10-25-2012, 03:03 PM
#1 |
World Class Cheapass
Oddometer: 258
Re-Drilling Hub Flange?
Is it possible to have a spoked wheel hub welded (i.e., closing up all the original holes) and re-drilled for a different number of spokes? If so, any idea what something like that would cost? I have a line on a spoked hub for my project bike but it's a 52-hole hub
There's not much selection in rims for that many holes, and those that are available are ultra-heavy chromed-out Harley chopper rims. Not really what I'm looking for.
- Steve GL1000 x2 GL1500 DR350 |
10-25-2012, 05:29 PM
#2 |
Lampin' it
Oddometer: 4,151
What kind of project bike?
I'd be nervous drilling and welding on a hub. I think you would be better served spending some cash and getting one custom made. Something like this? http://www.aaracing.com/DT_Hubs.aspx Or there are some decent candidates in 36 hole variety just depends on what you are using it for. Front rear?
We're not out here to rough it. We're here to smooth it . Things are rough enough in town. Nessmuk |
10-25-2012, 05:45 PM
#3 |
Oddometer: 258
The problem is it's for a shaft-drive CX650, so I'm kinda stuck with the hub since it needs the drive flange. I suppose I could have one custom made, but I imagine the machining for something like that would be more than the cost of every motorcycle I've ever owned.
![]() I have found a couple places that make custom rims, the cost on the rim is more reasonable, so maybe I'll go in that direction instead. I don't want an unsafe wheel.
10-27-2012, 06:42 PM
#4 |
Live easy, Brake Hard
Oddometer: 400
There is a guy who built a cx500 adventure bike. He was in East Texas. He did what you trying to accomplish.
Try Two Wheel Texans Website. http://www.twtex.com/forums/showthread.php?t=46633 Check down to about the 10th post Les
Obsessive compulsiveness always trumps good sense. lesman screwed with this post 10-27-2012 at 06:54 PM |
10-27-2012, 08:26 PM
#5 |
What could go wrong?
Oddometer: 4,960
Thats a tough one, I bet it would be pretty pricey to do and I think it would make me a tad nervous every time it got rode further than a few miles from home.
What are you trying to do, change the rim size? Woodys Wheels may be of some help here. http://www.woodyswheelworks.com/
Kawasaki H1 build thread 71- 450 Honda CL re & re Just another pathetic sheep following the herd |
10-27-2012, 08:37 PM
#6 |
Oddometer: 258
Yeah, the CX650 uses a unique final drive, it's not the same as the 500s, unfortunately. If it were, I'd just use the Comstars as I really like those wheels. I'm trying to get a different size rear wheel since the 650 comes with a 15" rear for some dumb reason. I want at least a 16" rear, preferably a 17" or 18". The spoked rear might be the only way to do that, there is a spoked rear that fits the 650's odd drive flange available on one year of the Honda VT800, but it's a 52-spoke wheel, which means that most of the common rims are out.
I think the best bet if I do end up going with the spoked rear is to have a custom rim made from Buchanan's and lace it to the VT800 hub. I wasn't sure if redrilling the hub flanges was a common thing or not, since I don't have any experience with spoked wheels on motorcycles. Bicycles, sure, but there's a big difference between the two.
10-27-2012, 08:46 PM
#7 |
Oddometer: 1,025
Woody
From what I hear he can do just about anything with wheels. Give him a shout.
http://advrider.com/forums/showthrea...ighlight=woody |
10-28-2012, 08:48 AM
#8 |
Oddometer: 8
If you use a CX650 Turbo rear wheel it will fit the Custom final drive, but you will need to fab up a rear brake system.
http://www.ebay.com/itm/1983-Honda-c...c5e71a&vxp=mtr |
10-28-2012, 08:27 PM
#9 |
Oddometer: 160
Probably a little more extreme than you were thinking, but what about a chain drive conversion?
http://thekneeslider.com/archives/20...wendell-jones/ Don't know if it would be possible/feasible to have some sort of chain drive conversion done with the engine mounted transversely (stock arrangement). This one uses a jackshaft with some sort of 90 degree gear set: http://www.ratbike.org/pages/08soe25.htm
<equipment_list>Insert a list of the crap you own here</equipment_list> cedric screwed with this post 10-28-2012 at 08:33 PM |
10-28-2012, 09:04 PM
#10 | |
De Jo Momma
Oddometer: 8,705
![]() A custom billet hub is really the only answer if you can't work with the existing number of spokes. The shaft drive interface should not be a huge deal. They would have to bore holes into the hub to mate up to your stock cush drive. Make some rubber or soft polyurethane bushings and Bob's your uncle. Of course somebody has to design it and--realistically--the hub alone will probably cost around a grand to have made. |
10-29-2012, 06:52 PM
#11 |
Oddometer: 336
I'm pretty sure a good wheel shop would be able to drill a 52 hole rim for you. You can order some rims blank, without the dimples for the spokes.
http://rallyraid.weebly.com/ |
10-30-2012, 09:02 AM
#12 | |
Lampin' it
Oddometer: 4,151
Buchanans can easily drill that rim for you, those guys are pros. It's probably the cheapest solution out there.
10-30-2012, 12:18 PM
#13 |
Oddometer: 1,025
Final Driven Flange
The Final Driven Flange bolted to the wheel on all the CX500/CX650 except the turbo.
The Final Driven Flange rivets, and has been bolted, to BMW wheels. With some careful comparison and measuring you might be able to bolt that Final Driven Flange to an existing shaft drive hub that has the number of spokes you're looking for. Kai Ju screwed with this post 11-01-2012 at 07:32 PM |
10-30-2012, 04:29 PM
#14 | |
Oddometer: 258
10-30-2012, 08:02 PM
#15 |
Oddometer: 133
Crazy Idea here and may not be possible, but what about just leaving some empty holes on the hub and use a lower hole count wheel?
I would have to have one here to look at so I really can't do the figuring in my head, but it may be possible to just skip a hole every few spokes? |
