Old 10-25-2012, 08:16 PM   #1
LaurelPerryOnLand OP
Oddometer: 3,481
100 THREADS all GS/GSA owners should read.
The "100 Threads" is a compilation of the TOP 100 THREADS submitted by your fellow inmates.
It contains the most common information in an easily SEARCHABLE format that you want/need/ought to know if you own a GS/GSA.
Part 2 can be found here:
http://advrider.com/forums/showthread.php?t=967525
HOW TO SEARCH THE LIST
You can SEARCH the "100 Threads" by using Ctrl+F keys This opens a FIND window which allows you to SEARCH this thread.
For example, enter "Brakes" into the FIND dialogue window and you'll get each instance of "Brakes".
1. HOW DO I CONVERT MY HEADLIGHTS TO HID?
http://advrider.com/forums/showthread.php?t=288538
http://www.advrider.com/forums/showthread.php?t=388828 (1150GSA)
2. WHY IS MY ENGINE NOW RUNNING ROUGH? THE ENGINE IS IDLING HIGHER THAN NORMAL.
http://advrider.com/forums/showthread.php?t=835521
Post #5
3. HOW COME MY HEATED CLOTHING, AIR COMPRESSOR, POWER OUTLET, ETC DOESN'T WORK?
http://www.powerlet.com/learningCenter/iCan
4...IS THERE ANY PLACE WHERE THE MOST FREQUENT QUESTIONS ARE ASKED?
http://advrider.com/forums/showthread.php?t=326162
5. WHERE CAN I GO TO FIND DETAILED WRITTEN INSTRUCTIONS ON HOW TO DO MAINTENANCE ITEMS?
http://advwisdom.hogranch.com/Wisdom/
http://www.amazon.com/R1200-Haynes-S.../dp/1844259250 2010+ Haynes Manual
http://www.amazon.com/R1200-Service-...ds=bmw+r1200gs 2004-2009 Haynes Manual
6. HAS ANYBODY PRODUCED A DVD SHOWING HOW NORMAL MAINTENANCE ITEMS and COMMON REPAIRS ARE DONE?
http://www.jimvonbaden.com/
You got a BMW? Jim's got you covered!
Wethead: 2012 to 2013 R1200 Water Cooled BMW R-Series
Camhead: 2010 to 2012 R1200 Double Overhead Cam BMWs
Hexhead: 2004-2009 R1200 Series BMWs
Oilhead
: 1994-2006 R1100/1150 Series BMWs
7. Is oil consumption normal?
http://www.advrider.com/forums/showthread.php?t=504643
8. WHAT ARE THE PART NUMBERS THAT WILL FIT MY BIKE?
http://www.maxbmwmotorcycles.com/fiche/PartsFiche.aspx
http://www.ascycles.com/BMW-Motorcycle-Parts-Fiche.aspx
http://realoem.com/bmw/select.do
9. WHERE CAN I FIND THE BMW MAINTENANCE SCHEDULE FOR MY BIKE?
http://www.ascycles.com/bmw_motorcyc...schedules.aspx
10. WHERE CAN I FIND TORQUE VALUES? AND...OTHER GS STUFF.
http://www.r1200gs.info/misc/torque.html
11. MY GS/GSA WON'T START IN GEAR...NOW WHAT DO I DO?
http://advrider.com/forums/showthread.php?t=376181
12. WHY ARE MY BRAKES SO GRABBY? SANDPAPER IS THE FIX...YOU SAY?
http://advrider.com/forums/showthread.php?t=838082
13. WHERE CAN I FIND A COPY OF MY BIKE'S OWNERS (RIDER'S) MANUAL THAT CAME WITH THE BIKE? YOU KNOW..RTFM.
http://www.bmw-motorrad.com/com/en/index.html
Click on "Service"
Click on "Rider's Manuals" on left side
14. HOW DO I ADJUST THE VALVES ON MY 10+ DOHC.
http://sanjosebmw.smugmug.com/Other/...9614&k=BmBc5cN
Note from contributor EvilTwin:
I know there is a thread around for this somewhere, but can't find it. I do, however, have the photos bookmarked. This is a pictoral for a '10 and up valve lash check. There is a little more to it than this if you have to change shims. For example, if your shim (semi-sphere) measures as it should and your clearance is off then something else is worn and you will need a new shim of a different size to change the gap appropriately. If the shim does not measure as it should and the gap is not correct, then there is the possibility that you need a new shim of the same size to take up the gap. Provided, of course, the valve lash change needed = difference between actual shim size and spec'd size
15 HOW DO I TIE DOWN MY BIKE FOR TRANSPORTING?
http://www.grassrootsbmw.com/uploads/Tiedown2.pdf
http://advrider.com/forums/showthread.php?t=853572
17. WHAT TOOLS DO I NEED TO WORK ON MY BIKE?
http://www.r1200gs.info/misc/toolkit.html
http://jimvonbaden.com/Tool_Kit.html (JVBaden's suggested list!)
