06-21-2010, 07:43 AM
#1 |
Oddometer: 31
Last year I purchased a euro-spec ignition switch so I could run just the pilot light in the daytime if I wanted, or at least turn off the headlight at my command as opposed to having it "on" all of the time. But when I went to install it, I could not make sense of the wiring, which way to plug in, etc. I tried a couple of combinations, but nothing seemed to work when I operated the switch. Anyone here put one of these switches in a US spec bike? How did you plug the wiring in?
Anybody? Anybody? Beuhler? Any suggestions and I am all ears!
06-21-2010, 07:55 AM
#2 | |
airhead or nothing
Oddometer: 7,935
When I had a GS, I bought one, unplugged the US version and plugged the Euro right in...
"punkrocks what it's all about" - J. Strummer Quote:
06-21-2010, 09:31 AM
#3 |
Oddometer: 3,739
What year is your gs?
88-90 the colours are red = 30 green = 15 grey =58 White/yellow =56 exactly the same as the us switch. As solo says there shouldn't be any other differences. 1990 on the lights are switched on using the right hand switchgear - the ignition switches are identical. Rob Farmer screwed with this post 06-21-2010 at 09:52 AM |
06-21-2010, 09:33 AM
#4 | |
Oddometer: 31
1988`
06-21-2010, 09:58 AM
#5 |
Oddometer: 3,739
The wirings identical to the US switch so it should be plug and play
06-21-2010, 10:17 AM
#6 | |
Oddometer: 31
06-21-2010, 10:20 AM
#7 | ||
airhead or nothing
Oddometer: 7,935
06-21-2010, 11:17 AM
#8 |
Beemerguru...G/S guy
Oddometer: 635
You've got 5 positions on the European ignition switch and it's a real PITA to switch postions while in motion. Much easier to just get the European handle bar switch.
Europeans allow for side lights for parking, no front lights but fog lights, etc. Droive me nuts whenever I drive a car over there. And the Euro ignition switch does the same thing for the bike...way overkill for the States. Actually on yours, keep the same US ignition switch and swap the green and gray wires..does the same thing.
Greg Hutchinson BMW Club of Northern California, Ambassador, BMW MOA, Vice President Vintage BMW Club http://gregsgssite.shutterfly.com/ ![]() |
06-21-2010, 11:20 AM
#9 | |
Oddometer: 3,462
06-21-2010, 11:56 AM
#10 | |
Oddometer: 31
5 positions?
1988 BMW R100GS Blue & White, mine since new 1973 Honda CL350 Scrambler mine 6-21-2009 1964 BMW R50/2 mine since early 1990s, sadly in boxes awaiting time & $$ |
06-21-2010, 12:53 PM
#11 | ||
airhead or nothing
Oddometer: 7,935
Thanks! SL
06-21-2010, 01:11 PM
#12 |
Oddometer: 3,739
The 5 positions are:-
1- Off 2 - Parking Lights 3 - Ignition On 4 - Ignition + Side lights 5 - Ignition + Side lights + Main Lights The Euro early 88-90 Paralever (with the Mono style headlight Pod) has the same switch gear as the US bike but has the 5 position switch. The later Paralever 91 onwards (with the roo bar) has the same ignition switch as the US bike but has the light off/Side/Main switch on the right hand switch gear on the Euro bikes. |
06-21-2010, 01:13 PM
#13 |
Oddometer: 635
Anton's right on the Euro handle bar switch. They work on later GSs and K bikes only. I confused early and later model G/Ss..when BMW opted for the K bike switch gear for the GS in '91?, then the handle bar swap will work.
I have the Euro ignition switch on the G/S in NC..will be there over the 4th and will post what happens in each position. Thought it would be cool to have it..not true as experience happened. Just switch the 2 wires
06-21-2010, 01:18 PM
#14 | |
Oddometer: 3,462
So is it safe to say: G/S - uses the euro switch on the handlebar GS 88-90 - uses 5-position key or swap gray and green wires GS 91-on - K-style euro switch on handlebar EDIT: no, this is wrong ?? AntonLargiader screwed with this post 06-21-2010 at 05:34 PM |
06-21-2010, 01:57 PM
#15 |
Oddometer: 3,739
The Euro g/s uses uses the same 5 position switch as the 88-90 GS but there are wiring differences that are shown in the later Haynes manual.
