Old 10-29-2012, 01:24 AM   #1
koh kood OP
koh kood's Avatar
Oddometer: 117
Hiding tracks, routes in Mapsourse
Could someone please tell me if it's possible to hide tracks or routes in Mapsourse? All the tracks/routes I have show up on the map, the map is pretty busy with everything being shown. I'd like to hide them if possible and just look at them when I need to. When I look at the track or route properties there is a box that says "show on map" but nothing there that says "do not show on map".
Thank you
"I wasted time, and now time doth waste me."
koh kood is offline   Reply With Quote
Old 10-29-2012, 05:10 AM   #2
koh kood OP
koh kood's Avatar
Oddometer: 117
Seems like I should have looked a little harder first. Can't be done.
http://www.advrider.com/forums/showthread.php?t=501024
koh kood screwed with this post 10-29-2012 at 05:12 AM Reason: spelling
Old 10-29-2012, 06:14 AM   #3
BKMLWR
Wondering around...
Oddometer: 4,579
basecamp can help out with this issue. create a folder for a given area then make lists for routes/tracks/waypoints in the given area. Each list can be viewed without seeing the info in the other lists...
Sometimes I get off the bike before it has come to a complete stop....
Another Proud Small Scale Faker......
Praise You In This Storm
LifeSong
BKMLWR is offline   Reply With Quote
Old 10-29-2012, 07:14 AM   #4
BigDogAdventures
Fart Letter
BigDogAdventures's Avatar
Oddometer: 4,941
In mapsource here is what I do.
If I did not want to see the tracks-----I'd make another file and copy and paste the things you wanted to see into it---you could save it and call it the same name as the old file but add "Without Tracks".
Or--------in the running file----you could delete the tracks------just don't save it as you close the file or they'll be gone.
I do both of these things all the time.
BigDog
2008 Yamaha WR250R---by far my main bike.
2006 KTM 450EXC
2014 KTM690 Enduro--we'll see how good it is after 70,000 miles.
2013 Husky 650 TR650 Terra
I'm good--but I ain't no Dingweeds
BigDogAdventures is offline   Reply With Quote
Old 10-29-2012, 07:51 AM   #5
Spiritwalker2222
Oddometer: 112
I haven't used Mapsource in a long time, but can you change the track color to invisible for the ones you don't want to see?
Spiritwalker2222 is offline   Reply With Quote
Old 10-30-2012, 02:19 AM   #6
koh kood OP
koh kood's Avatar
Oddometer: 117
Thanks to all of you for the suggestions.
Old 10-30-2012, 03:49 AM   #7
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 12,940
I use separate files for different trips and save them in a single folder on my computer.
It is possible to turn the color of the route to "clear" so they don't show on the screen, but are still listed in the track and route list. When you want to show them, just change the color back to something you like.
dunno.....
Old 10-30-2012, 06:49 AM   #8
koh kood OP
koh kood's Avatar
Oddometer: 117
Maybe it's the version of Mapsourse [6.14] I have. I can change the track/route colour to "transparent" but it really still shows up as a thin black line. With all the track log points still being displayed.
Old 10-30-2012, 11:26 PM   #9
Countdown
Oddometer: 5,345
Originally Posted by koh kood View Post
Could someone please tell me if it's possible to hide tracks or routes in Mapsourse? All the tracks/routes I have show up on the map, the map is pretty busy with everything being shown.Thank you
Mapsource is an application like Word. You keep Mapsource data in files (.gdb or .gpx).
It sounds like you have all your data in ONE FILE. Do you keep all your word text in one .doc file, NO. Each item is in its own file.
You can open new a "Untitled" MapSource file, cut some data from your giant file and past in new one and Save As what ever the subject is.
Jerry Counts
Countdown is offline   Reply With Quote
Old 10-31-2012, 07:43 AM   #10
koh kood OP
koh kood's Avatar
Oddometer: 117
I was trying to keep everything in one file. I guess it's not the easiest way to do things. I'll try your suggestion. Thanks.
Old 11-01-2012, 07:35 PM   #11
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,543
Sounds to me like you'll need BaseCamp in that case. It'll let you have all your tracks in one environment but still manage them effectively, in folders.
Emmbeedee is online now   Reply With Quote
Old 11-07-2012, 11:15 PM   #12
Timmer
Timmer's Avatar
Oddometer: 2,323
Why not just set the property color of the track or route to transparent which will leave a very faint line. That's the quickest method I've found. Alternatively, in BC, I just copy what I might want to view to a new list folder.
Tim in Burien, WA
'05 R1200GS '03 F650GS
'08 WR250R
'03 Wing
'01 ST1100
Timmer is offline   Reply With Quote
Old 11-19-2012, 01:19 PM   #13
wbbnm
wbbnm's Avatar
Oddometer: 2,064
I often want to hide the tracks too in order to see what the underlying road looks like or if it even exists in a given mapset.
I tried the transparent option and it did not have the desired effect. It left a whitish thick line with a dark line connecting the very visible track points. I could not see the underlying roads.
I guess I will go back to what I usually do and temporarily delete the track and then restore is via Control-Z.
Maybe I did something wrong with the transparent selection?
wbbnm is offline   Reply With Quote
Times are GMT -7.   It's 06:30 AM.