http://advrider.com/forums/showthread.php?t=348022
18. HOW CAN I CHANGE THE LOCKS (RE-KEY) ON MY VARIOS?
http://www.advrider.com/forums/showt...ighlight=rekey
19. HOW DO I INSTALL THE BURNS MOTO (OR OTHER) FUEL BYPASS CABLE?
https://skydrive.live.com/redir.aspx...4609DB3988!130
http://www.youtube.com/watch?v=7c_30Nn0BWE YouTubeVIDEO of above steps
http://www.burnsmoto.com/bmw-fuel-pump-bypass-cable.php Burns Moto website to PURCHASE one
20. WHAT SPARES SHOULD I CARRY?
http://advrider.com/forums/showthread.php?t=839751
http://advrider.com/forums/showthread.php?t=316464
21. HOW TO INSTALL ALTERNATOR BELT:
http://www.youtube.com/watch?v=YzPTPN98x40
22. HOW TO INSTALL AN ODYSSEY PC535 BATTERY:
http://www.advrider.com/forums/showthread.php?t=320214
23. WHAT'S WITH THE REAR DISK BRAKE FLANGE?:
http://www.advrider.com/forums/showt...3#post17330243
24. HOW TO DO BRAKES: PADS:
http://www.bmwmoa.org/forum/showthre...=34541&page=2;
25.HOW DO I BLEED MY BRAKES:
http://advrider.com/forums/showthread.php?t=341305
26. HOW TO BREAK THE BIKE IN HALF: (INTENTIONALLY, OF COURSE)
http://www.advrider.com/forums/showthread.php?t=655998
27. DRIVE SHAFT, U-JOINT REPAIRS:
http://www.advrider.com/forums/showthread.php?t=555869
http://www.advrider.com/forums/showthread.php?t=853018
28. HOW TO REMOVE, REINSTALL DRIVESHAFT & BOOT:
http://www.advrider.com/forums/showthread.php?t=712469
29. HOW TO CHANGE FINAL DRIVE OIL:
http://jimvonbaden.com/R1200_Final_Drive.html
30.HOW TO REPLACE FINAL DRIVE OUTER SEAL:
http://www.advrider.com/forums/showthread.php?t=335870
http://advrider.com/forums/showthread.php?t=880390
31. HOW TO BYPASS THE SIDE STAND INTERLOCK SWITCH:
Method 1. http://advwisdom.hogranch.com/Wisdom/SSIBD.pdf
Method 1. R1200GS
Method 2.http://www.youtube.com/watch?v=kWVEA...FD804CDF3E026C GlobeRider's video
32. HOW DO I CLEAN UP THAT REAR CALIPER?:
http://advwisdom.hogranch.com/Wisdom/BFDRear2.1.1.pdf
33. MY HEADLIGHT SEEMS TO BE OUT OF WHACK...HOW DO I FIX THE AIMING?
http://advrider.com/forums/showthread.php?t=590440
34. WHO'S THE GUY THAT TRUES AND STRAIGHTENS SPOKED BMW WHEELS? I THINK HIS NAME IS WOODY.
http://advrider.com/forums/showthread.php?t=839732
Post #3
http://www.advrider.com/forums/showthread.php?t=70578 Woody's own post!
35. HOW CAN I FIND PAINT THAT MATCHES MY BIKE/YEAR?
http://www.colorrite.com/index.cfm?killnav=1
http://www.bmbikes.co.uk/paintcodes/reds.htm (select your color family)
http://www.oreillyauto.com/site/c/de...1159&ppt=C0253 (Valve covers!)
36. ARE THERE AFTER MARKET OPTIONS FOR TIRE PRESSURE MONITORING?
http://advrider.com/forums/showthread.php?t=626512 (Doran Manufacturing)
http://www.tyredog.com.au/store/ (tyredog TPMS)
http://www.orange-electronic.com/en/...ofit_m202.html (Orange Electronic)
http://www.advrider.com/forums/showthread.php?t=711933 (Orange Electronics review)
37.HOW DO I REMOVE MY ALTERNATOR?
http://advrider.com/forums/showthread.php?t=703446
38. HOW CAN I KEEP MY VARIO SIDE CASES FROM FALLING OFF?
http://advrider.com/forums/showthread.php?t=605203
39. HOW DO I INSTALL OEM GSA DRIVING LIGHTS ON MY GS?
http://advrider.com/forums/showthread.php?t=578964
40. WHERE CAN I GO TO IMPROVE MY RIDING SKILLS?
See LINKS in "100 Part 2)...moved due to space consideration
Part 2: http://advrider.com/forums/showthread.php?t=967525
41. I JUST REPLACE MY 'HALL' SENSOR AND MY BIKE DOESN'T RUN OR STOPS RUNNING WHEN IT GETS WARM. NOW WHAT DO I DO?
http://advrider.com/forums/showthread.php?t=827860
42. HOW DO I INSTALL THOSE ROX RISERS ON MY BIKE?
http://advrider.com/forums/showthread.php?t=341906
http://advrider.com/forums/showthread.php?t=844550
http://advrider.com/forums/showthread.php?t=347359 (Re-routing the throttle cable...afterwards)
43. THE ADV SEARCH ENGINE DOESN'T FIND WHAT I'M LOOKING FOR. WHAT DO I DO NOW?
https://www.google.com/search?num=10...le&btnG=Search
Substitute whatever you're looking for for the word "Motorcycle" and you'll find it!
