Old 10-31-2012, 10:32 AM   #1
christian OP
Exchange your GPS Track!
christian's Avatar
Oddometer: 2,657
Yamaha Majesty - About to buy things to watch?
I am about to buy my first Maxi scooter, yamaha Majesty 400 , 2008, 9000 miles.
I checked the scooter, everything seems to be where it needs, so that's good.
Anything special to watch on these? I did a search on here and MajestyUSA.com but couldn't come up with anything significant.
so far
- Check with Yamaha that the fuel pump recall was done.
- Watch the air filters they can get dirty real quick.
- Slow off the start - can be adjusted with different variator weights
- Belts to be replaced at 12k miles normally - some keep it longer.
- Valve check at 24k miles
Anything bad like engine, or other ?
Kind of like the 950/990 KTM with their water pump, 640 KTM with their crankshaft bearing, Vstrom with their clutch chudder, etc...
Each bike has their issues, just trying to know about the Majesty ones before buying.
Thank you
Christian
KTM 950 ADV '05.5
KTM 690 '10
christian is offline   Reply With Quote
Old 10-31-2012, 12:28 PM   #2
Jim M.
Oddometer: 59
The wife has about 25k miles on hers. It's been solid as a rock and we've had no problems whatsoever. If your over 6' tall, leg room may be a little short. I'm 6'2" and a little more room would be nice. She's 5'8" and has no problems.
Jim M. is offline   Reply With Quote
Old 10-31-2012, 01:03 PM   #3
christian OP
christian's Avatar
Oddometer: 2,657
thank you
KTM 950 ADV '05.5
KTM 690 '10
Old 10-31-2012, 01:27 PM   #4
JerryH
Oddometer: 5,069
The Majesty seems to be rock solid, with one major issue. The valves. While they don't need to be checked for a long time, when they do, it is such a major job that I have heard it is cheaper to buy another scooter than to do the valves. I got this information from a Majesty forum when I was considering buying one. Apparently you have to just about disassemble the entire scooter, including removing the engine, to get to the valves.
I was considering buying a brand new leftover model, for almost $10K OTD, and would have reached valve adjustment time in about 3 years. I decided if it was that bad, the investment wasn't worth it. My three year old $10K scooter with 24K miles on it would be worth less than $3K. That is some very expensive riding. Used seems to be the only way to go with these.
JerryH is offline   Reply With Quote
Old 10-31-2012, 01:33 PM   #5
christian OP
christian's Avatar
Oddometer: 2,657
Thanks, this one has 9000, I do ~4000 miles a year commuting
that gives me 3 1/2 year - so I'll deal with it then and I do all my service anyway.
KTM 950 ADV '05.5
KTM 690 '10
Old 10-31-2012, 02:45 PM   #6
Paul Mihalka
Old Fart
Paul Mihalka's Avatar
Oddometer: 877
I recently bought a Majesty, "used", with 160 miles. I've read as much as could about it. This is the first time I read about valve check/adjustment being THAT expensive. I don't believe it. I know BMW bikes. To replace a clutch you take off all the body (a lot on some) and then split the bike in half. The labor on that is steep, but not so much that you would rather replace the scooter if that cost would be on the Majesty. I'll find out fairly soon. With my R1200GS I rode 25 to 30K miles a year. I won't ride that much on the Majesty, but I guess around 15K. We'll see...
Paul Mihalka is offline   Reply With Quote
Old 10-31-2012, 05:32 PM   #7
2WheelDuende
Oddometer: 27
I have an '06 I bought in '08 with 700 miles. It has been great so far and I prefer to commute on it rather than my Marauder. I have about 17k miles and replaced the belt this summer. I was getting a little nervous about it. The belt light will come on at 12500, and there's a procedure to reset. Find it on majestyusa. Scooter club rides and scooter events are a lot of fun too.
2006 Yamaha Majesty(gone to da boneyard)
1998 Suzuki Marauder
2011 BMW R1200R
2WheelDuende is offline   Reply With Quote
Old 10-31-2012, 07:48 PM   #8
Racerrrx
Oddometer: 123
Love my '05, has about 20K on it, no issues. I tried lighter/fewer roller weights and they helped but ended up going with a J Costa variator, much better! I really think the Maj is dangerously slow off the line stock. Stock I got 60mpg and now I get 50mpg, totally worth it.
Racerrrx is offline   Reply With Quote
Old 10-31-2012, 11:08 PM   #9
JerryH
Oddometer: 5,069
From what I read on the Majesty forum, adjusting the valves is akin to rebuilding the engine on some bikes. It seems that many just ignore the valve adjustment, and ride it for as long as it runs, or sell it before it quits running. Valves seem to be the biggest issue on maxi scooters, I don't know why they didn't design them so they are easier to get to, or use hydraulic valves. I chose the Zuma 125 over the PCX150 solely based on how hard it was to do the valves. Zuma, 15 minutes. PCX, 3 hours.
Old 10-31-2012, 11:54 PM   #10
focus42
Oddometer: 1
I'm assuming your looking at the black one off of the bay area Craigslist. If so, buyer beware. I looked at it as well. Felt like it had been ridden hard and put away wet. I've owned a Majesty before and found that one to be much smoother through the gears and with less clutch noise and play. The price is right though. I talked the owner down to 2,000 for it and just couldn't pull the trigger. Good luck!
focus42 is offline   Reply With Quote
Old 01-04-2013, 07:16 PM   #11
vader1701
vader1701's Avatar
Oddometer: 32
I own a 2008 and love it, I have done some mods to it, and I just bought a Laminar Lip to see if it will help the buffeting effect, going to do a full video on it as soon as the weather breaks. I am looking at maybe buying a Burgman 650E in 2014 but it does make me look at my Majesty, I only have 5K miles on it I do my own work on it.
Bob
See my Blog http://vader1701.blogspot.com/
Also my YouTube channel LordDarthVader1701
vader1701 is offline   Reply With Quote
Old 01-05-2013, 08:31 PM   #12
Chillis
Land Barge Pilot
Chillis's Avatar
Oddometer: 4,033
I can't believe nobody has adjusted the valves on one. Time to do some research. I have been looking at these as an option for next purchase(along with a lot of other bikes/cars as well and the valve issue is enough to scare me off.
I used to enjoy wrenching on bikes/cars/R/C, but not as much any more.
Why not hydraulic lifters???
Functional obsolescence and more jobs?
Chillis is offline   Reply With Quote
Old 01-05-2013, 08:50 PM   #13
Dabears
Oddometer: 710
Did you try looking here? http://majestyusa.com/forums/index.php
1980 Vespa P200E
2006 BMW R1200GS
2012 SYM HD200 Evo
Dabears is offline   Reply With Quote
Old 01-05-2013, 09:43 PM   #14
Chillis
Land Barge Pilot
Chillis's Avatar
Oddometer: 4,033
I did some snooping around there and it seems the folks who took the bikes to dealers had mechanics who "said" the valves were in spec, which working in several MC shops over the years means they were too lazy to check.
Apparently it is a big job of up to 7 hours of shop time to do the full procedure.
Sounds like a good long running bike though.
Old 01-07-2013, 02:02 PM   #15
christian OP
christian's Avatar
Oddometer: 2,657
well I really enjoy my Majesty, it came with a bagster apron/leg cover which I don't need/use.
It's up for sale in the flea market, Let me know if anyone is interested.
thx
KTM 950 ADV '05.5
KTM 690 '10
Times are GMT -7.   It's 01:50 AM.
