Old 11-02-2012, 06:00 PM   #1
tommcbride OP
tommcbride's Avatar
Oddometer: 1,081
BMW item identification help
Hi GANG!
I have a BMW 247 motor that has a screw in the left side of the case just under the oil level indicator switch
Anyone have any idea what this is for?
It appears the ONLY way to access this is to remove / loosen the motor from the frame.....
Thanks in advance.
Tom McBride
tommcbride is offline   Reply With Quote
Old 11-02-2012, 06:23 PM   #2
dave0
Oddometer: 20
Most likely an oil galley plug. No reason to eff with it unless you're in the middle of a complete engine teardown.
dave0 is offline   Reply With Quote
Old 11-02-2012, 06:30 PM   #3
bmwrench
Oddometer: 2,182
It's the driling to the the oil pump. A similar one can be seen at the rear of the crankcase. The rear drilling intersects the side one and delivers oil to the oil filter cannister.
Since these plugs see full pressure from the pump, they can be difficult to seal. I remove them and spray the threads and passages repeatedly with alcohol-based brake cleaner. When oil stops emerging-and this can take a full day-I apply Loctite 272 (red) to the plugs and screw them back in. Give the Loctite time to cure and/or apply some heat to speed the process. You will need to jack up the back of the motor, but this can be done without removing drive shaft bolts, etc.
bmwrench is offline   Reply With Quote
Old 11-02-2012, 09:08 PM   #4
tommcbride OP
tommcbride's Avatar
Oddometer: 1,081
So, it's just a PLUG, nothing more nothing less?
Tom McBride
Old 11-02-2012, 09:09 PM   #5
tommcbride OP
tommcbride's Avatar
Oddometer: 1,081
Seems you are spot on dave0
Tom McBride
Old 11-03-2012, 12:04 AM   #6
kbasa
Colnago!
kbasa's Avatar
Oddometer: 69,691
Moved to airheads
IMHO.
Fuck Cancer. Ride bikes. - dave + tina
kbasa is offline   Reply With Quote
Times are GMT -7.   It's 07:17 PM.