44. I'M LOOKING FOR A TOOLBOX FOR MY GSA...WHAT ARE SOME CHOICES?
http://www.advmotorrad.com/index.php...&product_id=61
http://twalcomusa.com/ttr-raidbox-r1200gs-adv.html
http://www.bmwgsemotion.com/accessoring.html
http://advgear.net/
http://dsbikeprotection.com/BMW-R120...l#.UOZHGm99LNk
http://www.bmwgsemotion.com/accessoring.html (GS Emotion brand)
http://www.wunderlich.de/shop/de/kofferbox.html (Liquid Cooled Version - Wunderlich)
45. HOW DO I REMOVE MY SIDESTAND? THE BUSHING SEEMS STUCK?
http://www.aksengineering.com/assets..._use_guide.pdf
http://advrider.com/forums/showthrea...=681061&page=2 (See Post #24)
46. ARE OHLINS SHOCKS REALLY THAT GREAT? CAN I INSTALL THEM MYSELF?
http://advrider.com/forums/showthread.php?t=262392
http://www.jimvonbaden.com/Ohlins_Shock_Install.html (Thanks, as always, to JVB!)
47. DO THOSE "WINGLET" THINGS REALLY WORK? WHERE CAN I GET THEM?
http://advrider.com/forums/showthread.php?t=151722
http://www.ceebaileys.com/bmw/1200gs_wind_wing.html
http://www.wunderlichamerica.com/mot...00378-379.html
http://advrider.com/forums/showthread.php?t=974853 2014 GS model?
48. WHERE CAN I BUY A 'THROTTLE CONTROL'
http://www.kaoko.com/default.aspx (Kaoko)
http://throttlemeister.com/ (Throttle Meister)
http://www.crampbuster.com/ (Crampbuster - CB2)
49. I WANT TO MAKE MY BIKE MORE VISIBLE...WHAT ARE MY OPTIONS?
http://www.skenedesign.com/lights/ (Photonblasters)
http://hyperlites.com/ (Hyperlites)
http://advrider.com/forums/showthread.php?t=605428 (LED's in Hanguards)
http://advrider.com/forums/showthread.php?t=831710 (Reflective Decals)
http://www.adventuretech.ca/ (LED Flashing Brake Light -05 thru 07)
http://beemershop.com/Merchant5/merc...uct_Code=RCL08 (LED Flashing Brake Light -05 thru 07)
http://www.touratech-usa.com/Store/1...m-2008-onwards (LED Brake Light -08 onwards)
https://www.kisantech.com/index.php?cat_id=3 (Kisan)
http://www.adventuremotorcycleparts..../TR481001.html (Signal Dynamics Back Off XP Brake Light Signal Module)
http://admorelighting.com/ (Various LED light bars)
http://www.identi-tape.com/solas.html (SOLAS reflective tape)
http://motoreflective.com/products?page=2 (Reflective tape kits made by ADV inmate)
50. HOW DO I REPLACE THE FINAL DRIVE BEARING IN A R1100GS and R1150GS?
http://advrider.com/forums/showthread.php?t=234400
51. I WANT/NEED TO BUY SOME PANNIERS FOR MY BIKE. WHAT ARE SOME CHOICES?
Contact Inmate Kirkster70 (Kirk's hand made panniers)...or...start reading here:
https://www.youtube.com/watch?v=23PD...e_gdata_player
http://www.touratech-usa.com/ (ZEGA's)
http://www.jesseluggage.com/ (Jesse's)
http://cariboucases.com/store/?name=Home (Caribou Cases)
http://micatech.net/ (Micatech)
http://www.happy-trail.com/ (Happy Trails)
http://www.twistedthrottle.com/shop-.../luggage-racks (Twisted Throttle - TRAX)
http://www.xplorermoto.com/bumotR12GS.html (Bumot made in Bulgaria...available in the US)
http://www.projectvnd.com/index.htm (Vern's World Beater's)
http://advdepot.com/globescout (Global Scout's - US Distributor)
http://www.globescout.de/home.php?cat=2 (Global Scout - Mfg website)
http://nomadacases.com/en/catalog/41...mada_PRO_cases (Holan Nomada)
http://www.maxbmwmotorcycles.com/fiche/PartsFiche.aspx (BMW branded, Varios and OEM aluminum) search by bike
52. I LOST THE KEY(S) TO MY BIKE. WHAT DO I DO NOW?
http://www.advrider.com/forums/showthread.php?t=396942
http://www.advrider.com/forums/showthread.php?t=791283
53. MY HEATED GRIPS STOPPED WORKING...NOW WHAT?
http://www.advrider.com/forums/showthread.php?t=770667
http://advrider.com/forums/showthread.php?t=856853
http://advrider.com/forums/showthread.php?t=894188
54. HOW DO I REPLACE MY HEATED GRIPS?
http://advrider.com/forums/showthread.php?t=498496
55. AM I TOO OLD TO OWN A GS? WHAT'S THE AVERAGE AGE OF A GS RIDER?
http://advrider.com/forums/showthread.php?t=844883
56. WHAT ARE SOME OF THE MODS RIDERS HAVE DONE TO THEIR VARIOS?
http://www.advrider.com/forums/showthread.php?t=643013
57. I JUST GOT MY CENTECH AP-1 OR AP-2 FUSE BOX..
HOW DO I MOUNT IT?
