Old 06-29-2014, 11:27 PM   #1
9secondsflat OP
Oddometer: 328
Intake manifold gasket leak
I was helping one of my friends out this past w/e with his scoot and located his problem a torn/worn out intake manifold gasket. My question can I use permatex ultra black silicone to make a new gasket? I can only find a stock oem gasket over seas and it will take 2 + weeks to arrive.
9secondsflat is offline   Reply With Quote
Old 06-30-2014, 06:55 AM   #2
9secondsflat OP
Oddometer: 328
its a mojito scooter (same one as i have)
the brand of scoot is meaningless...an intake leak is an intake leak.
the permatex copper is not made to come in contact with gasoline.
Old 06-30-2014, 07:24 AM   #3
tortoise2
tortoise2's Avatar
Oddometer: 540
If you are referring to the Piaggio 4-stroke LEADER engine . . what is so unique about the intake manifold gasket that you just can't fabricate one from the various gasket papers?
In this application, valve packing may be an alternative to the silicone products.
tortoise2 is offline   Reply With Quote
Old 07-03-2014, 05:16 PM   #4
manofwheels
Oddometer: 21
Use the copper silicone as dabears stated. In addition, buy some loctite clear sealant and apply it around the edge of the the intake manifold to have an airtight seal. This stuff isn't just for water leaks. I used both of these products on my 278cc scooter.
http://m.loctiteproducts.com/p/6/0/2...rproof-Sealant
manofwheels is offline   Reply With Quote
Old 07-04-2014, 05:47 AM   #5
MODNROD
Perpetual ponderer
MODNROD's Avatar
Oddometer: 2,102
Cornflakes packet.
Who the hell would drag race a Ducati?!?!?!?!
http://www.dragtimes.com/Ducati-Mons...lip-10329.html
MODNROD is offline   Reply With Quote
Old 07-04-2014, 11:44 AM   #6
manofwheels
Oddometer: 21
I actually used the copper silicone on a plastic gasket that was dripping some coolant. It works well. The water sealant reinforces the gasket and I used it keep my windshield from rattling due to two of the tabs I broke by yanking it. No more rattling.
Old 07-04-2014, 09:50 PM   #7
fullmetalscooter
Let me take this duck off
fullmetalscooter's Avatar
Oddometer: 2,937
One more thing is it worth going that route becasue often the OEM gasket is cheap , eg ch80 is 15 bucks . Also with most engines out there there are cheap clone gaskets kits. The cn250 clone kit is 20 bucks . The only issue with doing what your doing is using to much and having it end up in oil or water passages in the engine.
Life's journey is not to arrive at the grave safely in a well preserved body,but rather to skid in sideways totally worn out shouting WHAT A RUSH, WHAT A RIDE.
"Life is a tragedy when seen in close-up, but a comedy in long-shot." Charlie Chaplin
fullmetalscooter is offline   Reply With Quote
Times are GMT -7.   It's 08:19 AM.
