Old 11-29-2012, 03:31 PM   #46
UtahFox
UtahFox's Avatar
Oddometer: 446
Originally Posted by pilot3 View Post
That's pretty funny. Maybe next batch I include another one of those stupid little tabs so you can just rip the other one out of there. Yeah it's a bugger, no doubt. And it doesn't help that the plug obscures the lower screw for the light.
Looks great!
p3
Yeah, all that and I'm near sighted so the closer I'd get to have a look, the less I could see. Plus, I just couldn't get any leverage with my fingers. I wound up gently using a pliers to get it off the tab, it took maybe 3 or 4 tries to get it lined up enough to slide back on.
Before getting the connector off the tab, I got as many of the wires out of that compartment, routing them around some other things to keep them out of the way. This revealed the lower screw nicely. I used a standard allen wrench, which I could only get the screw turned a tiny bit, but 2 or 3 of those teeny maneuvers and it was hand loose.
It was fun. Have some Barkbusters & Oxford grips on the way, I hope the grips are as easy as this was.
UtahFox is offline   Reply With Quote
Old 11-30-2012, 07:04 AM   #47
Ronin1
Hoonigan
Oddometer: 66
Are these still available?
Jim
Ronin1 is offline   Reply With Quote
Old 11-30-2012, 08:16 AM   #48
PDXBOB
PDXBOB's Avatar
Oddometer: 2
Can't Wait!
Hearing these stories of how easy this is to install is exciting.
But I'll bet you I still figure out a way to f* it up!
I have a knack for that sort of thing!
PDXBOB is offline   Reply With Quote
Old 11-30-2012, 08:30 AM   #49
pilot3 OP
Oddometer: 415
Jim
PM sent
pilot3 is offline   Reply With Quote
Old 11-30-2012, 08:35 AM   #50
pilot3 OP
Oddometer: 415
Next batch of lights
Hey guys,
Thanks to everyone who purchased in round 1. Feedback has been great so far!
For everyone on the wait list, I will probably start the ordering for round 2 next week.
Here is who I have so far:
Rofor
wanderlost
invicta1
PDXBOB
erikh58
ronin1
Anyone else, let me know.
p3
Old 11-30-2012, 06:35 PM   #51
orv
Busted butt
Oddometer: 443
Done!
Took less than an hour and a half. Most was to find the right tools and to figger out where that slot went. I'd have liked one more slide showing the slot from the back of the bike. After examining the bike it was evident what was needed, though. I also had to retrieve two, 2, more than one, friggin screws from the depths below the seat lock. Stoopid.
I suggest that anyone else installing one of these lights stuff the bottom of the cavity with rags or paper to the level of the bottom screw before taking out and re-installing the screws.
One of the best deals about this light is that I did not even have to Think about playing electrician. Snapping in the connectors was a dream compared to most electrical accessories, and I'm not going to be worrying about the connections going down the road. When it comes to brake lights, that means a bunch.
It looks great, and is Very bright. Thanks!
If anyone in the Denver area wants a hand with installation, I'll guarantee it will be done in 30 minutes!
orv is offline   Reply With Quote
Old 11-30-2012, 06:40 PM   #52
doxbike
Oddometer: 277
Thumb
Got it in tonight with just a little finagling. Couple of tips-my connector was taped to the tab-they didn't have it snapped in, so check for that. Stuff some paper towels in the void when taking out and replacing the rear light assembly 3 bolts in case you drop them. Works great! Attention grabbing for sure. great farkle
doxbike is offline   Reply With Quote
Old 12-01-2012, 07:50 AM   #53
swimmer
armchair asshole
swimmer's Avatar
Oddometer: 4,635
Got mine installed. 40-45 minutes total work time. Nice.
swimmer is offline   Reply With Quote
Old 12-01-2012, 10:58 AM   #54
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,666
Installed mine today also. Took me about 50 minutes. All went great.
Not that it matters, but I used a bastard file to create the arch in the plastic tab, and then used a square edge file to cut it to a rectangle that just perfectly fit the cord going through it. I took my time and it probably added 15 minutes to the job.
Also, as my garage was kind of chilly, I used a heat gun to gently warm the light assembly and plastic tail piece before applying the sticky tape. My thought is that it will soften the adhesive a bit and help it to adhere better.
Works great! Thanks again, Greg, for your excellent workmanship.
Old 12-02-2012, 12:27 PM   #55
NaDSoB
Another asshole on a KLR
NaDSoB's Avatar
Oddometer: 364
Thumb Awesome!!!
Pilot -
Finally got around to installing mine today. Thanks to both your workmanship and clear instructions, the install went without a hitch (which for me, is nothing short of remarkable!).
I can't thank you enough, this is one of the best upgrades I've done on my Tiger! Please be sure to let me know if you come up with any future projects.
Rob
"Tire tracks and broken hearts, that's all we're leaving behind.
It doesn't matter what we're losing, it only matters what we're going to find!"
Meat Loaf from "A Kiss Is A Terrible Thing To Waste", Lyrics by Jim Steinman
NaDSoB is offline   Reply With Quote
Old 12-02-2012, 05:11 PM   #56
terrytwn
terrytwn's Avatar
Oddometer: 1
Is this still available?
This looks to be a wonderful addition and I was wondering if I can still tag along?
terrytwn is offline   Reply With Quote
Old 12-03-2012, 10:20 AM   #57
JayL
Oddometer: 4
Count me in for the next run of units.
JayL is offline   Reply With Quote
Old 12-03-2012, 11:05 AM   #58
pilot3 OP
Oddometer: 415
Round two forthcoming!
OK I am going to order the next batch today. The next group of buyers includes:
Rofor
wanderlost
invicta1
PDXBOB
erikh58
ronin1
terrytwn
JayL
I just PM'd the above inmates. Please confirm and respond via PM.
Anyone else let me know.
p3
pilot3 screwed with this post 12-03-2012 at 11:16 AM
Old 12-03-2012, 01:54 PM   #59
klrider99
I know a shortcut........
klrider99's Avatar
Oddometer: 28
Hi Greg,
Got my light installed easily last Sunday evening. Great instructions, and a very nice piece of kit.
Pat
'11 Multistrada 1200S Touring, Tiger 800 XC, DRZed 400SMDirt '05 Lil Ruckus, SR500G
Adventure bikes: Fours are foreign, Twins are in, Thumpers are cool, but Triples Rule!
klrider99 is offline   Reply With Quote
Old 12-04-2012, 09:15 PM   #60
pilot3 OP
Oddometer: 415
Thanks guys!
Thanks for the kind words everyone. I strive to send out a professional product because that is what I would want to receive so I'm very happy everyone liked their lights and the installations went smoothly. I'll take your suggestions and update the install instructions with the improvements.
For the next in line, I got responses from only two of you so far. I appreciate payment and will order when I get 5 confirmed. I PM'd or emailed everyone else, so please check your inboxes for your purchase information.
Regards,
p3
Times are GMT -7.   It's 05:54 PM.