WHERE CAN I MOUNT IT?
http://advrider.com/forums/showthread.php?t=537579
58. HAS ANYBODY EVER INSTALLED 'CRUISE CONTROL' ON A GS?
http://advrider.com/forums/showthread.php?t=845862
http://www.advrider.com/forums/showthread.php?t=244690
http://advrider.com/forums/showthread.php?t=803459 (O-ring version)
http://www.mccruise.com/collections/bmw (McCruise)
http://www.excelthrottlecontrol.com/ (Excel Throttle Control)
59. HOW DO I CHANGE A GEARBOX INPUT SEAL?
HOW DO I REPLACE A CLUTCH PRESSURE DISC?
http://www.advrider.com/forums/showthread.php?t=724130
60. HOW DO I REMOVE A GS ADVENTURE PETROL TANK?
HOW DO I REPLACE GS ADVENTURE SHOCKS?
http://www.advrider.com/forums/showthread.php?t=808727
61. WHAT IS CONSIDERED A LOW OR HIGH MILEAGE GS?
http://advrider.com/forums/showthread.php?t=744842
62, MY VARIOS ARE STUCK...THEY DON'T OPEN/CLOSE EASILY. NOW WHAT?
http://advrider.com/forums/showthread.php?t=356840
63. HOW DO I DO A THROTTLE BODY SYNC?
http://www.advrider.com/forums/showthread.php?t=231335
64. I THINK MY FUEL PUMP FLANGE IS CRACKED. WHAT DO I DO NOW?
http://www.advrider.com/forums/showthread.php?t=711467
65. I BROKE THE 'TAB' and/or 'LOCKING MECHANISM' ON MY VARIOS. HOW DO I FIX THEM?
http://advrider.com/forums/showthread.php?t=848307
66. I'M HAVING TROUBLE REMOVING MY SHOCKS FROM MY GSA. HELP!
http://advrider.com/forums/showthread.php?t=848957 (See Post #11)
http://advrider.com/forums/showthread.php?t=856133 (Removing ESA shocks on a GS. pictorial)
67. I WANT TO LINE MY ALUMINUM PANNIERS...EVERYTHING KEEPS GETTING BLACK ALL OVER IT. SUGGESTIONS?
http://advrider.com/forums/showthread.php?p=19339154 Post #204
68. HOW CAN I TELL WHEN MY BIKE WAS ACTUALLY BUILT? AND...A LOT OF OTHER DATA ABOUT YOUR SPECIFIC BIKE!
http://www.bmw-z1.com/VIN/VINdecode-e.cgi
...OR...
http://www.bmwarchiv.de/vin/bmw-vin-decoder.html
69. HOW CAN I ADJUST THE THROTTLE CABLE...IT SEEMS TOO LOOSE?
http://advrider.com/forums/showthread.php?t=850951
70. HAVEN'T FIGURED OUT HOW TO POST PICTURES...CAN YOU HELP?
http://advrider.com/forums/showthread.php?t=919
...or...Click on FULL SCREEN at lower right of window below.
71. MY BIKES STARTS...BUT IDLE'S VERY HIGH AT STARTUP. WHAT'S GOING ON?
http://www.advrider.com/forums/showthread.php?t=721682 Read Post #6
72. WHERE CAN I FIND A WIRING DIAGRAM/SCHEMATIC FOR MY BIKE?
R1200GS:
R11XXGS:
http://advrider.com/forums/showthrea...7#post20364897 Post #23
73. MY ABS UNIT IS SHOT. CAN IT BE REPAIRED? OR DO I HAVE TO BUY A NEW ONE?
http://advrider.com/forums/showthread.php?t=852577
http://advrider.com/forums/showthread.php?t=792722
74. THE FUEL PUMP FLANGE APPEARS TO HAVE A CRACK IN IT...WHAT DO I DO NOW?
http://advrider.com/forums/showthrea...ight=fuel+pump (Read about it)
http://advrider.com/forums/showthread.php?t=852502 (Fix it)
75. I WANT TO SHIP MY BIKE TO EUROPE. WHAT ARE SOME OPTIONS?
http://advrider.com/forums/showthread.php?t=852629 (SEE Post #4 and #20)
76. HOW CAN I TELL HOW OLD THE TIRES ARE ON MY 'NEW TO ME' BIKE?
http://www.tirerack.com/tires/tirete....jsp?techid=11
http://www.tirerack.com/tires/tirete...jsp?techid=172
77. WHAT'S MY BIKE WORTH? WHAT'S THE VALUE OF AN RXXXXGS?
http://www.kbb.com/motorcycles/ (Kelley Blue Book)
http://www.nadaguides.com/Motorcycles (NADA)
http://www.searchtempest.com/ (SearchTempest.com) - searches all Craigslist's in the US
78. HOW DO YOU REPLACE THE EWS RING?
http://www.advrider.com/forums/showthread.php?t=443172
http://advrider.com/forums/showthread.php?t=855501 (Post #2...Good info to know!)
79. I CAN'T GET MY OIL FILTER OFF? HUH? WHAT THE BLANKETY BLANK DO I DO NOW?
http://advrider.com/forums/showthread.php?t=852340 Lots of great alternative suggestions!
