Old 10-27-2012, 09:13 AM   #1
SR1 OP
Back in S. Korea
SR1's Avatar
Oddometer: 4,469
Can't find the right heated gear cable...
I have an older Heat Troller hard wired into the bike. It has an SAE output. I have a new Gerbings jacket that is apparently "dual wired" so I have to power jacket and gloves separately.
So, I need a cable that is SAE on one end, and has two coax (females) on the other.
Where do I get this cable? Surely I'm not the only one that needs one of these.
Powerlet doesn't seem to have it...
My TAT trip in 2014: http://advrider.com/forums/showthread.php?t=998193
SR1 is offline   Reply With Quote
Old 10-27-2012, 09:17 AM   #2
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,624
Can you do something like this?
And then this?
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 10-27-2012, 08:56 PM   #3
SR1 OP
Back in S. Korea
SR1's Avatar
Oddometer: 4,469
Yes, but the downside is that every connection is another possible place it'll disconnect. I would like to keep it as simple as possible.
Old 10-30-2012, 09:18 AM   #4
James Bond
Tight is best
James Bond's Avatar
Oddometer: 69
Shrink wrap the connection, that will make it pretty permanent.
09 KTM 530
11 BMW 1200GS
James Bond is offline   Reply With Quote
Old 11-01-2012, 07:05 AM   #5
SR1 OP
Back in S. Korea
SR1's Avatar
Oddometer: 4,469
Not a bad idea, actually. Thanks!
Old 11-01-2012, 07:22 AM   #6
xcflyn
xcflyn's Avatar
Oddometer: 1,152
I just went through this yesterday. Same exact situation. I ended up doing what was suggested, I cut the female coax off one and purchased the old two pin and soldered them together. I used two different sized heat shrink tube so I could double it up. Worked out great, gave it the walk away from bike while plugged in test the very first ride. Hard to get used to that plug again, I have not used one in a couple years.
xcflyn is offline   Reply With Quote
Old 11-01-2012, 10:46 AM   #7
Flashmo
Whatever...
Flashmo's Avatar
Oddometer: 2,617
That's how I unplug myself 90% of the time...
Flashmo is offline   Reply With Quote
Old 11-02-2012, 04:42 AM   #8
Speedo66
Transient
Oddometer: 6,863
Talk to this guy, he should have everything you need. http://034fdb9.netsolhost.com/bbblog1/category/coax/
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 11-03-2012, 12:32 AM   #9
omen
omen's Avatar
Oddometer: 13
Jim at Eastern Beaver will have what you want, if he doesn't he will make it for you.
Good guy to deal with too.
http://www.easternbeaver.com/Main/main.html
omen is offline   Reply With Quote
Old 11-07-2012, 06:10 AM   #10
SR1 OP
Back in S. Korea
SR1's Avatar
Oddometer: 4,469
Thanks guys. Sorry for the late response, the wife and I are busy having a baby!
I appreciate the recommendations!!!
Old 11-08-2012, 12:53 PM   #11
SR1 OP
Back in S. Korea
SR1's Avatar
Oddometer: 4,469
So far, he does not. I'll reach out to the Eastern Beaver guy.
Old 12-11-2012, 09:49 PM   #12
SR1 OP
Back in S. Korea
SR1's Avatar
Oddometer: 4,469
Follow up:
Eastern Beaver wouldn't make it either.
On a lark I called Powerlet. They asked me to send in a drawing, which I did. A week and $34 later I had a 1 meter long Y cable exactly the way I wanted it.
Thanks Powerlet!
Times are GMT -7.   It's 11:37 AM.
