Old 12-05-2012, 11:55 PM   #61
RZRob
RZRob's Avatar
Oddometer: 1,522
Vapor Guard
Can I recommend the aluminum guard for the Vapor?
RZ Rob
RZRob is offline   Reply With Quote
Old 12-06-2012, 12:46 AM   #62
G19Tony OP
G19Tony's Avatar
Oddometer: 410
RZ Rob
I want to do that, but nothing will fit on the 80.
I will have to come up with something. That plastic thing will not last.
BMW F800GT, Hodaka Dirt Squirt, Honda CL70, Honda CT70, Honda Grom.
Nothing's too cruel if it's funny enough.
G19Tony screwed with this post 12-06-2012 at 12:51 AM
G19Tony is offline   Reply With Quote
Old 12-07-2012, 09:11 AM   #63
Reconstructed
Oddometer: 246
Subscribed
This is just too cool. I have been wanting to do the same thing with a 100 for a long time now.
Awesome!
Reconstructed screwed with this post 12-08-2012 at 03:48 PM
Reconstructed is offline   Reply With Quote
Old 12-07-2012, 05:55 PM   #64
dirtydeeds
I'm alive.
dirtydeeds's Avatar
Oddometer: 2,564
Blast you!
Just saw that Vapor is made for the KLX as well.
I can't seem to find a deal on one. Can I ask where you sourced yours from?
990SMT, 640A, TXC450, TE510, ATC350X, ATC200ES, 550MXC, BW200. Need more space in garage.
dirtydeeds is offline   Reply With Quote
Old 12-08-2012, 01:58 AM   #65
G19Tony OP
G19Tony's Avatar
Oddometer: 410
Originally Posted by dirtydeeds View Post
Blast you!
I purchased mine from Trail Tech. $134. I've seen them for less than $100 on Ebay. I called to make sure I was getting the right one for my application, as they don't make one specifically for the CRF80. Keep looking, the good deals are out there.
I may wind up getting the speedo that is specifically for the Baja Designs kit. It will connect right up to the harness.
Old 12-08-2012, 02:09 AM   #66
G19Tony OP
G19Tony's Avatar
Oddometer: 410
Installed left side controls today.
I sorted out how to mount the rear brake light switch with an Adel clamp, and was able to just hook the other end of the spring around the brake rod. I think it will work ok.
Old 12-21-2012, 08:26 PM   #67
G19Tony OP
G19Tony's Avatar
Oddometer: 410
The ADV 80 is done.
I finished it last night. It's at the shop right now getting some adjustments done, and waiting on a part from Trail Tech. The front brake cable was too short, so they made up a new one for me. The throttle didn't feel right. I had put the carb spring on the brake, and the brake spring in the carb. I had a 50/50 chance. With the tall seat and handle bar risers, the bike sits great. I'm not anticipating any problems getting it plated. I learned a lot about maintenance with this project. I'm going to get right into finishing my 72 Trail 70. That's been a project for the last 4 years. Next will be taking my 74 Hodaka Dirt Squirt down and repainting the frame the correct color, refreshing the engine and generally making it look new. I'm having a blast with these projects.
Old 12-21-2012, 09:18 PM   #68
MacNoob
MacNoob's Avatar
Oddometer: 1,585
That's great! Congrats on a beautiful job. Post a link to your Dirt Squirt resto thread here so we don't miss that one...
"Ignorance, you see, can be out thought. Arrogance can be outmaneuvered. But ignorance and arrogance combined are unassailable."
82 Honda C70, 71 Honda CL175, 08 Kawasaki KLR650, 85 Honda GL1200 Goldwing
MacNoob is offline   Reply With Quote
Old 12-22-2012, 08:51 AM   #69
AC909
Great Job!
AC909's Avatar
Oddometer: 1,138
now go get it dirty!
A CT175 & XR250R Do A Few States of the TAT
http://advrider.com/forums/showthread.php?t=827855
A CT175 & DR350 Do a Few More States of the TAT
http://advrider.com/forums/showthread.php?t=1010764
AC909 is offline   Reply With Quote
Old 12-22-2012, 03:34 PM   #70
Jon
Jon's Avatar
Oddometer: 1,229
Turned out great. You'll have a blast on it.
I miss my plated CRF150F and you may have inspired me to build another neighborhood cruiser.
Jon is offline   Reply With Quote
Old 12-22-2012, 05:03 PM   #71
G19Tony OP
G19Tony's Avatar
Oddometer: 410
Thanks for the kind words.
After I get the other two bikes done. I want to plate, and supermoto a CRF150F. I need to find one for under a $1000 though. The sumo wheel and tire conversion will cost that.
Old 12-22-2012, 05:51 PM   #72
G19Tony OP
G19Tony's Avatar
Oddometer: 410
A couple more photos
I media blasted the header shroud and rattle canned it with Hi Temp Silver. It came out pretty close to the frame color.
The Vapor is mounted to the number plate screw on the front of the triple tree. It seems pretty protected. But I still think I will get the cover for it.
Old 12-23-2012, 12:05 AM   #73
RedRockRider
RedRockRider's Avatar
Oddometer: 1,410
Great project. Well done!
RedRockRider - WR250R, TW200, Versys, Vulcan 900 LT, Zuma 125
Southwest Utah: Dual Sport Riding from St. George
http://advrider.com/forums/showthread.php?t=725976
RedRockRider is offline   Reply With Quote
Old 12-23-2012, 01:04 AM   #74
roundtripping
Adventourist
roundtripping's Avatar
Oddometer: 1,702
Good job Tony, came out great!
12 F658GS
13 Honda CRF250L
My SPOT Tracker
roundtripping is offline   Reply With Quote
Old 12-23-2012, 02:14 AM   #75
milzispete
Conquistador
milzispete's Avatar
Oddometer: 282
a thing of beauty
projects like this just rock Gongrats on the result
If you are still looking for a surround for the vapor, Highway Dirt Bikes make one. They look great with just one of their top clamps if you don't want the full guard set up
they don't make 'em like they used to. which is a good thing really
milzispete is offline   Reply With Quote
Times are GMT -7.   It's 06:55 AM.