80. CAN YOU CONVERT A GS TO THE LARGER GSA FUEL TANK? HOW?
http://advwisdom.hogranch.com/Wisdom...Conversion.pdf
http://advrider.com/forums/showthread.php?t=378053
http://advrider.com/forums/showthread.php?t=760269 (Fuel transfer problems)
http://www.advrider.com/forums/showthread.php?t=521394
81. WHAT'S THE PROPER WAY TO USE THE DIAGNOSTIC PLUG FOR 'POWERING' THINGS?
http://advrider.com/forums/showthread.php?p=20473988
82. HOW DO I KEEP MY VARIO TOP CASE FROM FALLING OFF? IS THERE A FIX?
http://advrider.com/forums/showthread.php?t=686640
83. HOW DO I REMOVE THE CHARCOAL CANISTER FROM MY GSA?
http://advrider.com/forums/showthread.php?t=211357
84. HOW ABOUT A 21" FRONT WHEEL? ANYBODY DONE IT? CLEARANCE ISSUES?
http://advrider.com/forums/showthread.php?t=495376
http://advrider.com/forums/showthread.php?t=663107
http://advrider.com/forums/showthread.php?t=853064 (R1200GS Billet triple clamp project - Vendors)
http://advrider.com/forums/showthread.php?t=862561 (R1200GS Billet triple clamp project - Oilhead Boxers - discussion/feedback)
85. I BROKE MY HEADLIGHT RETAINER CLIP...WHAT DO I DO NOW? IS THERE A FIX?
http://www.advrider.com/forums/showt...php?p=20573586
86. I NEED ONE OF THOSE ABS FUNNELS TO SERVICE THE ABS...WHAT ARE MY OPTIONS?
http://advrider.com/forums/showthrea...4#post20586234 (See Post #17 for DIY parts)
http://www.beemerboneyard.com/abs3funnel.html
87. HAS ANYBODY BUILT A SNORKEL FOR THEIR GS/GSA...YOU KNOW... FOR DEEP STREAM CROSSINGS?
http://advrider.com/forums/showthread.php?t=628545
http://advrider.com/forums/showthread.php?t=811462
http://www.advrider.com/forums/showthread.php?t=520523
88. I WANT A LOUDER HORN. STEBEL IS THE NAME I'VE HEARD. HOW DO YOU INSTALL IT? WHERE TO INSTALL?
WHAT DOES IT SOUND LIKE?
http://www.stebel.it/stebel2012/suon...nautilusCS.swf
http://excelcyclewerkes.com/index_files/Page732.htm
http://www.itrider.net/downloads/R12...cle_Werkes.pdf (2011 GSA w/ESA)
http://www.motorcycleparts-hornig.co...ebel-Horn.html
http://advrider.com/forums/showthread.php?t=927073 (Stebel Horn Install - WC version...GREAT VIDEO from OP!)
89. MY BRAKES LIGHTS STAY ON ALL THE TIME. WHAT'S UP WITH THAT?
http://advrider.com/forums/showthread.php?t=692796
http://www.advrider.com/forums/showthread.php?t=688059
90. LOOKING FOR A SPARK PLUG COIL REMOVER TOOL. WHAT ARE MY OPTIONS?
http://www.marcparnes.com/BMW_Plug_Tool.htm (Marc Parness)
http://stores.promachdualtool.com/-s...val/Detail.bok (ProMach)
http://www.advdesigns.com/bmwspplcapre.html (Adventure Designs)
http://advrider.com/forums/showthrea...2#post20654002 (DIY methods and tools)
91. WHAT'S THE PREFERRED WAY OF MOST RIDERS OF ADJUSTING THE ALUMINUM GS/GSA SEAT RODS?
http://advrider.com/forums/showthread.php?t=684161
92. HOW DO I PROPERLY BED-IN NEW BRAKE PADS?
http://advrider.com/forums/showthread.php?p=20668739
93. I SEE THE OIL FOAMING IN THE SIGHT GLASS...SHOULD I BE CONCERNED?
http://advrider.com/forums/showthread.php?t=858913
94. WHAT THIS THING CALLED A "GS911 FAULT CODE READER" ACTUALLY DO? DO I NEED ONE?
http://advrider.com/forums/showthread.php?t=189421 (Many responses...discussion)
http://advrider.com/forums/showthread.php?t=861221 (More responses)
95. WHAT'S THE BEST WAY TO CONNECT AUDIO TO YOUR HELMET HEADSET? WIRED OR BLUETOOTH?
http://advrider.com/forums/showthread.php?t=874440
96. I WANT TO EXTEND MY MIRRORS FURTHER OUTWARD. WHAT ARE MY OPTIONS?
http://www.wunderlichamerica.com/mot...60446-447.html (Wunderlich, Black/Silver)
http://store.bobsbmw.com/product/zte...ers-r1200gsrst (ZTechnik)
http://advrider.com/forums/showthread.php?t=643655
97. I'D PREFER A DIFFERENT SEAT THAN THE OEM (READ AS...."I HATE MY SEAT!") WHAT ARE SOME OTHER CHOICES? (The #1 complaint)
http://www.day-long.com/gallery_BMW.html (Russell Day Long)
http://www.sargentcycle.com/bmwwsr12gs.htm (Sargeant)
http://www.corbin.com/bmw/r12gs.shtml (Corbin)
http://www.rickmayercycle.com (Rick Mayer)
http://mayergonomic.com/ (Bill Mayer)
http://www.touratech-usa.com/Store/3...ure-Oil-Cooled (Touratech)
http://www.advdesigns.com/safrseforbmw.html (Adventure Designs)
http://www.wunderlichamerica.com/mot...61164-199.html (Wunderlich Ergo seat)
