Go Back   ADVrider > Bikes > Battle Scooters
Old 10-28-2012, 04:44 AM   #1
ride4321 OP
ride4321's Avatar
Oddometer: 2,058
84 Honda Elite 125 questions...
I posted on another thread here a few days ago about this Elite I picked up for $100. Thought I'd start a new thread since I'm gonna have a lot of questions and maybe I can get some answers here.
running!
http://youtu.be/8VbcPVuXns4
So I've got it running which is good. Don't have much info on this bike but did get the service manual online. I don't have a key but the switch has be "modified" and I can turn it with a pair of pliers now.
First question. It's on the center stand running but the rear wheel isn't turning, not even when I give it more throttle. I thought it should engage with throttle input. Is it possible the brake switch is sticking? I haven't messed with that yet.
Don't you know there ain't no devil, it's just God when he's drunk.
Tom Waits
ride4321 is offline   Reply With Quote
Old 10-28-2012, 04:58 AM   #2
avir
Oddometer: 20
check to see if the belt is in place....
avir is offline   Reply With Quote
Old 10-28-2012, 05:02 AM   #3
max57
max57's Avatar
Oddometer: 56
running!
I have one of those I bought new. Your wheel should definitely be turning. I would guess either the belt is broken or- gasp- the final drive went without lubrication. I did that back in the 80s, ruined the bearings and had to get it fixed. But of course look for little things first. Drain the final drive to see if any oil is in there.
"Deep in the heart of every human being...the drive to demonstrate competence." R. Buckminster Fuller
max57 is offline   Reply With Quote
Old 10-28-2012, 05:18 AM   #4
ride4321 OP
ride4321's Avatar
Oddometer: 2,058
Checked the fluid and it was over filled. Didn't look to see if the belt was even there. I'll go check that now.
The belt is in place and actually looks pretty good.
So the wheel should spin while it's on the center stand when throttle is applied?
OK, just got back in from messing with it. When I take it off the stands and give it gas it moves forward a bit. Can't sit on it and try it out because it's on jumpers to an extra battery right now. I'm charging the battery that fits and will try it with me on it once it's charged up.
It's starting up really nice now and I haven't even cleaned the carb yet.
Tom Waits
ride4321 screwed with this post 10-28-2012 at 05:38 AM
Old 10-28-2012, 07:14 AM   #5
baloneyskin daddy
bikaholic
Oddometer: 2,176
Do yourself a favor before things get ruined and pop the cover off the drive train area and at least clean it out . Better yet,pull the variators apart and clean out the 30 yr old grease which is more like wax by now and regrease and lube everything and it will run forever for you.
baloneyskin daddy is offline   Reply With Quote
Old 10-28-2012, 09:55 AM   #6
ride4321 OP
ride4321's Avatar
Oddometer: 2,058
Good point, I'll do that. I did give it a go in the garage with me sitting on it just now. It moved but felt like it was slow in doing it. I'll pull it apart and see how everything looks later.
I remember seeing it here but can't find it now and the service manual doesn't say...what kind of oil do I use in the tranny?
Tom Waits
ride4321 screwed with this post 10-28-2012 at 10:20 AM
Old 10-28-2012, 04:49 PM   #7
max57
max57's Avatar
Oddometer: 56
There is a parking brake on that scoot but I forget how it works. That would be funny. It is on the left side and is to keep the scoot from rolling off the sidestand. You have a nice scooter there. I have gotten over 100 mpg on my wife's one. Takes off quickly too. Put good tires on it.
Old 10-28-2012, 05:28 PM   #8
ride4321 OP
ride4321's Avatar
Oddometer: 2,058
I've been trying to figure out how the parking brake works. I was under the impression you just pushed the brake peddle down hard and it would stay in place until you pressed on it again but mine doesn't work that way. It still needs to be lubed though so I could be wrong.
Is this the parking brake? It's frozen in place but seems to be some sort of cable.
DUH, never mind, it says PARKING BRAKE right on it. I'm going to lube that up right now and see if I can free it up.
If anyone has a link to the owners manual it would come in very handy.
Note: The parking brake wasn't on but the cable was frozen. Loosened that up and also sprayed the rear brake cable. The wheel seemed to spin better so I took it up the road a block. It seems to go ok but takes some throttle to get it moving. More work needs to be done on the brakes however
Tom Waits
ride4321 screwed with this post 10-28-2012 at 06:12 PM
Old 10-28-2012, 06:58 PM   #9
ride4321 OP
ride4321's Avatar
Oddometer: 2,058
Exhaust
Decided to pull the exhaust off and see what was left of it. The flange for the manifold is shot but that can probably be fixed I think...
it was hanging loose so that wasn't helping the sound at all. You can also see the flange is cracked and bent.
The rest of it. Got all the screws off the heat shield except the last one. Decided to call it a night but the pipe seems solid, not sure about the muffler.
I'm assuming the muffler is built into the back part just before the tiny tailpipe?
Tom Waits
Old 10-28-2012, 07:09 PM   #10
max57
max57's Avatar
Oddometer: 56
The muffler is quite expensive. I need to replace mine after 11000 miles, and 27 years. Keep the exhaust studs lubed. That muffler comes off anytime you remove the rear wheel.
Old 10-28-2012, 07:16 PM   #11
ride4321 OP
ride4321's Avatar
Oddometer: 2,058
I can see that. I'm hoping I can get this welded up and use it as is. $360 for a new exhaust just isn't in the budget until I ride it for awhile and make sure it's reliable. I think a welder can fix up the mount for me, then I can see how it sounds.
Guess this will be a good time to pull the wheel and check the bearing eh?
Tom Waits
ride4321 screwed with this post 10-28-2012 at 07:22 PM
Old 10-28-2012, 07:26 PM   #12
_cy_
Oddometer: 6,443
I've got two Honda Elite 125 parts scooters .. probably have a muffler if you cannot make that one work.
Old 10-28-2012, 07:27 PM   #13
max57
max57's Avatar
Oddometer: 56
What is the odometer reading? One surprise about the pop up headlight- it keeps on working year after year. I had to adjust it once.
Old 10-28-2012, 08:01 PM   #14
ride4321 OP
ride4321's Avatar
Oddometer: 2,058
I'll keep that in mind but will try to fix this first. Do you think one of them is in good shape? PM a price to me if it is.
Tom Waits
Old 10-28-2012, 08:03 PM   #15
ride4321 OP
ride4321's Avatar
Oddometer: 2,058
I think it's showing around 2600 on the odometer. I was real happy that the pop up light worked, wasn't expecting that. For $100 I'm just glad it's running to be honest.
Tom Waits
Times are GMT -7.   It's 07:18 AM.
