #12
Grinnin
Forever N00b
Oddometer: 2,837
Before shopping you may want to remove it and measure it on the bench. It could be abraded insulation where the wire goes through the case or pinched inside the case. The white and green wires go beside the rotor on the inside so there's extra opportunities for a short in wiring instead of in the field coil itself.
You need to remove a largish side case to look. After the side case is off, the field coil is held in place by th three screws that are prominent on the outside of the alternator housing.
I'll also look to see if I have a spare field coil.
Old 10-24-2012, 01:31 PM   #13
Grinnin
Forever N00b
Oddometer: 2,837
Oops. Sounds like you don't need the directions that I gave in my last post. Please excuse me.
I DID find a spare field coil. 7.6 ohms. The woven wire protection is in good shape, but the tube from inch 5 to inch 8.5 is stiff (but not broken or cracked). I don't know all the differences in engine cases between 750K and 750A. I wanted to let you check the photo to make sure this field coil matches yours. The photo doesn't show well that the rectangular grommet where it exits the case is skewed to exit at an angle.
Old 10-24-2012, 01:49 PM   #14
YOUNZ OP
Oddometer: 324
Isee you are reading from the red wire to the white. I just checked mine in the same manor and got the same reading. Prior, I was testing from white to ground and got zero. So I guess mine is OK also.
Guess I need to go back to looking at the diodes and regulator.
Old 10-24-2012, 02:29 PM   #15
Beezer
Oddometer: 5,841
something in the generator system has to move in order to generate... there a permanent magnet on the crank, rotating in the middle of the field coil yes?
there are a number of brushless designs out there but they all work something like this: a permanent magnet induces into a pickup coil & generates electricity. that electricity goes to a regulator and the regulated output induces the stator.
Edit: looks like the diagram I posted does not quite match.... there is no red wire off the field in the one I posted
Beezer screwed with this post 10-24-2012 at 02:53 PM
Times are GMT -7.   It's 08:37 AM.