98. LOOKING FOR A TANK BAG FOR MY GS. WHAT ARE MY OPTIONS?
http://advrider.com/forums/showthread.php?t=337145 (Tank Bag Discussion)
http://www.marseeproducts.com/ (Marsee)
http://www.twistedthrottle.com/shop-...acks/tank-bags (Bags Connection and others)
http://shop.sw-motech.com/en/by+prod...bags/index.htm (SW-Motech)
http://www.touratech-usa.com/Store/1...Bags-Tail-Bags (Touratech)
http://wolfmanluggage.com/index.cfm?...&category_id=8 (Wolfman)
99. HOW DO I INSTALL THE DISPATCH 1 POWER DISTRIBUTION SYSTEM?
http://advrider.com/forums/showthread.php?t=870449 pictorial on the R1200GS
http://advrider.com/forums/showthread.php?t=870941 pictorial on the R1200RT
http://arborealsystems.com/Arboreal_Systems/home.html
100. HOW MUCH OIL SHOULD I PUT IN WHEN I CHANGE IT? (#1 most common question)
http://advrider.com/forums/showthread.php?t=869667 (See Post #4)
101, MY GEAR INDICATOR IS 'INDICATING' THE WRONG GEAR. HOW DO I FIX THIS?
http://advrider.com/forums/showthread.php?t=824627
102. What alternate foot pegs and lowering options are available for the R1150GS and R1200?
http://advrider.com/forums/showthread.php?t=878283
103. How much fluid should I put in my final drive?
For R1200 :Answer is 180ml. It is also for a refill, not a clean and new FD. That is 220. Source: JVB .
For R11XXGS: On the 1100/1150 just fill to the bottom of the threads. Source: JVB
104. WHERE CAN I FIND THE 600, 6K AND 12K SERVICE SCHEDULES FOR THE WATER COOLED GS?
https://skydrive.live.com/redir.aspx...4609DB3988!336 (The BMW Factory ones)
http://1drv.ms/1dddn7q Service schedules PLUS relevant TORQUE VALUES from inmate Marchyman
105. WHERE CAN I FIND THE RIDERS (OWNERS) MANUAL FOR THE WATER COOLED GS...USA VERSION?
https://skydrive.live.com/redir?resi...JRulshujDoroAU
106. MY FINAL DRIVE HAS DIED...CAN IT BE REPLACED WITH THE LATEST FD...UP TO THE 2012 VERSION?
http://advrider.com/forums/showthread.php?t=711453
http://advrider.com/forums/showthread.php?t=904234
107. HOW DO I REPAIR THE GEARS IN MY VARIO TOP/SIDE CASES?
http://www.advrider.com/forums/showthread.php?t=908012
108. WHERE CAN I FIND THE TORQUE AND FLUID LEVEL SPECS FOR THE WATER COOLED GS?
https://skydrive.live.com/redir?resi...I9ZxPyn3L2QJ-c
109, WHAT FARKLES ARE MADE SPECIFICALLY FOR THE WATER COOLED GS?
http://advrider.com/forums/showthread.php?t=891023
110/ CAN YOU REPLACE THE OEM FOG LIGHTS WITH led? IF SO...HOW?
http://advrider.com/forums/showthread.php?t=652646
111. CAN YOU INSTALL OEM GSA LIGHTS ON A GS?
112. WHAT BASIC SKILLS DO I NEED TO RIDE 'OFF-ROAD'?
http://www.youtube.com/watch?feature...&v=Re2A9UJzSBw
113. CAN YOU MOUNT A CB RADIO ON A GS?
http://advrider.com/forums/showthrea...ighlight=RADIO
114. WHAT THE HECK IS "CANBUS" and HOW DOES IT WORK?
http://bmwmotorcycletech.info/canbus.htm
http://www.bmwra.org/otl/canbus/
115. WHAT ARE THE STATE MOTORCYCLE LAWS WHERE I LIVE?
http://www.americanmotorcyclist.com/...tate-Laws.aspx
116. WHICH IS BETTER...SPOKE OR CAST WHEELS?
http://advrider.com/forums/showthread.php?t=74319
http://advrider.com/forums/showthread.php?t=733032
http://advrider.com/forums/showthread.php?t=619644
http://advrider.com/forums/showthread.php?t=181217 (WEIGHT COMPARISON)
117. WHAT ARE MY CHOICES FOR TIRES FOR MY GS?
http://www.advrider.com/forums/showt...ht=mefo&page=2
118. ANYBODY MOUNT A ROWE ELECTRONICS PDM60 ON THEIR LC OR WC?
http://advrider.com/forums/showthread.php?t=928394
eXCELLENT PICTORIAL!
119. HOW DO YOU REMOVE/INSTALL THE SWINGARM?
http://www.youtube.com/watch?v=BsS8y...layer_embedded
Another excellent step-by-step video pictorial of how to do it!
Thanks inmate: *SHAG*
120. HOW TO YOU INSTALL LED TURNS SIGNALS ON A NON-WC/LC GS?
https://www.youtube.com/watch?v=nP8HPPKaFsQ
Nice...easy...peasy video from our friends at MAXBMW!
121. HOW DO I SERVICE THE ABS SERVO BRAKE SYSTEM? YOU KNOW = 'WHIZZY' BRAKES. (Prior to 2007)
http://www.youtube.com/watch?v=YLM25NYvlas pART 1
http://www.youtube.com/watch?v=a1ktxY_bgQY pART 2
A couple nice step by step videos!
122. I''M LOOKING FOR SOME HANDLEBAR ADJUSTER LEVERS. WHAT ARE MY OPTIONS?
http://www.wunderlichamerica.com/mot...e/8160111.html Wunderlich version
http://www.advrider.com/forums/showt...php?p=21306205 Berger Tools version
http://www.mcmaster.com/#adjustable-...andles/=p74api McMaster versions
123. MY 12 VOLT BATTERY IS SHOWING 12.00 VOLTS ON A MULTIMETER...WHY WON'T THE BIKE START?
http://www.mmbalmainauto.com.au/PDF/State_of_charge_12_volt_batteries.pdf ( Batteries 101)
124. THE BIKE WON'T START IN GEAR....DOES THE CLUTCH OR BRAKE LEVER SWITCH NEED ADJUSTING?
http://www.advrider.com/forums/showthread.php?t=376181
125. WHERE THE HECK IS THE ENGINE NUMBER ON THE BIKE?
http://advrider.com/forums/showthread.php?t=940727 (1200
)http://advrider.com/forums/showthread.php?t=35998 (1150)
http://advrider.com/forums/showthread.php?t=306082
126. MY SPARK PLUG SOCKET IS STUCK IN THE HEAD...WHAT DO I DO NOW?
http://advrider.com/forums/showthread.php?t=338290
http://advrider.com/forums/showthread.php?t=52818
Or...simply use the socket that came with the OEM tool kit
127. WHERE AND HOW CAN I MOUNT A GO PRO CAMERA?
http://advrider.com/forums/showthread.php?t=815150
http://advrider.com/forums/showthread.php?t=751276
http://advrider.com/forums/showthread.php?t=577008
128. WHATS UP WITH THE OFFICIAL BMW FUEL PUMP RECALL FOR THE UNITED STATES? WHO'S AFFECTED? HOW DO I GET IT FIXED?
http://advrider.com/forums/showthread.php?t=945705
ALSO, LETTER FROM BMW TO NHSTA WITH DETAILS
https://skydrive.live.com/redir?resi...nt=file%2c.pdf
CANADIAN VERSION OF NHSTA RECALL:
http://blog.motorcycle.com/2013/12/1...al-fuel-leaks/
http://wwwapps.tc.gc.ca/Saf-Sec-Sur/...eng&rn=2013442
SOUTH AFRICA
http://www.wheels24.co.za/BikesQuads...in-SA-20140106
129. WHICH IS BETTER - CAST WHEELS OR SPOKE WHEELS?
http://advrider.com/forums/showthread.php?t=743194
130.I CAN'T SEEM TO GET THE SPLINES ON THE FINAL DRIVE TO PROPERLY RE-ALIGN AND MATE AFTER SERVICING.
WHAT'S THE TRICK TO GETTING THEM BACK TOGETHER
http://advrider.com/forums/showthread.php?t=704832
131. WHERE'S THE BEST PLACE TO FIND A SOURCE FOR SWITCHED POWER?
http://advrider.com/forums/showthread.php?t=953179 2013+ WC
http://advrider.com/forums/showthread.php?t=794407 2012 DISCUSSION
http://advrider.com/forums/showthread.php?t=641794 DIAGNOSTIC PLUG ALTERNATIVE
http://advrider.com/forums/showthread.php?t=752846 1100GS DISCUSSION
http://advrider.com/forums/showthread.php?t=365594 NO SPLICE OPTION...MOLEX CONNECTOR INTO DIAGNOSTIC PLUG
132. I NEED SOME CRASH BARS. WHAT ARE MY OPTIONS?
http://advrider.com/forums/showthread.php?t=953633
Links to all manufactuers: Hepco-Becker, Wunderlich, Touratech, AltRider,
MotoGeist, Illum Works
SW-Mototech,
133. GOT A LEAK IN MY TIRE..SHOULD I PLUG IT OR PATCH IT?
http://advrider.com/forums/showthread.php?t=626119 Pros/Cons of each
http://advrider.com/forums/showthread.php?t=234511 Discussion of options
http://www.jimvonbaden.com/Tire_Plugging.html JVB pictorial on how to plug
134. DOES ANYBODY HAVE A LIST OF MOTORCYCLE SALVAGE DEALERS THAT PART OUT GS /GSA?
beemerboneyard.com
duncansbeemers.com
re-psycle.com
bobsbmw.com
More
Used Parts as well as a section on Parts Sales and/or Service
http://bmwmoa.org/forum/showthread.p...rces-and-Links
135.WHAT'S THE STORY ON THE 2013/2014 MODEL YEAR SIDE STAND SWITCH RECALL? AM I AFFECTED?
http://advrider.com/forums/showthread.php?t=961649
LaurelPerryOnLand screwed with this post 10-24-2014 at 06:28 PM Reason: link to FAQ
LaurelPerryOnLand is offline   Reply With Quote
Old 10-26-2012, 04:08 AM   #2
The Evil Twin
Boxer Freak
The Evil Twin's Avatar
Oddometer: 474
What? No oil thread??
CCS #132 Sponsors: DC-Moto.net, Amsoil, Manassas Honda Kawasaki, MARRC
2014 RCGT #1, Superbike #2 OA Mid Atlantic
2013 Amateur of the Year
2013 RCGT #6 OA Mid Atlantic
The Evil Twin is offline   Reply With Quote
Old 10-26-2012, 04:14 AM   #3
TomDac
TomDac's Avatar
Oddometer: 310
When will my FD explody?
Hayward, CA
2006 R1200GSA - aka "Gretel"
http://www.flyv65.com
TomDac is offline   Reply With Quote
Old 10-26-2012, 04:50 AM   #4
mb90535im
'05 R1200 GS
mb90535im's Avatar
Oddometer: 5,242
My legs are too short, waaaaaaa, waaaaaa !!
(search for seat height, lower, Napoleon, inseam, etc,)
"Dang man I'm impressed." - Willy-B
"Are you OK? ... Are you sure you're OK?" - Honcho
"Disturbing and funny, all at the same time." - MrTwisty
mb90535im is online now   Reply With Quote
Old 10-26-2012, 04:54 AM   #5
rcliffor
rcliffor's Avatar
Oddometer: 122
Gotta have a tire thread, the problem is which one?
2015 CTX700D
rcliffor is offline   Reply With Quote
Old 10-26-2012, 07:29 AM   #6
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,559
Too bad we can't organize the threads based on category by BMW part category.
01-Literature
11-Engine
12-Engine Electrics
13-Fuel Preparation
16-Fuel Supply
17-Cooling
18-Exhaust System
21-Clutch
23-Transmission
31-Front Suspension
32-Steering
33-Rear Axle & Suspension
34-Brakes
35-Pedals
36-Wheels
46-Frame, Fairing, Cases
51-Vehicle Trim
52-Seat
61-Electrical System
62-Instruments Dash
63-Lighting
65-GPS, Alarm & Radios
71-Equipment Parts
77-Accessories
Aftermarket exhaust, What seat do I get, Panniers, Driveshaft, Spline lube, GPS wiring, Shift lever, foot pegs, How do I check my oil quantity. What car parts can I use. What color paint is my engine painted, Who is tagesk, What is a sticky, What is GSpot Frequently Asked Questions/LOOK HERE FOR FORUM CONTENTS GSpot FAQ
scooteraug02 screwed with this post 10-26-2012 at 10:50 AM
scooteraug02 is offline   Reply With Quote
Old 10-26-2012, 08:25 AM   #7
Wdwrkr
Wdwrkr's Avatar
Oddometer: 2,013
but ummm which tires should i use
Wdwrkr is offline   Reply With Quote
Old 10-26-2012, 03:03 PM   #8
Wdwrkr
Wdwrkr's Avatar
Oddometer: 2,013
Originally Posted by LaurelPerryOnLand View Post
And...your suggested THREAD or LINK is?
I will try to tap into links tomorrow. At home I only have the iPad and I couldn't begin to figure it out on this thing. Sadly there are limits to my abilities.
Old 10-26-2012, 05:27 PM   #9
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,543
Needs more oil thread..
Oh..and exhaust makes my bike run like shit thread..
xcellent effort LPOL
"Ignorance is a powerful tool when applied at just the right time..sometimes even surpassing knowledge.." EJ Potter
Bill-66 is online now   Reply With Quote
Old 10-27-2012, 02:56 AM   #10
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,386
how about an accessories / farkles thread?
"The early bird gets the worm, but the second mouse gets the cheese." Unknown
'12 BMW R1200GSA '02 BMW R1100S BCX
macadamia is offline   Reply With Quote
Old 10-27-2012, 06:47 AM   #11
The Evil Twin
Boxer Freak
Oddometer: 474
Will you post more so I can watch your avatar?
Old 10-27-2012, 01:08 PM   #12
macadamia
XK Red 27 Technique
macadamia's Avatar
Oddometer: 1,386
er, no...
Old 11-04-2012, 06:56 AM   #13
The Evil Twin
Boxer Freak
Oddometer: 474
I know there is a thread around for this somewhere, but can't find it. I do, however, have the photos bookmarked. This is a pictoral for a '10 and up valve lash check. There is a little more to it than this if you have to change shims. For example, if your shim (semi-sphere) measures as it should and your clearance is off then something else is worn and you will need a new shim of a different size to change the gap appropriately. If the shim does not measure as it should and the gap is not correct, then there is the possibility that you need a new shim of the same size to take up the gap. Provided, of course, the valve lash change needed = difference between actual shim size and spec'd size.
Old 11-04-2012, 01:51 PM   #14
Tomcat503
Usually Just Lurking
Tomcat503's Avatar
Oddometer: 65
Here are two that I've bookmarked and found useful:
How to Rekey Vario Panniers - A Pictorial:
What tools do I need to work on my bike?
BTW, great idea for a thread.
2006 R1200GS
2007 Moto Guzzi Griso
Tomcat503 screwed with this post 11-04-2012 at 04:01 PM
Tomcat503 is offline   Reply With Quote
Old 11-04-2012, 05:36 PM   #15
The Evil Twin
Boxer Freak
Oddometer: 474
Awesome! Bookmarked this one for my Christmas list
Times are GMT -7.   It's 07:22 AM.
